Originally Posted by
2manytoys
Well done MP. I'm due back on the Dyno in April.
Arthur, I've been thinking about the 3000-8000 test. I even did a couple today. Do you run at 3000 and then plant your foot and hit the timer at the same time, or do you start at a lower rpm and hit start as you cross the 3000 rpm mark?
Also, the time between 6000-8000 is not even 2 seconds, so lets say you are 10% down on HP at 7000, not knowing the maths, but wouldn't that only be 0.2 second difference at the most. Therefore 8 seconds could be 8.2 in a "good" car or 8.4 in a bad car. I'm asking a serious question, because one of my runs were 9.4 the other 8.8.
PS: MP's carbon was not that bad, so I'm shocked he lost as much as he did. It does highlight what carbon does at the top end regardless of the actual numbers (just the shape of the graph).
Mal.
I start at 2000 and press the pedal so it's 100% at 2500 or so...
if you were down 10% power at 8000 or an average of 5% from say 4000 to 8000 I would expect a 1/2 sec difference...
9.4 is way out of range
I've got a database of 34 cars so far, over 150 runs (3rd gear, timed 3k to 8k)
average is 7.9
tossing out the 5% hi/low 8 flat
tossing out the 5% low only 8.1
the highest run is 8.5, and he ran better once he got the hang of it, start at 2000, start timer at 3000
magazines (avg of 4) got 8 flat using the gears for the same speed range
factory, mag and misc dyno times for 3rd gear 3-8k (36 to 96 mph) 8.4 sec
no discernable difference between cleaned or hi vs low mileage...
a couple of other things...
can you 'feel it'?
let's say your average accel is 5% faster, and your avg from 5000 to 8000 is 0.8 g...that's pretty high, lower gear...a 5% difference would be 0.04g, imo, no one could feel that, not even a fighter pilot...
how is the car driven? you get best accel from 4000 to 6000 or so, highest torque since the driving thrust = T x gear rations
HP only helps for high spped sustained runs, ie, top speed
this car has such a wide torque band, hi speed operation is not a big factor, as proven by my bunch of 3rd only runs ~8 sec vs the mag tests using ALL gears of 8 sec, almost no difference between shifting or not
my M3 has 145k miles, 4000 hours of operation, redline 8000
how much time has it spent >7800? 51.3 sec in 4000 hours
how many events > 7800? 231, about 2/10ths of a sec average...
real world driving, back roads, or track, if you keep these cars on a 'boil' 5000-6000 range, you will be flying...
iirc the BMW M3 time Ring runs avg gear is 3rd, with some 4th, and avg rpm of 5800 rpm, I have the telemetry at home, very few gear changes, I was surprised...
I PERSONALLY don't believe that deposits cost HP, in large part due to my data (more tests please :) ) but regardless, we need to put these numbers in perspective...an 8% difference, if accurate, is not substantial, going from 80 to 40F will have ~ the same impact...or driving at an atl of 1500' vs SL
I'm out of this debate...I will wait and see what Audi does, seems like they are on the case, and until then just enjoy my car...
do some more runs...9.4 is really bad...8.8 is also not good...if functioning correctly imo 8 to 8.5 depending on EL, temp, wt, etc.
