Results 1 to 21 of 21
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 03 2005
    14 MkVI, 11 Sienna AWD
    530, California
    The A4 is rwd biased?
    I searched drive bias and rear wheel drive bias and found nothing. The only reason I ask is because the base model A4 is FWD.
    Since the motor is mounted long ways like a RWD car, I assume the A4 is RWD biased, is this correct?
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    No, it is FWD Bias, the torsen diff provides traction to the wheels that need it.
    Torsen
    Registered Member Three Rings
    Aug 19 2004
    ohio
    incorrect. the engine configuration does not declare drive wheel bias, that's done with the center diff. most AWD cars are 60/40.
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    yeah, most are slightly rear biased because of the straight shot to the rear axle, and that acting like a RWD car until encountering a traction loss is the idea of the system.
    Aug 19 2004
    ohio
    watchu talkin' bout, willis?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    In stock conditions, the Torsen is close to a 60/40 bias, this can be corrected to close to 50/50 with shimming of the center diff. STaSIS Engineering can do this, ask Jet Jockey, he has performed this modification.
    Registered Member Four Rings LEDFoot's Avatar
    Nov 01 2004
    '99.5 A4 1.8T | '99 Jeep GC 4.7 | '00 S4 (in the shop for a few weeks :( )
    dfw, Tx
    Torsen quattro is 50/50. not 60/40.
    Vart tog vägen vägen, varför är vi på en åker och åker?
    //Martin
    Feb 17 2004
    Sterling, VA
    The Torsen diff is 50/50. Fact. Call Torsen and check for yourself.
    Yes, you can add washers to the larger end of the torsen to modify TBR but, you would effectively change the TBR under positive and negative loads.
    Here's the bottom line.
    There are 2 versions of the Torsen diff in Audi cars.
    T-1: This model is used in MT cars only. It has been the same model since quattro was first brought to production in 1986. There was one subtle change in late 1997 where a needle bearing on the rear end was swapped in favor of a teflon inpregnated washer set. Standard ranges of TBR are: 2.5:1 - 3.5:1
    T-2: This unit was added in 1995 for Audis with Automatic transmissions. Before 1995, there were no Audi cars that had both an automatic transmission and quattro. Standard TBR ranges are: 1.5:1 - 2.5:1
    The hard facts of the Torsen diffs used in Audi cars:
    In standard part throttle driving, the Audi A4/A6/A8 drivetrain is a 50/50 split. If you are under load via throttle, your rear wheels can receive as much as 65-70% of the engine's output. When you are in a negative load condition such as downshifting, the torsen can direct as much as 80-85% t othe front wheels. This was a requirement from Audi because you don't want your torque bias to high in the rear under deceleration. This can cause the rear wheels to drag the car into a left/right yaw and will send you off the road.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Active Member Four Rings
    ^^ Believe him ^^
    Oct 17 2004
    Columbia, SC
    with an avatar like that, you'd be crazy not to
    Veteran Member Two Rings
    Mar 02 2004
    2001 Audi A4 Avant
    Upstate NY
    I was gonna say I swore it was 50-50. When I am straight line on the snow and hit it, I can hear/feel the power go to the back more.
    And Daft, I thought you might like this, I had it on file.
    Current:
    2001 Audi A4 Avant, Stage 3 (17 years, 120K)
    Sold:
    1999 Audi A6 Avant, Worn (3 years, 134K)
    1996 Audi A6 Avant (5 years, 155K)
    *(Owned, Odometer)
    Feb 18 2004
    Audi A4
    East Aurora NY USA
    Definately RWD bias based on driving.
    Thanks to Daft for good information.
    i like my black girls clean and my white girls dirty.
    doesn't matter either way they're all out to hurt me.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Daft is the man. Excellent post.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Feb 17 2004
    Sterling, VA
    Hehe, That's pretty cool. It reminds me of one of those giant stone heads on Easter Island.
    Brett - Moderator
    Issue?: email me.
    Jan 03 2005
    530, California
    Daft, you totally awnsered my question beyound doubt. Thank -You.
    DarkkstaR, I agree, it does feel RWD biased when driving, much more fun the WRX's IMO.
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    02 A4 3.0 Sport
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    makes a lot of sence
    you can kinda feel it when I'm doing donuts in the snow
    Senior Member Two Rings aks986's Avatar
    Mar 03 2004
    Tucson, AZ
    Stupid Question:
    I was recentily thinking about the idea of making a rwd a4 from a quattro a4. How much work would this be? Has any one done it? Any idea of cost?
    I live in Tucson, AZ and dont really need the quattro, and miss the feel of my other rwd car, plus i could deff use the extra hp to the wheels. Any insight would be great.
    Shea
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Originally posted by aks986
    Stupid Question:
    Shea
    Stand alone tuning and if you want 100% rwd you will need to install a normal rwd tranny.
    Mar 03 2004
    Tucson, AZ
    i was just thinking that with my dads 996tt when they put it on a 2wd dyno they just disconected the drive shaft, and i understand that would be diffrent with a front engined car, but i was hoping it wouldent be all that complex. So there is no some what simple way of doing it? you couldent just disconnect some parts or make a few part replacements?
    Shea
    Jul 07 2004
    socal
    Shea
    Dont think its that easy with the quattro setup. We cant dyno on a single roller and at the drags I have seen S4's break half shafts, rear diffs and the drive axle. When this happened the S4 could not drive on its own.
    Oct 17 2004
    Columbia, SC
    you would have to beef up the rear to handle 100% of the power,
    find a way to disengage the center differential that puts power to all 4 axles. may just be as easy as bolting a flange where the front axle shafts go in that makes the power flow to the rear.
    but then youll have to put a mock CV shaft end into the knuckle to keep the preload on the front wheel bearings. because the hub nut is what keeps the bearing loaded.
