Results 1 to 19 of 19
    Jan 22 2010
    Goldsboro, North Carolina
    drive shaft oil leak
    Hi every one, new to the forum and really need help. Saw a small puddle forming under the car a few days ago and went under for a closer look. Please see the photo I did some searches, but I am quite honestly not sure what to query (I don't know what the specific area that I need help with is called). There seems to be some talk about center support bearings, but I don't think this is it (or is it). If any one has a DIY for this already, please point me in the right direction. I have a good amount of tools and am not afraid to dig in. The problem is that I cannot find a hanes or chilton for this model.
    Is this doable on jack stands and are there any "while you're there" items I should be aware of.
    Thank you for any help.
    BTW, while I was searching for what this problem was, I saw an offer on blauparts.com at the bottom of the page that they will rebuild certain model driveshafts for free. No affiliation, just passing on what I saw.
    (http://www.blauparts.com/audi/audi_d...pair_kit.shtml)
    Chris
    2002 Audi A4 B6 Quattro 3.0 automatic, 75K miles[
    Last edited by cjs 928; 01-22-2010 at 08:20 PM. Reason: still tryin got attach picture
    Veteran Member Four Rings drjonez's Avatar
    Oct 27 2009
    2011 Q7 TDI Prestige, '72 Nova
    The Cheese State
    Re: drive shaft oil leak
    I don't think that's coming from the driveshaft, it's more like the oil seal on the end of the trans. Not a hard job at all.
    '11 Q7 TDI Prestige
    Function > Form
    Veteran Member Three Rings A4Avant02's Avatar
    Feb 05 2008
    '02 A4 Avant, '74 Triumph TR 6
    Folsom, Cal
    Looks like the oil seal on the output shaft of the center diff. Not a hard fix at all, the seal is not too expensive either.
    Take a look at this thread for a bit more info: http://www.audizine.com/forum/showth...nsmission+Seal
    Oct 27 2009
    The Cheese State
    Quote Originally Posted by A4Avant02 View Post
    Ah crap, I meant center diff.... That's what I get for posting early in the AM...
    '11 Q7 TDI Prestige
    Function > Form
    Jan 22 2010
    Wow, thanks all. Pictures help a bunch. Can you guys point me in the right direction for the best place/price to download the repair manual for this car. I have seen $91, but have heard I can get fit or $60 or less-would prefer to download (I need the torque specs).
    Also, anyone come across a drawing/pic naming what all the large parts under the car are. This is why I suffer at the search process-I don't know what to call these items.
    Thank you again.
    Jan 22 2010
    doing a search for the manual, here is what I have so far for those searching for the same:
    Partsgeek-$91.75 for the cd
    Bentley publishers-$129.95 for the dvd (not sure what the difference is)
    Jan 29 2007
    08 S4 00 S4
    MD
    Bentley manuals CD's usually go for right around 100 bucks outside of Robert Bentley. They may be or have phased out the CD version directly from them. There is also an online parts database similar to ETKA that can be used to look up part numbers. www.vagcat.com. Just register and it's free.
    08 S4- Stock SOLD
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Quote Originally Posted by drjonez View Post
    when the plug is removed, does it drain all the fluid? so i know how much to get. thanks
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by mrbacardi35 View Post
    It doesn't drain all of it, but quite a bit.
    http://www.audipages.com/Tech_Articl...placement.html
    08 S4- Stock SOLD
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    PM me your email address and the year/engine/trans of your car and I'll email you the instructions from Bentley. They are not difficult to replace but you need a few special tools.
    If you change the fluid it takes just under three liters.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Apr 20 2007
    Lander, Wyoming
    Quote Originally Posted by mholme View Post
    That's not how it's done on a 5speed. There is a circlip that holds the flange, not a bolt. YOu have remove the clip via a plug from the bottom.
    Jon
    go > show
    Ich liebe mein Audi
    Jan 22 2010
    pm sent
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by lookaught View Post
    Yes, obviously that's an A8 with an auto trans, I was more or less trying to show it as an overview and what to expect fluid wise when the seal comes out. They're all the same, have been for 25 years, but yes, the model in question does use a snap ring on the flange.
    EDIT: Looks like he does have a 5spd auto, so he would have the bolt if I'm not mistaken. Either way, that's the generalized job that I linked.
    08 S4- Stock SOLD
    Apr 20 2007
    Lander, Wyoming
    Yeah I double checked and for the A4 auto trans it is the same procedure as the A8 that you linked.
    For the archives:
    Auto trans:
    Torque is 25Nm for the center torx that holds the flange.
    23Nm for the head shield bolts
    55Nm for the driveshaft to the flange with blue loctite. It recommends replacement of the bolts however I never did this and have had no issues over the years.
    Fill the trans slowly to allow the fluid to move... so fill, wait a few min, fill again, wait a few, etc.
    For a five speed (or six I imagine) use this:
    http://www.audigeeks.com/forums/index.php?topic=3079.0
    The only torque spec is the 55Nm for the driveshaft bolts.
    Jon
    go > show
    Ich liebe mein Audi
    Established Member Two Rings amrcnv8's Avatar
    Jan 23 2010
    1991 Audi Coupe (AAN swap), B8.5 S4, 4M Q7 Prestige
    Hawthorn Woods, IL
    Quote Originally Posted by cjs 928 View Post
    I got my DVD from Bimmerzone.com recently for $80. Not super impressed with the way they have the info organized or how little info there seems to be, but since there is not a Chiltons or Haynes manual for these cars, it will have to do.
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    Quote Originally Posted by amrcnv8 View Post
    agreed, i got mine from amazon.com for $40 (i had a 40 dollar gift card). the manual isnt quite as detailed as i expected and its not organized very well.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    Apr 20 2007
    Lander, Wyoming
    All the info is there it's just tricky to sort through it. Once you get used to sifting through you can find almost everything. It is made for professional mechanics not diy'ers
    Jon
    go > show
    Ich liebe mein Audi
    Jan 23 2010
    Hawthorn Woods, IL
    Sorry, didn't mean to hijack the thread! I've spent some time, but I'll keep looking to get more familiar with it. I have found most of the instructions but haven't found the description of the codes from the computer yet.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    The center diff/transfer case only takes 0.8L.
