Hello guys. I have encountered similar problem today. I can't open the trunk with my remote or the switch on the trunk. The only way to open it is with the key. I have checked the system and found something that has never posted by anyone so far.
As an initial check, I tested the mechanical parts and everything works okay. Then I go to the actuator. I took it out and reconnect to the wire. I found that if I leave it for a few minutes, the actuator will pull back all the way to the end, hold for half a second and come back out to normal position. But if I press the repeat the action, the actuator will pull back about 80% and immediately back out. Repeat again 50% out and back. Repeat again 30%... and eventually nothing happen. If I leave it for another few minutes, it is able to do a full range again. I manually push the actuator in (when unplugged), what I feel is that this is not a solenoid. It is in DC motor with gear and is spring loaded. When powered, the motor turn and pull the lever in. When power is out, the spring bring the lever out again.
With the actuator unplugged, I measure the DC voltage from the plug. When I press the switch or remote, the voltage jump to 18V and drop to 12V very quickly, and then back to 0. If I repeat, the time interval from 18V to 12V to 0 is shortened. After repeating the process several times, the voltage just go up and jump back instantly.
My assumption is: the problem that I have is not from the latch, the actuator, or fraction. There is something wrong with electronics. I believe the "hold" of the voltage is done via a capacitor somewhere that store sufficient charge. When the remote or switch is pressed, the capacitor release sufficient charge to power the actuator. The actuator will pull the lever all the way in. When the charge are all released, the spring on the actuator bring the lever back to normal position.
If the capacitor assumption is correct, then I may have a dying capacitor that cannot normally charge, or a bad resistor that significantly slow down the charging process.
How to fix it? So far I have no idea. I couldn't find any hints or information on the internet to pin point this problem. I also couldn't find useful information from the service manual.
