WOW! Thank you so much for posting JayTeeC. I have been struggling with this for over a year and can thankfully say the struggle is over!
My seatback would remember position - but only to a certain angle. After that it would not remember.
For search purposes, I want to share my experience tonight, too:
First, changing the coding to 00003 didn't actually do anything. The car accepted the coding, and I immediately started fiddling with the positions. No change, still would not remember past a position. Then I shut down VAGCOM and turned the key off, then on again. Fiddled again, still no change. Then, I started poking around in vagcom again. In the adaptation menu, the default channel of 81 pops up. There was a little message that said "enter 20771 to learn vehicle data" or something like that. I entered that number, hit test, and save. It certainly accepted it, but nothing seemed to happen.
Then, i started fiddling again, and voila!! The issue is FIXED!
The reason I wanted to post my experience above was, to me, it wasnt immediately clear whether it was the 00003 coding or the adaptation channel 81 entry which knocked my seat memory out of issue. Perhaps it just took a few minutes for it to take effect. Regardless, the issue is now fixed.
For what its worth, my coding is now back to 00003 and I still have full range of memory positions available. From here on out, I will see if I can get all the functions working again, as per the manual, and I will post back with my experience!
THANK YOU AGAIN. You have made me a few happy guy.
