Results 1 to 10 of 10
    Established Member Two Rings audi_buff's Avatar
    Dec 08 2009
    '02 Black A4 1.8T QT
    Coquitlam, BC
    Case of the disappearing washer fluid
    Something I've noticed since I bought my car is that the washer fluid reservoir is always empty. I can count on one hand the number of times I've used the system and usually it's only to demonstrate the headlight washers (people are curious...)
    I know for sure that I've put at least 8L (approx 2 Gallons) of washer fluid into it since purchase, and the reservoir does fill up, but it drains within 10 seconds. The level reaches the top, I stop filling, and it's like watching a sink empty. No sound, no air bubbles, no leaks underneath, and nothing visible on the ground.
    Is there a secondary (massive) reservoir for the headlight washers? That's the only thing I can come up with. Like I said there is no obvious place where the fluid is going, and watching underneath the car shows nothing. Should I just keep filling and filling it? (I get free fluid @ work so this is not an issue )
    TIA
    **I should note that the low fluid warning never comes on, and there is always fluid when I use the system. Never seems to be dry....
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    Re: Case of the disappearing washer fluid
    the most common problem would be your washer bottle itself, it could very well be one of the hoses going to your headlight washers... you need to look at it very carefully, 8 liters of fluid don't just magically dissappear, they go somewhere...
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    It just has it all in the large area under that one. Just keep putting it in there and it will fill up soon. ;)
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    Or you need to call stephen hawking right now so you can split the nobel prize money for discovering the first microscopic black hole.
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    I thought the same thing man, But i bought a big ass bottle of washer fluid and it took the WHOLE bottle..It takes a lot of fluid, the damn tank is huge..
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    This may not be the case if you're not seeing it drain anywhere, but I have had the driver's side headlight pump crack twice which causes everything to drain out and have no pressure in the system. Luckily I made them fix it the first time for free, but now it's broken again and the fluid drains out pretty much immediately like you are saying.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Mar 27 2009
    Columbus, Ohio
    Quote Originally Posted by OneBadAudi View Post
    I was kinda shocked cause it was dry when I first got my car. It took over one bottle and still wanted more. I can put one that is 20% bigger then normal and fill it that way.
    Dec 08 2009
    Coquitlam, BC
    I keep thinking it could be a leak, but like I said there is tonnes of pressure whenever I do use the sprayers. The car is just COVERED in fluid. And if it was all draining out, wouldn't the low washer fluid sensor be chiming in? It could be broken but I doubt it.
    I'll throw another jug in there on monday and see what happens...
    Quote Originally Posted by IVRINGS View Post
    I had the same thing when I bought it. Looked bone dry. Must hold more fluid than a minivan given how much I've put in though...
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by audi_buff View Post
    TIA
    There's an upper part and a lower part... upper part always looks empty, but the lower bit holds like a gallon. Pretty sure mine leaks a bit too though, and mine also always looks empty. I removed my headlight washers, but I think they tend to leak at the junction between the upper bit and the lower bit I'd guess. Doesn't take long for a little leak to evaporate the stuff away..
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Remove headlights to check their washer pumps. there's probably a slow drip out of the headlight washers. I had the same problem. Apparently when the reservoir was filled it was enough fluid weight to produce enough pressure at the passenger headlight washer seal/gasket to drip. The dripping ceased sometime when the volume was down into the lower hidden part of the reservoir.
    To fix, I grabbed the pump and twisted the bottom around a bit, leaving it at a different angel than what I found. Problem solved.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
