Results 1 to 40 of 44
    Sep 17 2005
    Fremont, California
    034Motorsport - Introducing B7 2.0T FSI Lightweight Flywheel & Clutch Packages
    034Motorsport is proud to present new lightweight flywheel and clutch packages for the B7 2.0T FSI Quattro!
    Our new aluminum flywheel was designed for enthusiasts looking to replace the failure-prone dual-mass flywheel with a lightweight unit for superior throttle response, and more precise clutch engagement.
    The 034Motorsport LWFW for the B7 2.0T FSI Quattro is designed to accept Sachs, Southbend, or Spec 240mm clutch kits for the Audi Coupe Quattro, which provide excellent holding power and driveability at an affordable price.
    • CAD engineered and CNC machined in-house from billet aluminum.
    • Features replaceable steel friction surface.
    • Weighs 12.2 lbs. - Over 11 lbs. lighter than stock!
    • Compatible with all 240mm clutch kits for Audi Coupe Quattro.
    • Flyhweel & clutch packages supplied with OEM quality throwout bearing, clutch alignment tool, and all necessary hardware.
    FAQs about the 034Motorsport B7 2.0T FSI Quattro Lightweight Aluminum Flyhweel:
    - Can I use this flywheel with stock clutch kit?
    No. However, it is compatible with all 240mm Audi Coupe Quattro clutch kits from Sachs, Southbend, and Spec. These clutches are very affordable, and offer excellent holding power and driveability.
    - Will I gain many horsepowers with this flywheel?
    No. However, you will have a much faster revving motor and experience superior clutch engagement.
    - Dear 034Motorsport, I get nervous in social situations, will this flywheel help?
    Yes. Just purchase a platinum chain along with our flywheel, and wear them around your neck, Flavor Flav style. You'll be the life of the party wherever you go!
    We are now organizing a pre-order special. Production flywheels will be machined, assembled, and ready to ship in approximately 2 weeks. Send me an email or PM to get on the list.
    Please take a look at the different clutch options below.
    Sachs
    This package is ideal for stock turbo or S3 K04 cars, and maintains butter-smooth engagement while providing increased holding capacity over stock.
    Includes:
    • 034Motorsport Lightweight Flywheel
    • Sachs heavy Duty Pressure Plate
    • Sachs 240mm Clutch Disc w/ Full-Face Organic Friction Surface
    • Sachs Throwout Bearing
    • Pressure Plate Bolts
    • Flywheel Bolts
    • Clutch Alignment Tool
    This kit offers all the benefits of having a LWFW without any of the drawbacks often associated with performance aftermarket clutches. I have personally used this setup on my daily driven K04 B7 2.0T FSI (putting down ~300WTQ) for over 12,000 miles.
    Retail: $795
    034Motorsport Pre-Order Special: $725
    Southbend
    This package allows you to combine our 034Motorsport LWFW with your choice of Southbend clutch packages.
    For more information about the different Southbend Clutch Stages, please click here: http://www.034motorsport.com/product...ducts_id=13902
    Includes:
    • Southbend/Sachs Pressure Plate (Stage 1-5)
    • Southbend 240mm Clutch Disc (Stage 1-5)
    • OEM Throwout Bearing
    • Flywheel Bolts
    This kit is ideal for those who have modified cars, and are familiar with aftermarket clutch options.
    Stage 1 - HD - Retail: $765
    034Motorsport Pre-Order Special: $705
    Stage 2 - TZ - Retail: $815
    034Motorsport Pre-Order Special: $745
    Stage 3 - OFE - Retail: $875
    034Motorsport Pre-Order Special: $795
    Stage 4 - OFE SS - Retail: $975
    034Motorsport Pre-Order Special: $895
    Stage 5 - FE SS - Retail: $1055
    034Motorsport Pre-Order Special: $945
    Spec
    This package allows you to combine our 034Motorsport LWFW with your choice of Spec clutch packages.
    For more information about the different Spec Clutch Stages, please click here: http://www.specclutch.com/products
    Includes:
    • Spec Pressure Plate (Stage 1-5)
    • Spec 240mm Clutch Disc (Stage 1-5)
    • Flywheel Bolts
    Stage 1 - Retail: $795
    034Motorsport Pre-Order Special: $735
    Stage 2 - Retail: $845
    034Motorsport Pre-Order Special: $775
    Stage 2+ - Retail: $905
    034Motorsport Pre-Order Special: $825
    Stage 3 - Retail: $885
    034Motorsport Pre-Order Special: $805
    Stage 3+ - Retail: $1025
    Stage 4 - Retail: $895
    034Motorsport Pre-Order Special: $815
    Stage 5 - Retail: $1025
    Feel free to email me or send me a PM if you have any questions.
    Jun 05 2007
    Phillips Ranch, CA
    Re: 034Motorsport - Introducing B7 2.0T FSI Lightweight Flywheel & Clutch Packages
    Looks good.
    Veteran Member Four Rings bez101's Avatar
    Oct 06 2009
    sheffield
    hom much for full kit stage 3 for fsiT 2.0 fwd
    delivered to the uk
    southbend
    and LWFW
    Oct 12 2009
    are these for FWD as well?
    2015 Audi A3 TDI
    1971 VW Squareback
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by acidrome View Post
    Looks good.
    Quote Originally Posted by bez101 View Post
    delivered to the uk
    southbend
    and LWFW
    PM Sent!
    Quote Originally Posted by colt45 View Post
    ETKA shows the same part numbers for the FWD and Quattro flywheels and pressure plates, with different part numbers for the clutch discs.
    Fitment should be the same for both FWD and Quattro cars, just like it was for the previous generation Audis. However, we haven't had a FWD car in here yet to confirm 100%.
    Veteran Member Four Rings viperdsa's Avatar
    Aug 28 2007
    Angry Gerbils
    west of the equator
    Is there any chatter with the lwfw?
    '06 Dolphin Gray A4 2.0T
    Motoza Tuned EFR
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by viperdsa View Post
    I don't get any chatter in my car.
    Veteran Member Three Rings jayuuey's Avatar
    Aug 22 2007
    SF Bay Area
    Quote Originally Posted by Laszlo@034 View Post
    [INDENT]Yes. Just purchase a platinum chain along with our flywheel, and wear them around your neck, Flavor Flav style. You'll be the life of the party wherever you go!
    can you bundle the platinum chain in the deal for an even better preorder price?
    seriously though, thanks for releasing more great stuff for the b7 community!
    Jay
    Current: Ibis White A4 Avant S-line TI 2.0T MT6 (JHM STS, Unitronic Stage1)
    Sold and quickly forgotten: 09 Forester XT Limited
    Sold and will be missed: A4 2.0T Quattro, 6-speed manual, APR Stage 2+
    (old) norcal audizine GTGs, etc. http://www.flickr.com/photos/jayuuey/sets/
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Quote Originally Posted by jayuuey View Post
    No Joke!
    Stage 4 OFE FOR ME!!
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Issam@034 View Post
    No Joke!
    For you the price is $1,695.
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    WOW, i was actually thinking about a clutch upgrade when i leave this tiny little K03. :)
    '08 Brilliant Black B7 A4 w/ DTM Conversion Stage 2+ - Sold
    '14 Midnight Blue Allroad Premium Plus w/ Nav & LED Package - Sold
    '13 Ford F150 XLT - Current
    '14 Glacier White Q5 Premium Plus - Current
    '08 Ibis White B7 A4 Titanium Edition Stage 1 - Current
    -Steven
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    this is awesome. the clutch/lightweight flywheel upgrade was one of the best mods i did to my IS300. i'll definitely have to consider this mod in the future.
    Feb 26 2006
    Earth
    SOLD!!
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by AWDTURBO View Post
    It's actually a really nice improvement in pedal feel even on a stock turbo. Not to mention how much quicker the motor revs!
    Quote Originally Posted by p1nk50ck View Post
    You won't regret it!
    Feb 26 2006
    Earth
    bump
    Sep 17 2005
    Fremont, California
    Thank you for the orders!
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Laszlo,
    I think 034 needs to come up with a turbo kit for the B7 that generates enough power that a stock clutch can't hold it;-)
    Then, you will sell a lot more of these...
    "Obsessed" is a word that the lazy use to describe the committed.
    Apr 09 2009
    montreal
    bump for great guys, issam are you still on vwsport? any activity there?
    Feb 26 2006
    Earth
    Quote Originally Posted by TheRealtor View Post
    Ye I still am but it is pretty dead there.Most of the guys have either sold there platforms and moved onto to another make or grew up and have a family.You very seldom find people modifying there cars between the ages of 30 & 45....life just takes over.
    Whats up with the red bar? Ill help
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    I just noticed my clutch starting to slip today at 102k so I need to start looking and all of these look real good.
    Sep 17 2005
    Fremont, California
    Thanks again for all of the positive feedback!
    Just wanted to let everyone know that the flywheels are getting done this week, and the products are now live on our website:
    034Motorsport B7 2.0T FSI LWFW & Southbend Clutch Package
    034Motorsport B7 2.0T FSI LWFW & Spec Clutch Package
    Introductory pricing will be available through February 12th, 2010!
    Here is some feedback from a local customer who we did an install for last week:
    Quote Originally Posted by 034Motorsport Customer
    ... I've put about 300 miles on the car since picking it up, and it seems to have broken in nicely! Sorry for hassling you about that; this is my first experience with an aftermarket clutch. The pedal is a bit stiffer than stock, but it feels great. There is no more lurching when I engage the clutch, and the "shuddering" I was experiencing at low speeds with the factory clutch/flywheel is completely gone.
    ... The engine feels a lot snappier and more responsive. There isn't even a hint of the gear "chatter" that I was dreading so much.
    ... I wish Audi had delivered my car like this to begin with.
    Aug 28 2007
    Angry Gerbils
    west of the equator
    I'm assuming that the torque holding capacity stated is at the crank.
    What if you don't know what holding capacity you need, and you end up over what the clutch can hold? Will it just wear out quicker?
    Motoza Tuned EFR
    Sep 17 2005
    Fremont, California
    Yes, the torque capacities are all stated at the crank.
    If you get a clutch kit that isn't rated to hold the torque you plan on making, it will wear out quicker, or never break in properly and continue to slip.
    That being said, all of these clutch kits require a 250 mile break-in at the least, depending on the friction materials used on the disc. Some of the more aggressive discs can require up to 1,000 miles of break-in.
    If need help figuring out torque capacity, just shoot me a PM. If you know what turbo you plan on running, and what kind of driving/racing you plan on doing, I'll have a pretty good idea of what clutch you'll need.
    Sep 17 2005
    Fremont, California
    We are now offering a flat-rate $400 installation service for any of these kits! This is for a limited time only, please send me a PM for more info.
    Feb 26 2006
    Earth
    Right up to the top.
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    With an off the shelf AWE BT, would you guys recommend the HD Stage 3?
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by agkellyboy View Post
    Yup, the Stage 3 is perfect for that.
    Apr 09 2009
    montreal
    not the popular one here lol, never was on none tech forums. i guess i have a bit of a attitude problem at times. Yah i think it went downhill after the hardcore section was removed :(
    Sep 17 2005
    Fremont, California
    Thanks for the orders! 1 week left on the introductory discount.
    Sep 17 2005
    Fremont, California
    Bump!
    Sep 17 2005
    Fremont, California
    The first production run of the flywheels has already shipped out to customers worldwide.
    We just machined up 10 more, here they are with ring gears attached, waiting to be fully assembled.
    In case you're wondering how we make these...
    Our flywheels are developed and validated utilizing state-of-the-art CAD software, then transferred to complete assemblies with ring gear, friction surface, and hardware. This method allows us to know how much the flywheels will weigh, and what they will look like, without wasting materials and machine time.
    The assemblies are once again reviewed and validated, and the machining process begins.
    Each flywheel starts its life as a chunk of billet aluminum, which we mercilessly feed to one of our in-house Haas CNC machining centers. All of the fixtures we use for our CNC machined products are designed to ensure consistent fit and allow our parts to be machined to precise tolerances with every production run. Here is our Time Attack VR6T B5 A4 making friends with the larger Haas:
    Once machining is completed, the flywheel is weighed, hand-assembled by our employees, and then weighed again.
    For all new designs, the prototype flywheel is test fitted, and rigorously tested on 034Motorsport employee and/or shop cars before final release.
    Production flywheels are neatly placed into 034Motorsport packaging, and put on the shelf ready to ship.
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    ^^pretty awesome stuff man!
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Feb 26 2006
    Earth
    Lets bump this up!
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    What CAD software you guys using? Just wondering what the pros use. Im learning with NX at the moment.
    -Ian
    Feb 26 2006
    Earth
    Quote Originally Posted by Vorsprung View Post
    Solidworks.
    Sep 17 2005
    Fremont, California
    We use Solidworks for all of our design and evaluation needs, and SolidCAM to define machining operations. Solidworks is widely used in the industry, and very intuitive and easy to use. It is enough for the overwhelming majority of CAD software users.
    That being said, ProE does have some more functionality, and many government/DoD contractors use ProE exclusively. It's also somewhat more complicated to use.
    Inventor and Catia are two other mainstream CAD programs.
    Most of the features and operations are very similar, which is why a lot of schools start out teaching ProE. I started out learning in ProE, and the switch to Solidworks was a breeze.
    Some fields prefer one software to another, which is why I'd recommend researching the field that you intend to join.
    Feb 24 2010
    Norway
    Hi,
    I couldn't find SACHS for B7 TFSI Quattro on your website?
    Will this kit be just as smooth as a daily driver with stock clutch?
    http://www.034motorsport.com/product...ducts_id=16425
    I have heard that in order to ride smoothly with an aftermarket performance clutch it has to be organic??
    I am by no means a clutch expert, but I wanna make sure I can drive smoothly when getting a new clutch. I will be installing an APR/ATP turbo kit in the car in the near future.
    Regards,
    Morten
    Established Member Two Rings torquewrench's Avatar
    Jan 26 2009
    WA
    Quote Originally Posted by 50morlan View Post
    Hi,
    Organic facing are the best compromise between heat tolerance and smooth engagement. Typically, if you can find a clutch with organic, it is the choice for a daily driven vehicle.
    Sep 17 2005
    Fremont, California
    Hi,
    Regards,
    Morten
    Hello Morten,
    Organic will offer the smoothest engagement, but kevlar and feramic discs aren't difficult to drive at all as long as the disc is full-faced.
    The kit you linked is actually just for a Spec clutch for use with your stock flywheel.
    Our LWFW with Spec clutch can be found here at a much better price: http://www.034motorsport.com/product...ducts_id=19874
    Our LWFW with Southbend clutch is here: http://www.034motorsport.com/product...ducts_id=19871
    If you're very concerned about driveability, I'd stick with a Stage 1 kit. Both the Spec and Southbend Stage 1 kits use an organic friction material.
    However, the Southbend Stage 3 setup is a great deal, and most people love the feel of that clutch.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    is there a different option for the 3.2?
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
