Results 1 to 40 of 56
Thread: rota p45r
    Active Member Two Rings brokes4's Avatar
    Sep 13 2009
    vista ca
    Talking rota p45r
    will the rota p45r in 17x9.5 et30 with 215 45 17 be ok on my b5? thanks
    Senior Member Three Rings poop_on_jdm's Avatar
    Apr 22 2009
    Newport News, VA
    Re: rota p45r
    anything but rotas please..rota's are for hondas. even though those are the best looking wheel they have. it reminds me of volks.
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    Re: rota p45r
    you want a 9.5" rim, with a 215 tire?
    laff
    The Best Things in Life Are Free... Or Heavily Discounted!
    Jul 20 2004
    Re: rota p45r
    theres one set fitted to a nogaro blue S4 on the site and if I recall they were part of a special set of wheels for audi fitment and they would not be produced again unless 10 buyers prepaid.
    Sep 13 2009
    vista ca
    Re: rota p45r
    i found a set on ebay. its a daily driver so i cant see myself buying volks or bbs. will this work is what im asking i dont want to buy them if they wont fit. thanks for the replys
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Re: rota p45r
    they will work with a lot of fender work...
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Veteran Member Three Rings sparkyvw's Avatar
    Feb 11 2008
    B8 avant,964,B5 wb s4, mk2 vr, mk3 vr
    Palm Beach Gardens FL
    Re: rota p45r
    215 on a 9.5 No thanks with these cars.
    Cloud9Helicopters South Florida
    ROTIFORM AIRLIFT
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Re: rota p45r
    Quote Originally Posted by sparkyvw View Post
    haha X2, didnt even see that in the first post.. wayyyy too much stretch
    Mar 13 2009
    Noise
    Re: rota p45r
    et30? i test fitted et20 9.5 rota grids, and that worked for me.
    get ready to pull your fenders tho
    Jul 20 2004
    Re: rota p45r
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Re: rota p45r
    they won't fit. Unless you feel like pulling your fenders and probly painting them then don't even bother.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Re: rota p45r
    Meh, he said they are a 17x9.5 et 30. I have a 17x9 et20 on my car which sticks out further that a 9.5 et30 would. I'm also running fk452's in a 215/45 and they don't even really looked stretched to me since the sidewall is taller than they would be in say a 225/40 on an 18. You would have to look at the inner clearance in this case, I'm not sure if they would clear.
    Oct 08 2008
    MA
    Re: rota p45r
    I have 225/40s on my 19x9.5s. I think I'm going to narrow it up to 215/45s because there is absolutely no stretch and I need a bigger sidewall. I can't get a higher profile rubber in there with 225s.
    I'm pretty sure he will rub on the inside.
    Active Member Four Rings
    Sep 14 2009
    s.e. mass
    Re: rota p45r
    Quote Originally Posted by wdbdy2000s4 View Post
    rub on the inside of what? control arms? wheel well arch/liner? Please elaborate
    Veteran Member Four Rings orttauq's Avatar
    Mar 11 2007
    8V S3
    tri state
    Re: rota p45r
    Quote Originally Posted by poop_on_jdm View Post
    Why, do they become mysteriously triangular shaped if you put them on anything other than a Honda?
    As far as fitment, 9.5 width and a 215 series tire just doesn't make sense.
    Sep 13 2009
    vista ca
    Talking Re: rota p45r
    i dont want 18s or 19s because of the fittment issues and the work you have to do to fit them. i just tought that by going with 17x9.5 or 17x9 et 20 i would had be fine with few issues and less work. i seen a few s4 on here with this size so i know it can been done. is there another wheel that will work? i just like that wide look on the s4. this s4s sure are a pain even to get the right wheels for them. thanks for the replies
    Mar 11 2007
    8V S3
    tri state
    Re: rota p45r
    Nothing wrong with the size if you're up for doing a little fitment work. IMO 17x9 is a great size for wheels on S4's.
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Re: rota p45r
    Quote Originally Posted by orttauq View Post
    It makes sense on a stock bodied s4. You wouldn't be able to fit any wider of a tire.
    I'd imagine fitment issues between a 17 and 18 would be similar. You need to go lower with a 17 to look good since the sidewall is higher...
    Mar 11 2007
    8V S3
    tri state
    Re: rota p45r
    Quote Originally Posted by Gabe. View Post
    What would really make sense would be a 17x8 wheel with a 215 tire.
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Re: rota p45r
    Here is a 215 on a 9. Hardly anything to get your panties in a bunch about
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Re: rota p45r
    ya but the setup in question is a 9.5" wide wheel with a 215...
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Re: rota p45r
    for all practical purposes an additional 1/4 inch on each side won't change the look a whole lot and the fender clearance will be a little better with more stretch
    Jan 29 2006
    b5 s4 stage 3, 4runner
    livermore
    Re: rota p45r
    what brand tire? not all 215's are the same. could work out perfectly or pull the tire a little too hard
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Re: rota p45r
    That is a falken fk452. I know a falken 512 is about .4" skinnier so that would be a different story.
    Feb 11 2008
    Re: rota p45r
    215 on a 9.5
    ROTIFORM AIRLIFT
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Re: rota p45r
    ^ ya i think it looks pretty good, but it isnt practical if you actually drive your car hard.
    Sep 13 2009
    vista ca
    Re: rota p45r
    i dont drive mi b5 hard so do you think this will work
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Re: rota p45r
    Quote Originally Posted by brokes4 View Post
    sure, but you are missing out on the best part of these cars
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Re: rota p45r
    215 on a 9.5
    that looks like a 215 on an 18x9.5 not a 17x9.5. as long as you have the clearance you should be able to drive just as hard.
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    Re: rota p45r
    omg. stretch is fucking gay. a 225 on a 9.5 will need to be filled up 2-3 times per week. thats annoying
    whats more annoying is you look like a beaner-truck. stretch it just enough to fit so your car doesnt handle like a mack truck w/ those tiny tires
    /rant
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Re: rota p45r
    Quote Originally Posted by sdoherty_tjm View Post
    /rant
    Wat?
    215's or 225's will basically act the same whether they are on an 8 or 9. You aren't going to need to continually fill them with air either.
    For those of you that are wondering what a particular tire brand/size will look like on a certain width/size wheel go to www.tyrestretch.com
    Veteran Member Four Rings audi til I die's Avatar
    Mar 04 2008
    IL
    Re: rota p45r
    /rant
    Actually, stretch on some set ups is quite sexy.
    I've ran 225's on 9" rims. Didn't even poke. 215's you might be getting poke then, but still not as much as some VW guys. 452's are also liquid.
    And horrible comparison of using Mack trucks for handling as they're far better than Petersbuilt
    Oct 20 2008
    fuck off
    Re: rota p45r
    Wat?
    how? difference of 10 mm wider tire wise, and 1 inch wider rim width. 25.4mm=1"
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Re: rota p45r
    What are you asking me? How you won't need to continually fill them up with air? Or how they will still act similar?
    Oct 08 2008
    MA
    Re: rota p45r
    There is more to consider then tire width. A 215/30 will be stretched at a far more radical angel then a 215/45 because there is less sidewall to bridge the width gap. Op, you should be fine with a 215/45 and I don't think you will fit much bigger on a lowered stock-body car.
    Veteran Member Three Rings ZMEY's Avatar
    Feb 08 2009
    B5 S4 Avant A.W.E stg3
    Chicago, IL
    Re: rota p45r
    its up to you, what setup you go with and what look you trying to acomplish, you will need to modify your fenders either way. i would probably go with 235/40.
    Mar 11 2007
    8V S3
    tri state
    Re: rota p45r
    Impossible. If they're flexible enough to stretch, they're not solid enough to not roll over under hard cornering. They won't be similar.
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Re: rota p45r
    I said similar. Not the same.
    I could put the exact same tires that are on my bbs onto my stock avus and you wouldn't be able to tell a difference.
    This is also true.
    Mar 11 2007
    8V S3
    tri state
    Re: rota p45r
    And how wide are your BBS's? That's just not true. You'll have more sidewall if they're installed on stock wheels, and more room for sidewall flex.
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    Re: rota p45r
    215 falken 512's on an 8.5
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
