Results 1 to 27 of 27
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Replacing front diff fluid, what's the capacity?
    This weekend is catch-up on some maintenance I'm a few thousand miles overdue for. I'm going to be changing all the differential fluids. Can't seem to find the capacity of the front differential, however.
    And from what I read, it uses the same stuff as the center differential...which is...?
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Mar 11 2008
    B7RS4 & e46Ms
    Re: Replacing front diff fluid, what's the capacity?
    ...They all share the trans fluid.
    FRRG AZ Ring
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    JHM says around 3.5L, so buy 4 and then fill till starts to dribble out. The filler cap is kinda up near the driver axle are too, its a 10mm hex bolt if I remember correctly.
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Apr 24 2009
    Frisco, TX
    Front front needs 3.5qt? Dang. Center supposedly needs a little under 1qt, rear needs 2qt.
    So it's GL-4 or GL-5 in all 3?
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    you must put GL-4 in the transmission/ center diff. GL-5 will wear out the brass parts in your transmission faster. what fluid are you going with?
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Apr 24 2009
    Frisco, TX
    Not planning on GL-5 in the tranny. Just going to grab Royal Purple MTF at the local Autozone.
    The diffs can use GL-4 or GL-5 from what I read. I can get Motul locally but am not crazy about it at $20/L. Can also get Red Line locally. I'll see what AutoZone has.
    Maybe I am getting mixed up here from reading too many threads, but front diff = tranny, right?
    Sep 15 2008
    CO
    Quote Originally Posted by dparm View Post
    The center diff and tranny share the same fluid. Make sure you use ONLY GL-4 for it. Nothing that's both GL-4 & GL-5 approved. I went with Redline MT90 + a quart of Shockproof Heavy. I highly recommend it.
    You should use GL-5 for the rear differential.
    Veteran Member Three Rings justinperkins's Avatar
    May 14 2009
    Q7 TDI | B6 S4 Avant MT | 84 Adventurewagen | 53 Ford Jubilee
    MI
    dude, dparm, get it together man, lol
    for an MT, you want this:
    buy 4 quarts from JHM:
    http://www.jhmotorsports.com/shop/ca...roducts_id=403
    -justin
    Apr 24 2009
    Frisco, TX
    Okay, this is making more sense now. Cut me some slack, long day at work and my mind is shot.
    Manual tranny: 3.5qt (GL4, NOT GL5)
    Rear diff: 2qt (GL4, GL5 gear oils)
    Center diff: <1qt (GL4, NOT GL5)
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Quote Originally Posted by justinperkins View Post
    x2 on this. It really helps in cold temps
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Feb 15 2007
    i'm running Lubro Moly Fully Synthetic gear oil (75w-90) in my tranny.
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Active Member Three Rings tylerS's Avatar
    Aug 02 2009
    nw
    :( you only have your center and rear diff. center takes 3.5 rear takes 1.5.
    Apr 24 2009
    Frisco, TX
    I'm going to a local tuner (Genesis Racing Development) that stocks European Mobil 1 and Amsoil, so I think I'll be set. Thanks for the info, guys.
    Feb 15 2007
    Is this the same for RS4?
    Established Member Two Rings winreboot's Avatar
    Jan 06 2010
    A6 TDI, Q7 4M
    NE PA
    I used Motul 75W90 for the rear. Does anyone have DIY for the front diff? The rear was pretty easy to do.
    Thx,
    Dec 31 2008
    PA
    Lubro Moly site http://www.liqui-moly.de/liquimoly/w...oil_guide.html
    Audi/RS4/4.2
    rear diff:
    · Capacity : Lubicant capacity 0,9 liter
    · Intervals : Check 30000 km / 24 months
    · Products : Hochleistungs-Getriebeöl (GL-4+) SAE 75W-90
    tranny/front diff (Transaxle, manual/transfer box 0A3/1) :
    · Capacity : Lubicant capacity 3,2 liter
    the fluid they recommend for both (same):
    http://www.liqui-moly.de/liquimoly/p...id/e_4433.html
    Feb 15 2007
    Quote Originally Posted by ArthurPE View Post
    Audi/RS4/4.2
    rear diff:
    I've been looking for this stuff for about a year now.....
    Apr 24 2009
    Frisco, TX
    I got the Lubro-Moly engine oil at NAPA, I wonder if they could order their other products?
    Dec 31 2008
    PA
    Quote Originally Posted by zachf88 View Post
    the info or the product?
    product: http://catalog.etyparts.com/item.wws...qty=1&type=ETY $12/liter
    Apr 24 2009
    Frisco, TX
    Christ, that website looks like it hasn't been redesigned since the early 1990s. Woohoo Netscape 4.7!
    Dec 31 2008
    PA
    I'll have to check with them on Monday, that may not be the right stuff, it's listed as GL5, not GL4+
    if you can read German http://www.motoroel-direkt.de/liquim...e75w90gl4.html the right stuff
    looks like someone already asked:
    Thank you very much for your email, dtd. 12th March 2008...
    Years ago, Volkswagen recommended for its transmissions a GL5 gear oil with a viscosity range from SAE 75W-90. But some gear boxes had problems with the synchronisation and consequently (Volkswagen recommended) a GL4+ also with SAE 75W-90 viscosity range. Nowadays (1996+ transmissions (which have black covers)) there is no problem with our GL5 SAE 75W-90 gear oil, and it is better for protection against the wear of the gear wheels. Our recommendation is, if there is no problem with the synchronisation (or in other words if it's a modern transmission) it´s better to use the GL5 oil to protect against the wear.
    With kindest regards from Germany!
    i.A.
    Dietmar ....
    LIQUI MOLY GmbH
    Anwendungstechnik/Application Engineering
    Jerg-Wieland-Straße 4
    D-89081 Ulm-Lehr
    Phone: +49 (0)731 / 14 20 - xx
    Fax: +49 (0)731 / 14 20 - xx
    Mobil: +49 (0)172 / 9 37 36 xx
    great site, good info: http://www.opieoils.co.uk/products-f...ake=vw#results
    May 14 2009
    MI
    They don't do custom ordering of products they do not carry.
    -justin
    Feb 15 2007
    i.A.
    Dietmar ....
    LIQUI MOLY GmbH
    D-89081 Ulm-Lehr
    So I'm good running GL5 in my tranny?
    Sep 15 2008
    CO
    NO. It will eat your brass synchros. GL-4 in the transmission/ center differential only. If you do not trust me, ask Old Guy or Diagnosticator or 'Jeff' (eh), it's a shame you S4/RS4 guys do not have them, they are invaluable assets to our B6 A4 community.
    Feb 15 2007
    Yeah, because I asked about a year ago in the transmission & drivetrain forum and they said GL5 was fine for the transmission. I will look around some more for the GL4+, but if I can't find it, i'll run RL MT-90 with some lubromoly MoS2 for gears
    Dec 31 2008
    PA
    I'll trust Lubro Moly (they are Audi oem approved) and I'll contact Audi and Lubro on Monday...from what I've seen GL5 is fine, but I'll verify that...for myself...Lubro would not put it in writing if they weren't sure...sounds like they were fully aware of the issues...
    the GL5 will afford better wear protection...
    everyone else, do what you feel is right...imo the GL4 was for older VW trannies whose synchros were built with older tech materials...corrosion/binding was the issue
    who builds Audi trannies? Getrag? ZF? or they actually build their own?
    does anyone know what tool is required for the tranny and rear diff?
    can't be as simple as a box wrench (BMW tranny) or hex (BMW diff)
    looks like a reverse 12 point or somthing, not a Torx...
    thanks
    NAPA: just bought two 5 liter jugs Lubro-Moly 5W40 (VW 502/505) synthetic and a Mahle filter for $90 including the tax...not bad...
    Apr 24 2009
    Frisco, TX
    The manual tranny in our cars is Getrag. The auto is ZF.
