Results 1 to 14 of 14
    Dec 15 2009
    Philly
    Sound when opening door?
    Hey guys, everytime I open my door on my 2010 A4 it makes this sound, you know the sound when you're adjusting your seat??? I'm so confused because I have no idea what it is. However, I always hear it when I open my door to get in. Does anyone have any idea what that noise is?? Are my seats adjusting?
    Veteran Member Four Rings Black3.2's Avatar
    Jun 02 2009
    2017%20S6%2C%202019%20Q7
    Atlanta
    Re: Sound when opening door?
    almost positive it is the fuel pump getting the car ready. it sounds like a whoosh, correct? there was a post on this not too long ago and i believe that was the final verdict.
    Dec 15 2009
    Philly
    well, it isn't exactly a whoosh, it's almost the exact sound you hear when we move our seats up or down with the buttons. Hmm....very perplexing -.- well for me at least. hahaha
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    If you have your seat memory synced with the keys, and somebody adjusted the seats prior to you, when you open the door, the seat will reset itself to whatever is in the key.
    Mine makes more noise after my dad drives the car...with his settings. The HPFP is that whirr noise from under the car. The clickety clack buzzing is from the seat.
    Ryan - flickr
    Dec 15 2009
    Philly
    i only have the PP model, so no memory seats -.-
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    hm...interesting. Then it's probly just the pump. They do make clicking noises too. Just less pronounced than seat clicks.
    Ryan - flickr
    Apr 18 2009
    Sweden
    I hear a sound too when opening one of the doors and I don't have powered seats. It's an electronic sound almost like when applying the electronic parking brake.
    Is this the sound you're hearing too?
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    i know the sound you're thinking of, and yep i believe its the pump or whatever.
    Dec 18 2009
    2015 Jeep Wrangler JKU
    Atlanta, GA
    it is the fuel pump priming the car for ignition and is perfectly normal. notice that it only makes that sound when you open the driver's door.
    2018 Audi S5 SB - Gotland/Rotor
    Previous Cars █
    2010 Audi A4 2.0TQ 6MT
    2008 Audi TT 2.0T S-Line DSG
    2005 VW Jetta GLI 1.8T 6MT
    Dec 31 2009
    Madison
    It is indeed the fuel pump.
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    Quote Originally Posted by stikillller View Post
    its the fuel pump (right rear)
    it sounds a little chain driven. All normal. There was a thread about this last year.
    it sounds a tiny bit like the sound they use in the movie at the end of this commercial
    http://www.youtube.com/watch?v=vfEZJ5vjsU4
    Dec 15 2009
    Philly
    ah ok, thanks for all the responses, btw, it also makes the sound after I shut the car off i believe~
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Yep Fuel Pump, it also only does it when you open the driver's door I noticed, not the other doors (on my S4 at least).
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Sep 13 2009
    2010 A4 2.0T
    it hasn't been mentioned before, but i think it's the fuel pump...
    maybe someone can chime in and confirm.
