Results 1 to 28 of 28
    Dec 27 2009
    Orland Park, IL, USA
    Making Auxiliary input (audio) jack work in car with Audi Interface only ?
    I bought the 2010 Audi A4. it came with the Audi music interface in the dashboard. No separate audio jack input!
    Problem is, I dont carry my ipod around much in my car. I used to have all my mp3 songs in my phone (palm pre) and preferred that in my previous vehicle since I have it mounted on my touchstone dock in my car, right next to the stickshift.
    The issue Im having is this : Is there anyway of having some kind of workaround (maybe an adapter or something) that will allow me to plug in my palm pre's auxiliary output (u know, the small audio jack) into my car's audio system so i can access my phone's mp3 library ?
    The music interface came with an SD card input, but i dont use it much, since the limit is only 4 gb (as opposed to an SDHC card) which can go upto 32 mb or higher and so have access to a lot more songs.
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    Re: Making Auxiliary input (audio) jack work in car with Audi Interface only ?
    don't the 2010's support SDHC? I know its been covered so many times I forget what the last conclusion was
    Not too sure about aux input...check the glovebox somewhere, maybe where AMI would have been? (top left of your glovebox)
    Established Member Two Rings T0XiK's Avatar
    Nov 07 2009
    Beijing
    i use an 8gb SD card on my b8 so i dont think the limit would be 4gb
    Jul 10 2009
    northeast
    my aux is in my arm rest. see if its on the wall closest to the radio
    Senior Member Three Rings A4DK's Avatar
    May 13 2009
    Larkspur, CA
    There is an Audi bluetooth adapter that plugs into the MMI interface. You can connect any BT enabled music device to that adapter and play music that way through.
    iamaudi.com has an article about it somewhere.
    The only way to get rid of a temptation is to yield to it. - Oscar Wilde
    2019 Q8 Prestige - Year 1 - Adaptive Chassis - Luxury - Navarra Blue
    Gone but not forgotten.
    2011 A6 3.0T - Prestige - S-line - Sport
    2011 S5 6MT - Prestige - Sports diff - Brilliant Red
    2009 A4 2.0TQ - P+ - Sport - Aruba Blue
    2002 A4 1.8T - Executive - Brilliant Black
    Nov 26 2009
    2002 Audi TT QC / 2010 Audi A4 Avant
    London, Ontario, Canada
    Check with the parts dept at your local Audi dealer. There are a number of adapters that you can use with the port located in the glovebox where your iPod adapter currently is plugged in.
    http://www.audi-collection.com/itemd...=Communication
    Dec 27 2009
    Thanks guys ! Will check out my car and report back in case theres an aux jack hidden somewhere.
    Aug 10 2009
    SD is supported up to 32GB. I've got 16gb class 6 working just fine.
    Oct 27 2009
    Miami, FL | Boone, NC
    Bottom line:
    If you have AMI: there is no separate aux-in jack - you need to buy an adapter that plugs into the ami
    If you don't have AMI: there is an aux in jack in the center compartment under the armrest.
    You can't get both...
    2010 cars (and some 2009's manufactured past a certain date) support SDHC - all others only support SD...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Dec 27 2009
    No aux input in my car, just the ipod AMI cable in the dash. Does anyone have the bluetooth adapter below ?
    Apr 23 2008
    Orange County, CA
    confusing shit lol
    Sep 13 2009
    2010 A4 2.0T
    lol to make it easy...if you have AMI, it replaced your aux input. but you can buy aux cables for your AMI.
    Oct 19 2010
    Boston, MA
    I've jut got myself a cable like this:
    http://www.audi-collection.com/MP3-Cable-for-AMI (#4F0051510C)
    hoping to use it for AUX in, but for some reasons when I go to the "source" in my sound options both AMI input and AUX input are disabled :/ ANy ideas what could be wrong or if I have to enable something else for it to work?
    2010 A4 Avant w/Premium
    Oct 19 2010
    Boston, MA
    Bump.
    Veteran Member Four Rings t0mt0m's Avatar
    Apr 26 2005
    Nothern Va
    any luck? have you looked into vag com codes possibly?
    B6 A4 1.8t 5MT Quattro - Sold
    B8 S4 '10 6MT Prem+ - Sold
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    Quote Originally Posted by Metorn View Post
    I know this is a silly question, but does your car have AMI? If so, under source it does show your 'iPod' when connected, right?
    Veteran Member Four Rings ultra's Avatar
    Apr 12 2007
    13 Allroad
    San Antonio,TX
    yup you need that cable and it should work fine, works for my Droid no problem
    Eurocode
    2013 Allroad Volcano Red, Eurocode goodies
    2018 SQ5 Florett Silver S-Sport package
    Oct 27 2004
    Montreal, Canada
    you've got the wrong cable.
    4F0051510K is what you need for 2010-2011 AMI.
    Veteran Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    Quote Originally Posted by ultra View Post
    You could use your Droid without having to fool around with cables every day,
    this is the A2DP advanced stereo digital interface for non-MMI cars from Audi:
    Audi PN 4F0 051 510J
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Bridgestone RE-11 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI-5mm-Fr+10mm-Rear & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, Seat Bins, Trunk Triangle, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
    Dec 02 2010
    Austin
    Does anyone actually have the A2DP interface working? And does anyone know why it doesn't work with the MMI?
    Nov 17 2015
    dundee
    Hi guys. I'm new here in this forum. I have a audi a4 s line 2010 with audi concert stereo. I don't have a ami port in my car. does anyone here know how can I put an ami port in my car.so I can listen to my iPhone or ipod music through the cars stereo. and also I do have an aux port inside the hand rest area which doesn't gives a good sound quality. is there any way I can change or replace the aux port. please help. thank you
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    man this is 6 bucks on ebay, 75 at the dealership lol
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Mar 01 2017
    Northplainfield
    No Ami in my Audi A4 2009 b8
    Hi guys. I'm new here in this forum. I have a audi a4 2009 b8 with audi symphony stereo. I don't have a ami in my car.I can listen to my iPhone 7 my car does have a Aux would anyone recommend any Bluetooth device that I could get on eBay or Amazon
    Jul 08 2015
    Quote Originally Posted by soccerislife47 View Post
    type audi bluetooth adapter on search bar.
    you have the choice of bovee and tune2air. best of luck
    Mar 01 2017
    Northplainfield
    Which one will show the song information on my car ? While I play the music ?
    Registered Member One Ring monoelk's Avatar
    Jun 21 2017
    Mexico City
    Hi, i just bought the aux cable for the ami in my audi a4 2011, i activate the aux input in the vagcom, but there is no sound when i plug in my cellphone. Anyone knows how to make it work? The car came out of factory with the ipod interface installed, so i have to use the vagcom to activate the aux input.
    Jun 21 2017
    Mexico City
    Hi, I just bought the same cable, and my car have the aux input disabled too, you have to activate it from the vagcom, i just did it, but it didnt work properly. Did you solve it?
    Established Member Two Rings CanadaRed's Avatar
    Aug 26 2013
    London, Ont
    1993 Honda Prelude SR 4WS
    1997 Honda Prelude Base
    1996 Volvo 850 Turbo Wagon
    2010 A4 2.0T Sline 6spd MT
