Results 1 to 13 of 13
    Feb 17 2004
    Liberty Hill, TX
    Strange squeal/squeak when pressing brake pedal
    I recently noticed that when pushing on the brake pedal while already stopped, I can hear what sounds like a squeaky spring being compressed. It's coming mainly from the front right side, but is also somewhat audible from the left as well. It doesn't sound like squeaky pads (Hawk HPS, installed with anti-squeal gel on back of pads), but I'm not sure what else it could be. Thoughts?
    edit: added audio clip below. sound is audible from the 10s-20s mark
    MP3 clip
    TIA
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    Re: Strange squeal/squeak when pressing brake pedal
    Its just the flux capacitor activating. It needs warm up time before you reach 88mph!!
    Gcc's blacksheep
    May 19 2009
    Alabama
    No but seriously.. Im trying to look up somethings to help you out, but im finding nothing.
    Gcc's blacksheep
    Feb 17 2004
    Liberty Hill, TX
    added audio clip to first post above
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    Sounds like the caliper is getting stuck or being difficult to move in the body... IDK, stumped on this one.
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Feb 17 2004
    Liberty Hill, TX
    bump, anyone? I'll take a closer look at the calipers today while I'll throwing on my COs :)
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    What brake fluid are you using? Is this a noise that's heard inside the car, or is this coming directly from the front brakes outside?
    USP CLUB MEMBER #34
    Dec 09 2008
    Wisconsin
    That sounds horrible... I have a slight squeak coming from the pedal area when I pump them, but it's nothing like yours (which I'd classify more as a creaking). I just assumed mine was from the piston being pushed in on the master cylinder.
    Spiff, no help
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    you have the ST-40 right?
    I would say take a look at the dust seals and see if they are OK. If they are torn they could be letting in brake dust and dirt which would make the piston seal dry up and could cause a squeak like that.
    I would also check the TQ on the caliper bridge bolts and the carrier bolts, just to be sure.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by CyberPMG View Post
    Valvoline DOT4 synthetic. Noise is coming from the wheel well, not the MC
    Quote Originally Posted by MikeWire View Post
    yup, ST40s. I'll take a look today and update the thread later. Thanks for the input.
    May 19 2009
    Alabama
    The brake fluid has to be a mineral based fluid. Im not sure of the valvoline is or not..
    Gcc's blacksheep
    Mar 08 2007
    Air and water
    SATX
    Quote Originally Posted by schmally View Post
    You might be confusing the power steering fluid with brake fluid - any DOT 4 brake fluid will work in any system requiring DOT 4.
    Audi PS system needs to have a mineral based VW/Audi fluid, not generic PS hydro fluid.
    -Mike
    @countdowngarage
    Feb 17 2004
    Liberty Hill, TX
    I took a look at the seals today and there wasn't any obvious signs of damage, but it could just be it wasn't visible. I cleaned/re-lubed the back sides of the pads without any improvement, so I'm guessing a rebuild is the next step. The noise is definitely coming from the caliper.
