Results 1 to 6 of 6
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Symptoms of a failing dual mass flywheel?
    I recently replaced the clutch and installed a new LuK DMFW on my car. Before I had replaced it I had an intermittent problem that I have not heard since, I am wondering now if it was due to a failing flywheel.
    Basically the car would occasionally make loud clanking/thumping noises from the trans area while under load, and only under load. It didnt matter if it was a light load or heavy WOT, it would clank and I could feel it through the pedals. The odd part is the intermittent nature... I'd hear it during a drive, then the next time I drove... nothing. On and off for about three months, probably five times total. I also heard it right before I took the car apart and once back together, no noise.
    It all started one day when fanning the clutch to reverse out of a parking spot, it was rattling a bit. That rattling just went away for like two months, then the clanking etc started.
    Anyway I am just curious if these are typical symptoms of a failing DMFW. It is a moot point now that I have a new one, but I'd still like to know.
    Thanks for any input!
    Jon
    New v Old. I'm very glad that I replaced it, the clutch is sooooo smooth and never chatters or skips anymore. Clutchmasters CX300 FTW!
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Three Rings rbj325's Avatar
    Aug 12 2008
    Rochester, NY
    Re: Symptoms of a failing dual mass flywheel?
    I am having similiar issue/noises and I came to the same conclusion. My clutch holds fine but there is a "lightweight flywheel rattle" coming from the trans.
    It's funny because when I asked several people if a flywheel can fail they laughed at me.
    E85!
    "I got four cylinders when I need them and four cylinders when I don't"
    Jun 22 2009
    Dundalk, MD
    I just broke mine, issues are like you said, the pedal would almost kick back at my foot in between shifts and things
    Veteran Member Three Rings vacsimile's Avatar
    Nov 15 2008
    2004 Audi S4, 1991 Nissan D21, 2001 GTi VR6
    Outer Space
    I worked on a Jetta that had a broken flywheel, although it was a DSG tranny... it sounded like a diesel and had no power whatsoever. I guess it had broken a while back, because it vibrated so much that it started to slip where the input shaft of the tranny splines into the flywheel, and eventually wore down the splines to look like a smooth, machined surface.
    Jun 22 2009
    Dundalk, MD
    Quote Originally Posted by vacsimile View Post
    wow that's bad... Makes no sense though, were the bolts backed out on it?
    Nov 15 2008
    Outer Space
    Quote Originally Posted by [email protected]. View Post
    No all bolts were tight, but the two pieces of the flywheel had wayyy too much play between them. It's supposed to be pretty stiff and only move radially... this flywheel was loose enough to move around by hand, and not just radially but up/down and left/right, like an eccentric bolt.
