Results 1 to 28 of 28
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Auto-Dimming Mirror Retrofit Information and DIY (long)
    The auto-dimming mirror was offered on some A4’s, but has proven to be a popular retrofit modification for many. However, despite the popularity, I found it very difficult to find accurate and understandable information on the subject, so I decided to create a huge thread filled with everything I learned, plus a DIY, so hopefully this will help people out in the future.
    First off, you need to buy an auto-dimming mirror. There are two basic types, one with a power button and one without. Both work the same way and include a compass. I chose the non-power button one. They are for sale in the classifieds quite often (which is where I bought mine), ranging in price from $70-$100, depending on condition and type. When you buy your mirror, make sure it includes the big mirror piece (part number 4Z7857511), a felt backing pad that goes against the windshield, and the little cover piece that hides the wires (part number 4B9857593). Note that the part numbers listed are for the satin black, non-power button mirror.
    The next piece of information concerns the mounting of the mirror. If you have the little flip down dimming mirror now, the mount on the windshield should be the same mount as the one required for the auto-dimming mirror, so it should just pop on (mine did, as did several other people I spoke to). The other big concern is getting power to the unit. There are a few different ways to do this. First, check in the headliner (in front of the sunroof controls; you’ll have to take this down to see in) and determine whether or not you have a connector for the mirror (I did). You’ll have to look hard and poke around; it’s not clearly visible (I noticed mine well over a month after I started the project). If you have this, great! Fish it out. If not, then you need to move on to option #2 (or the easier option if you want the power and ground source locally). You can either buy the end of a harness that came out of a car with auto-dimming mirrors (this is what I did initially), or just tap lines for power and ground at the sunroof control panel.
    So off to the write-up. As a disclaimer, this is strictly for informational purposes only. I take no responsibility if you work on your car and break something. Use common sense. It’s not a very hard DIY to do once you’ve figured everything out (which is why it took me a month). Doing this from start to finish should take less time than it took me to do this write-up (~2 hours).
    In addition, all the tools listed are not necessary. I’m merely including the tools I used. This entire process took well over a month to do, so there were a few different variations. And yes, the pictures are taken at different times/places with either a crappy P&S or my BlackBerry camera, neither of which takes good photos.
    Parts Needed:
    Auto-dimming Mirror: 4Z7857511
    Wire Cover: 4B9857593
    Felt Pad: No part number listed in EKTA
    Wire Harness from another A4/S4
    Wire Taps/Splicers (available from Radio Shack, etc.)
    Fuse Taps
    Extra Wire
    Electrical Tape
    Tools Needed:
    Something with a flat blade (butter knife, etc)
    Phillips Head Screwdriver
    Flat Head Screwdriver
    Wire Strippers
    Multi-Meter
    Needle-nose Pliers
    Channel-lock Pliers
    Ratchet w/ 8mm socket
    Paper Clips
    Flashlight (or something similar)
    Before:
    Step 1: Grab hold of your non-auto-dimming mirror and rotate it counterclockwise to release it. It takes some pressure, but be sure to apply the pressure firmly. Once the mirror pops off, set it aside.
    Step 2: Wrap a towel around the mirror base (the beige thing still on the windshield). Take the channel lock pliers and grab onto the base and twist it counter clockwise. Be very careful to keep even and steady pressure so that you don’t break the windshield (not sure if it’s even possible, but better safe than sorry). Once it’s off, set it aside.
    Step 3: Put the felt piece (the one that goes against the windshield) so it slots in behind the mirror. You’ll see how it goes.
    Step 4: Look at the metal attachment point on the windshield in relation to the receptor piece on the auto-dimming mirror. It goes on the same way the old mirror came off, except the base and mirror are one piece instead of two. This means you will have to put the mirror on at a 90 degree angle and then rotate it clockwise to engage it in place. It’s fairly straight-forward. Take the harness that’s coming from the mirror and click it into the tab thing.
    These first four steps are generic to either of these two write-ups. However, it branches off here. The first part it assuming that you need to create your own power and ground in the sunroof controls. The second part assumes that you have the mirror harness already in the headliner. You will only need to follow one or the other. I had the harness in my car already, so my apologies if the details on the “create your own” DIY are a bit sketchy.
    Step 5: Use the butter knife to release the two tabs on clear, plastic map light cover. There is a tab on each side. Then use the butter knife to release the beige plastic surround that covers the area around the individual map light buttons. Next, remove the two Philips head screws towards the front of the assembly (if you’ve never done this before, look directly up underneath everything and you should see them), and remove the assembly. Disconnect all the connectors, but remember where they go!
    Step 6: Locate which wires on the connectors have power. They vary from car to car. I found that on mine, the grey sunroof connector had power going to Pin #1. A good test is to locate a ground (any bolt on the roof should work), and use a paper clip stuck into the Pin slot to test with your multi-meter (straighten the paper clip out and stick it in the hole at the location you want to test). Put the multi-meter’s ground pointer on the ground and touch the power to the paper clip. You’re looking for a reading somewhere around 12V on the multi-meter.
    The wires on the mirror that you need to concern yourself with are Pin’s #1 and #2. Pin #1 is power (white wire) and Pin #2 is ground (black wire). If you have a harness from another car, the wires on that harness are also Pin #1 and Pin #2, but Pin #1 is a black wire with a blue stripe (power), and Pin #2 is a brown wire (ground).
    Step 7: Either plug the harness from a parts car into the mirror harness and splice the wires, or splice extra wire in to make the connection. When you turn the car to the auxiliary position, the mirror should power on. If so, use the electrical tape and tape up all the connections, reassemble the sunroof switch, and pop the wire cover piece on the mirror. You’re done!
    If you have a harness in the car already, follow these steps (this assumes that you’ve disassembled the sunroof controller/map lights in order to find the harness. If you need help on how to do this, refer to step #5 above):
    Step 5: Fish the harness out and pop it through the front of the headliner. Plug it into the harness coming from the mirror (it can only go one way). Pop the wire cover on. Reassemble the map lights and sunroof controller.
    Step 6: Open the driver’s side door and remove the fuse cover (use a flat head screwdriver and pop the fuse cover off). There are three 8mm bolts that you need to drop the knee bolster. I don’t have pictures of these bolts, but there is one on the steel fuse bulkhead, and two at the bottom of the bolster (near the OBD-II port on the left, and in the same general location on the right). Remove the bolts and wiggle the bolster out. Disconnect the footwell light (it’s a white connector, pull the tabs away from each other and it should slide out) and the OBD-II port (it just pops out), and set the bolster aside.
    Step 7: You will need to remove the kick panel that is next to the dead pedal. Start pulling out and you’ll get an idea of where the clips in the front are. There is another trim piece by the fuse box that you will need to remove first. Remove that. Next, running along the door sill, you’ll see where the trim continues to run from the kick panel (its one big piece). You’ll need to start nearest to the B-pillar and work your way back, as the kick panel needs to pull out from behind the hood release. I know it sounds complicated, but once you start at it the process will make more sense. Everything is held in by clips that take a fair amount of pressure to remove. Set all these pieces aside.
    I don’t have step by step pictures for #6 and #7, but the car should end up looking like this:
    Step 8: This is where you need a flashlight or something like that (since you disconnected the footwell light). You’re looking for an orange T17f harness connector at the left connection station. You’re likely staring at an orange connector. That’s not it. The connector you’re looking for is on the left side of the driver’s side footwell (think of it as being on the left “wall” of the footwell, if there were one). The connector is next to a blue on and a red one (I think). There’s ~20 wires feeding into it. Locate that connector.
    Not this:
    This:
    Step 9: Once you’ve found that connector, locate Pin #3. This is a pain in the ass. I couldn’t get my connector unplugged to give me more room to work, so I had to contort myself to work on it. What you need to do is splice a wire from Pin #3 to a switched 12V power source. Start off by locating the beginning and end points (the beginning point is the wire going into Pin #3, end point is a switched fuse). The wire in Pin #3 should be black with a blue stripe. Take your wire tap and your extra piece of wire and splice these two together. Then run the wire to the fuse box. As an FYI, you shouldn’t need more than 18” of wire to get from point A to point B.
    Step 10: I used the fuse at position #31 (for the reverse lights). It’s a switched fuse, which means it will go on and off with the car (fwiw, I had my radar detector wired in at this fuse…I’ve been told that the 15A will support the radar detector and the mirror). The fuse should be a 15A fuse (15-amp…if you’re running the mirror and the detector off the same fuse, you may want to up it to a 20A, but it’s not necessary). Pull the fuse, insert the fuse tap, connect the wire (there’s a few ways to do this, I temporarily ghetto-rigged it. Don’t leave it how I did), and plug the fuse back in. Turn the car into the auxiliary position, and if you did everything right, the mirror should power up. If so, tape up all the electrical connections.
    This isn’t the right fuse, but it provided power so I could double check everything.
    Step 11: Put the car back together. Enjoy. If you have any questions, comments, or need clarifications, please don’t hesitate to let me know. Big thanks for Minh for the mirror and diagnosticator for all the technical hand-holding along the way.
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Jun 05 2007
    Nashville, TN
    Re: Auto-Dimming Mirror Retrofit Information and DIY (long)
    Thanks for the post! Maybe this weekend I'll take a look at the mirror that's been sitting in my garage for over a year and get it installed!
    ROB
    Veteran Member Four Rings b4a41point8t's Avatar
    Jun 06 2009
    Los Angeles, CA
    Great in depth write up. I'll get around to this soon. I think it's kinda funny tho how much easier it is to do this without having the plug than it is with the pre-wired plug.
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    Quote Originally Posted by b4a41point8t View Post
    For me, after I figured everything out, it was easier using the pre-wired plug, because all you need to do is disassemble the car and splice a wire in. My biggest issue with finding power locally is that all the threads/DIY's about powering devices in the map light region listed different pins, and none of mine actually had power. I only found power 2 seconds before I saw where the pre-wired harness was, and at that point I was like, screw it.
    It seems daunting, but once you get in to it, its not that bad. I tried to explain everything as simple as possible, so if there's any questions, please feel free to PM/email me.
    Jul 29 2009
    Ontario
    Hello there, I have a few questions regarding the installation of the auto-dimming mirror and the rain sensor.
    First off the dimming mirror.
    I bought the harness form Kufatec and it comes with instructions, but it doesn't really show where to find the connectors I need to splice into and the instructions provided are different form the ones above. My questions are with regards to the instructions provided:
    1. Black line - Solder or crimp protection on S5 (ignition plus KI.15)
    - Where do I find S5 (ignition plus KI.15)? I need to know connector colour, pin number and location please. If anybody know where to find it... Can this be found in the overhead console where the blue tooth mic and reading lights are? Can I use another connector with KI.15 instead??
    2. Brown line - Ground A column driver's side behind lining.
    - I could use that one, I could also use the one on the passenger side; but, is there a ground connection point on the overhead console I could use? Or what wire from the overhead console is ground (connector and pin number) so that I can splice into it?
    3. Blue/Red line - Solder orange plug driver floor space at pin 9 (RF signal).
    - I think this one goes with the instructions on Step 8 above.
    4. White line on - plug interior light pin 1.
    - How many pins does the interior light plug have? Can I find this in the overhead console? Anybody have any pictures of this?
    5. Black white line - Orange plug at pin also solder 7 on Black line becomes green - Orange plug at pin also solder 8 on Black and white and black green only with auto dimming outside mirror
    - What the heck does the line above mean?!?!?! I guess it lost a bit in the translation from German. Is the orange plug they refer to the same plug as in number 3 above?
    Now the rain sensor
    I know the three connections the sensor has relate to these:
    Pin 1 > fuse box (spare fuse)
    Pin 2 > Earth
    Pin 3 > F3
    For pin 1, what kind of power does it use? KI.15 or KI.30? Where can I connect it in the overhead console (need plug and pin number for map reading lights (don't have sun-roof)).
    For pin 2, I would use the same ground I would use for the auto-dimming mirror connection.
    For pin 3, Where the heck can I find F3 (plug and pin number...)
    I'll figure out the coding myself after the install is done.
    Dec 22 2009
    Piscataway, NJ
    Our installs are quite different...I tapped into the harness that was already in the car, and all I had to do was connect power to the block by the drives side footwell. I looked around at trying to tap into power locally and came up with nothing. I would double check and see if you have a harness in the car first...that will make your life a lot easier.
    As for the rain sensor, I didn't think our cars came with one, so I'm not sure how to proceed with that. I know B7's were available with them...might want to ask there.
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Thats bad ass DIY. Good job
    Established Member Two Rings cosmokramer's Avatar
    Jul 10 2010
    '02 Audi A4 1.8TQM
    Glendale, CA
    Two quick questions:
    If I already have this autodim mirror, does that mean that I have the rain sensor also? Or does is there a mod to get that working?
    Second, is this the same mirror that is required to get the "coming home" feature enabled on cars that did not come stock with it?
    Jul 29 2009
    Ontario
    Sorry, I forgot to mention that my car is a B7. I know some B7s come with the socket already to plug in the harness but mine doesn't have the the connector. Could be because it doesn't have a sun-roof? I will look into the footwell tonight or to morrow to see what I can find about the orange plug and will go multi-tester crazy on the overhead console and see if I can find a power cable. As far as to connecting it to the map reading lights, I still have to figure that one out...
    If you come across something, Matt, please do let me know.
    Jul 29 2009
    Ontario
    Ok, I installed the harness last night with the exception of the side dimming mirror connections and the reverse signal connection. There is no wire at pin 9 or at pin 3of the orange connector. Can somebody with elsawin give me the appropriate pin for the backup light on a B7? Any help is appreciated.
    Cheers.
    Dec 22 2009
    Piscataway, NJ
    Quote Originally Posted by cosmokramer View Post
    Not necessarily. IIRC, you could have an autodimming mirror without the rain sensor, but not the other way around. To get the rain sensor working, I think there's a different autodimming mirror, plus (on some cars) there are modifications to the wiper stalk that need to be made.
    And yes, same mirror AFAIK. Granted, you need a lot more to get the coming home thing working. There's a DIY writeup somewhere on it...IIRC the rest of the parts were fairly expensive.
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    Does anyone have spare parts or part numbers for: felt that goes behind the J-hook and the connector/wiring that comes from under the roof liner?
    FS: Audi TT 225Q Roadster
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Does anyone know how to get the rear view mirror and the side mirrors to communicate (auto dim)? I just bought a set of S4 mirrors and I'm hoping to get them fully integrated with auto-dim, and I have read that is dependent on the rear-view mirror.
    Veteran Member Four Rings Duchenbagen's Avatar
    Feb 29 2004
    ATL/FLL
    When you put the car in reverse does the auto-dimming feature stop working? Thats the way the factory units work.
    John
    USP CLUB MEMBER #5
    How much does the illusion of integrity cost?
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by Duchenbagen View Post
    I don't have the mirrors installed yet. Although I am 100% sure dimming won't work unless you have a properly fitted rear-view mirror, as that's where the only dimming sensor is. So, I am wondering if perhaps the existing wiring is there, as some have stated (I.e., if I have the harness, is it wired all the way to the side mirror modules inside the doors (on the window regulator).
    Aug 26 2005
    Quote Originally Posted by PNW Avant View Post
    Wiring must be added between the driver's door control module and the passenger's door control module, to control the outside dimming mirrors from the inside auto dimming mirror light sensor. Basically the outside mirrors are slaves to the inside auto dimming mirror.
    Vorsprung durch Technik
    Aug 26 2005
    No. The dimming signal wire to the left and right door control modules is not present, and must be added.
    Jun 08 2008
    Calgary AB Canada
    Boo. Is this difficult to do? I was going to tackle it this weekend
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Aug 26 2005
    It's harder to do than most wiring retrofits, because the wire must be run through the door jambs, through the rubber boots. Otherwise, it's not hard to run the wiring under the dash from left to right side. You should check the wiring diagrams, and compare your harness to that. My '03 did not have the dimming control wiring installed, but the basic wiring harness for the inside auto dimming mirror was already installed. For the dimming signal wires to the door control modules, the correct repair wires are also needed with the specific wire terminals pre crimped onto the repair wires, to fit into the harness connectors at the door control modules.
    Jun 08 2008
    Calgary AB Canada
    Fortunately I have a donor car with all the appropriate wiring harnesses so I plan on splicing them in before the door jamb connector and using the door wiring harness from the donor car
    Stock. For now...
    May 29 2014
    Vancouver
    this was one of the most useful DIY's I have seen to date. For anyone planning on doing this upgrade I found the wiring harness for my mirror in the dome light assembly. It was plugged into the vent looking part of the overhead dome unit. When I unplugged it, there were no pins or metal contact points. Using that information and the fact it fit into my new mirror I decided to use that part of the harness. Spliced in my power under the kick panel and boom the mirror lit up. Thanks 100000000000 Great writeup.
    Jan 16 2014
    United States
    Will try soon
    Nov 15 2011
    Montreal | I sell in USD
    Oups
    *****I sell in USD*****
    Nov 15 2011
    Used this diy to connect my central compass & auto dimming mirror and it made it easy. However im now trying to get the S4 sideview mirrors I installed to dim when the central mirror dims but had no luck with my research so far.
    If anyone as already done this, I could use the help.
    Ty
    Nov 15 2011
    So I finally got the sideview mirrors to work and made a DIY for those wanting to do it too.
    Auto dimming side view mirrors
    This is for B7's.
    B7's came with the driver door connector pre wired but unfortunatly it seems the B6's didnt. On a B6 you will need two 000 979 131ea repair wires (4 ends total) since your will need to insert them into both T10e (two ends) and T10f (Two ends)
    T10e is the driver 10 pin connector and t10f is the passenger 10 pin connector.
    Veteran Member Four Rings ballinb5's Avatar
    Jan 16 2011
    CA
    Do these two wires on the side mirrors mean I am pre-wired for it? It looks like it would be heat and auto dim switch. I have non dimming/non heat side view mirrors and center rear view.
    2021 SQ5
    2008 A4 Avant 6 speed
    Senior Member Two Rings arankaspar1's Avatar
    Feb 20 2018
    Oakland CA
    Quote Originally Posted by ballinb5 View Post
    Did you figure out what these wires are for?
    Feb 27 2011
    Winnipeg
    the wires with the red caps are for heated mirror glass, auto dim has a 2 wire black plastic connector
