New questions:
Ok, so I pulled out the cigarrette lighter under the arm rest, and there are 3 wires. red/blue, grey/blue, and brown. Obviously two are power and ground, and the other is for the light ring around it.
My new questions are:
1. Which is which?
2. Can I use the wire for the light to make my adapter turn on/off with the key as opposed to always on?
Old questions:
1. The front cigarette lighter in my car, the one under the radio, does not work. I have checked fuses, and fuses are fine. I doubt it could be a fuse, because the light around it still works. Where do I go from here?
2. I am thinking about hard-wiring something that currently has a cigarette lighter adapter. Is it as simple as cutting the adapter off and then there is the usual neg and pos wires? How should I go about this? If that is the case, I would probably just splice into the wires to the working lighter near the e-brake.
Any help on these matters would be appreciated.
