Here is the cup holder and its simple removal/install.
Tools needed: 1 hand, two small flatheads, or similar tools \/
The cup holder in question \/
The locking tabs. There is one on both sides. You use the screwdrivers, or other tools so push these back (be careful, they can break easily) \/
The next step requires a bit of manual dexterity, or a second set of hands. After you have pushed in the small locking tabs, all you do is pull upwards, as you pull upwards once you get past the locks pull out your tools, and the cup holder will slide right out. The first time I took mine out it took a little more force than every other subsequent time, but it will come out. There is nothing else holding it in. \/
And your cup holder is out.
All you have to do to install is: take your new cup holder in the "closed" position, and slide it into the opening. Once you hear the locking tabs click in, thats it, your done. One new cup holder, removed and installed.
