Hi All, I am burning lots of oil and took the car to the dealer, so they are doing an oil consumption test. I am checking the oil every time I fill up with gas and usually have to top up the oil at the same time. There is no oil leaking, because I park the car mostly at only two places, home and work and there is no oil on the ground.
The funny thing is when I took it in for the oil consumption test, the dip stick is way over the top. Usually I have it between the low/high. I actually did fill it too much a while back and thought that might be a problem so took it back to the dealer and it said it should be fine. I was thinking that there could be problems with too much oil.
The car will be going in to complete the test in the next couple of days, so will let you know what the results are.
Its quite a mystery where all this oil is going, I hate to think what my values are looking like.
