The K03-073 has the 8fin design as the K04 with slightly different specs for the turbo.
The specs of the FrankenTurbo K03-073 turbo are:
- Wastegate Ported from 20mm to 24mm
- Compressor Wheel: 38/51
- Turbine Wheel: 44/40
- "Uprated" Acutator
My Pictures:
At first view the box looks very professional/well thought out and when you open the box and look at the turbo, you can tell this is not a cheap ebay replica. The only thing I wish that the packaging included were some packaging peanuts, as it's only the turbo wrapped in a bag within the box.
When you look at the turbo, you can see marks on the turbo showing that the turbo was clocked by hand correctly, along with the wastegate adjusted properly.
The install went very smoothly (with the help of jrock) and there are no modification needed to the turbo or manifold/cat. Everything lines up properly and works smoothly. The biggest clue for the turbo not being a cheap replica is when you look at the wastegate port and it's not off-center/10-15mm big. I mention that because I know that a AZ member bought an eBay Chinese K04 replica and the wastegate port was 13mm and it was off-center. not to mention that on startup apparently his replica sounded like a dentist drill. This turbo does NOT do any of that, no drill sounds or off center wastegate.
After the install, I have put on 500 miles on this turbo so far and have not had any issues. when comparing to jrocks gpopshop K03/K04 hybrid the turbo pulls just as hard (minus my current boost leak
The turbo is currently running on 91oct GIAC tuning with a slight misfire (due to a coilpack) and the car is running strong. I will have a dyno graph hopefully within the next few weeks. I plan on going with the GIAC K04 file as the specs of this turbo are very close to that of the K04-015.
I'll edit this review at the 1000mile mark on the turbo and after I get the GIAC tuning + dyno graph. But so far, I am not regretting the purchase of this turbo.
On-going Review on VWvortex:
http://forums.vwvortex.com/zerothread?id=4576316&page=1
FrankenTurbo Website:
http://frankenturbo.com/F4h-l.html
