Results 1 to 14 of 14
    Established Member Two Rings joebleu's Avatar
    Dec 11 2009
    Los Angeles, CA
    Question Stock Alarm Replacement using VW Alarm?
    Hey guys,
    I have a question that I hope to get your experiences on.
    Short Version: Are VW electronic parts typically the same as Audi part? Specifically, is the VW alarm the same as the Audi one?
    Long Version: I am trying to replace my stock alarm horn (eaten away by dead battery). I pulled the old one from the trunk using this guide:
    http://www.audizine.com/forum/showthread.php?t=306320
    The part number is 8L0 951 605. A search on genuineaudiparts.com showed that the part has been updated to 8L0 951 605A, which looks like this:
    The part costs $176.40... which is a lot. I then did further research and found that there is a VW part of 1J0 951 605A, which looks like this:
    That part only costs $85.68. Do you think that they're actually the same part? $86 bucks is a lot but it is way cheaper than the Audi part. I have not been able to find any research to install a generic (2-pin) alarm in place of the Audi (3-pin) alarm unit. If they're the same part, i'm going to get the VW part and hope that it will work since there's no return on electrical parts.
    Thanks for your opinions!
    BTW, I'm new here so Hi! I just bought an 03 Audi A4 1.8TQ and I'm constantly worried that I've forgotten to lock my doors.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Stock Alarm Replacement using VW Alarm?
    Should work just fine. Has the same software programmed as the Audi unit.
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    Probably the one you're looking is for a Rabbit or a Jetta, and the one for our A4s probably crosses into the Passats or something. Is there anyway to replace it for something louder?
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Established Member Two Rings Darwood's Avatar
    Sep 12 2009
    2003 A4 3.0 quattro
    Pennsylvania
    Interested in whether this will work. Dealer quoted me like $225 for the Audi module, but if that VW one works, I'm on it. Looks like there's no reason it wouldn't work...
    May 06 2007
    3.0 quattro
    South of Montreal
    Dec 11 2009
    Los Angeles, CA
    Quote Originally Posted by chrom View Post
    The Lambo one is even more expensive than the Audi one! Haha... I'm trying to save money here.
    Thanks for the link for the pin diagram. Why didn't I think of that? My old alarm is taken apart so I double checked. The three pins are:
    1. GND
    2. Comm
    3. +12V
    If I were to go generic, how should I tap the signal? The generic alarms only have 2 wires (pos/neg). I think I'll need a way to get the Comm signal to the alarm?
    Dec 11 2009
    Los Angeles, CA
    I did some further research and it looks like there are some differences in the VW unit.
    On the VW forums, the pins inputs seem to be:
    1. Comm/Signal
    2. GND
    3. +12V
    If all else is the same, I might need to just buy an extra connector or cross-splice the 1st and 2nd cable. But now there is a bit more doubt as to whether the unit is the same inside.
    2003 Audi A4 1.8T Quattro
    APR Stage 1+ | Genesis 380cc Injectors | EuroCode FMIC | RS4 Sway Bar | Neuspeed SS | DV710N
    Sep 12 2009
    2003 A4 3.0 quattro
    Pennsylvania
    Theoretically, the only reason these have a 12V and ground connection is for charging the batteries inside them. I wonder if the alarm control module is "aware" of what type of siren is connected to it. I'm thinking not, since mine is dead and the car doesn't seem to be bothered by it. I also can't see any GOOD reason why these two parts would be wired differently, that defeats the purpose of the whole economy-of-scale/parts commonality that carmakers love so much these days... That said, I looked for a Passat part but couldn't find one with a part number or picture. The 1J0 part is used in Phaetons and Touaregs, apparently.
    Dec 11 2009
    Los Angeles, CA
    Well besides charging the battery, I think it may also provide power for the alarm itself. I wonder what would happen if i just connected a generic alarm to the signal line and the ground.
    Haha... it has been a long time since I've taken a class in circuits. Those were the days.
    Too bad I don't know anyone with a Phaetons or Touaregs to test it out.
    Feb 26 2011
    Vancouver, Canada
    Quote Originally Posted by joebleu View Post
    Joe,
    Did the VW alarm work?
    Rob
    Dec 11 2009
    Los Angeles, CA
    Quote Originally Posted by robbyvanz View Post
    Joe,
    Rob
    I don't know. I ended up getting a used Audi unit. Let us know the results if you try it!
    Sep 16 2010
    Central Wash
    It would work, but most of the VW horns had a "honk" instead of a "chirp" up to the mk6/ late 05' model,....so, you'd get that surprise when you installed it!
    Feb 26 2011
    Vancouver, Canada
    Quote Originally Posted by rollerton View Post
    The VW alarm siren shown above is a "beeping" type alarm siren. It was used in Touareg's and Phaetons. Other VW's use a 2 wire horm for the alarm. Here's a link to youtube:
    http://www.youtube.com/watch?v=9N0d_Y4cF3c
    Looks like just wire 1 and 2 are reversed.
    Apr 01 2005
    one wagon one truck
    Michigan
    So does anyone know if the VW will for sure work and what part number it is? I just took mine out and it has to much corrosion for me.
    2009 Audi A4 avant, ECS CAI, Malone stage 2 tune, etc.
    1995 Mazda Miata Montego blue with tan
    2003 A4 1.8tqms Mototec Cold air intake, USP door Blades, GIAC software and bigger injectors. - Gone
