Results 1 to 24 of 24
    Veteran Member Three Rings Dillon's Avatar
    Mar 16 2009
    91 mr2 turbo, Honda Ruckus
    Boone, NC
    3.0 Coil pack test numbers.
    Im going to take my coilpacks to autozone and have the resistance tested but what numbers should i look for? and can this mess them up if there not already bad?
    2002 B6 3.0
    "To give up would be to give in to everything I hate." sns
    Nov 07 2008
    2002 A4 Sport 3.0; 2000 Saleen #415
    SE Michigan
    Re: 3.0 Coil pack test numbers.
    Why in gods name go through all that? Just find someone in your area with a Vag or even a good Solus scanner and you can check each coilpack. Way less labor involved. Just my 2 cents!
    Sep 13 2008
    Western Chicago Burbs
    why do you wan to test them? if they work, they work
    Apr 13 2009
    2002 A4 3.0Q tiptronic
    Peru, MA
    What is the purpose of testing them? The coils are a minor pain to pull off on the 3.0, if your car is running smoothly and you have no CEL there isn't much of a point in doing this.
    Mar 16 2009
    Boone, NC
    Quote Originally Posted by mayhem View Post
    My car is not running smoothly and i have a cel..... I have them already taken out and need to figure out which ones are bad.
    2002 B6 3.0
    Sep 13 2008
    Quote Originally Posted by Dillon View Post
    Go to autozone and have them scan the car. Or find someone with VAG COM
    Mar 16 2009
    Boone, NC
    My cel is flashing so its a no go on driving it for now. I just sold my wheels for a decent price tonight so im gonna go ahead and just buy all new ones.
    2002 B6 3.0
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    this how you see which ones work, turn car on pull each coil 1 by 1 to see if engine sound changes. if it changes, its not the one. if it doesnt then thats the one not working.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Apr 13 2009
    Peru, MA
    Checking the codes will tell you which ones are bad because the computer stores which cylinder had misfires. Replace the coils in those positions and you're good.
    You know there is a recall out for this issue and you cna just get it fixed at your local dealer, right? Or just buy yourself a complete new set and sent the bill to AoA. Throw out the known bad one(s) and keep the rest as spares in case you get into trouble again.
    Veteran Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    make sure you keep your receipt! audi is reimbursing as there is a recall on the coil packs
    02 Avant 3.0 // Avant Garde Member // 3.0 Group Member
    Sep 13 2008
    dont let the engine run when you have bad coilpack for too long. the unburned fuel will destroy your car which is a costly pair if your above 90k miles.
    Mar 16 2009
    Boone, NC
    I got the recall in the mail and everything but when i called Audi they said there only replacing the bad ones for now and for me to bring my car in and they will see if i need it. My dealership is about 75 miles away so thats a no go.
    2002 B6 3.0
    Apr 13 2009
    Peru, MA
    Bummer.
    Still, you cna find out which one is bad by checking the codes. it'll tell you which cylinder is misfiring.
    Mar 16 2009
    Boone, NC
    Ok cool thanks. Ill try and get the codes for you.
    2002 B6 3.0
    Mar 16 2009
    Boone, NC
    Ok scratch what i said before i called A.O.A. instead of the dealership this time and they said as long as i buy Coil packs that are approved by Audi they will reimburse me.
    So now the question is which ones are approved by Audi?
    2002 B6 3.0
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    if you can wait for shipping buy these from greg at DTH. best price around. might as well get all 6 as these are the latest and greatest. and yes, they are approved by audi
    Mar 16 2009
    Boone, NC
    Quote Originally Posted by zz2h33 View Post
    I thought those were for the 1.8t does it matter?
    2002 B6 3.0
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    Those are for the 1.8T. They won't work on the 3.0. The correct part number for the 3.0 coils is 06C905115M. It replaced the L's. We just got a bunch in this morning (http://www.europaparts.com/ignition-...6c905115m.html)
    Mar 16 2009
    Boone, NC
    Quote Originally Posted by Matt@EuropaParts View Post
    Thanks Matt i will be ordering all 6 from you guys monday. If this dosent fix it im gonna cry.... lol
    2002 B6 3.0
    Mar 16 2009
    Boone, NC
    Two more questions.
    Does a dealer or mechanic have to change the coil packs to be reimbursed?
    I changed all my plugs, And tried to crank it with the bad coil packs. Did this foul my new plugs?
    2002 B6 3.0
    Mar 16 2009
    Boone, NC
    Bump!
    2002 B6 3.0
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    To answer your question probably not, unless you actually have a strong gas smell. As far as the recall goes I wouldn't know. I would say the dealer has to do it in order to be a recall work...
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    ^no, others are getting reimbursed after purchasing their CPs and replacing them themselves. OP, did you ever get the recall letter from Audi? It tells you in there how/where to send in the receipts and the reimbursement form.
    Mar 16 2009
    Boone, NC
    yes i got all that paperwork i just wasn't sure because it asked for the mechanics name. but i have a friend who is a Audi tech so ill just have him sign.
    2002 B6 3.0
