Results 1 to 17 of 17
    Veteran Member Four Rings dannyj777's Avatar
    Jun 01 2008
    2005 B6 S4 Avant Arctic White
    NorCal/SoCal
    Question new brakes and rotors...nothing but squeaking, need help
    just got new drilled/slotted rotors and Hawk high performance pads in the front.
    i don't really feel any improved braking, but definitely not worse.
    problem is, they are squeaking like a mofo, especially front right.
    they were lubricated properly, bedded in, and i was told the squeaking would probably dissipate after 20 miles because they are new. well 150 miles later, they still squeak as i come to a regular traffic light. I've tried bedding again, but with no avail. I've also hosed down the calipers to clean out any dust, but it didn't help. Any advice? I'm about ready to pull my hair out.
    thanks in advance.
    2005 B6 Avant Arctic White
    Registered Member One Ring audiringstt's Avatar
    Aug 15 2007
    2000 Audi TT 1.8T (Sold) 1999 Audi A4 2.8 (Sold)
    Wisconsin
    Re: new brakes and rotors...nothing but squeaking, need help
    Check the space between the rotor and the brake dust shield. This happened to me on my front right when my brakes were done. All I did was pry it back a bit.
    Veteran Member Four Rings mad70sx's Avatar
    Mar 12 2009
    Silver '04 S4
    North Central CT
    Hawk ceramic pads? I installed mine and I thought mine made a lot of noise at first too. Especially when they were cold or when I came to a slow stop,dragging the brakes a little. I did notice an improvement after I installed them but I also installed braided lines and light weight rotors at the same time,too.
    Barely hear anything now,not sure how many miles it took to quiet down but it was definitely more than 150 mi.
    I don't have any advice other than wait it out a little more. Believe me,I know it's annoying but in my case it pretty much went away.
    JHM Tune ~ JHM Intake Manifold ~ JHM Version 2 Headers ~ FI/JHM 2.5" Exhaust ~ JHM 40/60 Rear Diff ~ JHM LSD Rear Diff ~ KW V3 Coilovers ~ Porsche 18Z calipers ~ BBS CH
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    what rotors did you get?
    Aug 17 2009
    Pittsburgh
    Hawk recommends that before bedding in the new pads you may have to bevel or shave the leading edge a bit at a 45* angle or so to prevent noise on certain rotors. Also, the bedding in process should be 8-10 HARD FAST 45-60mph stops, followed by a complete cool down to prevent noise and aid in function. Upgrading to a pad like Hawk or Porterfield is nothing like your typical pad like Akebono or EBC.
    Jun 01 2008
    NorCal/SoCal
    thank you all very much. I have already noticed a significant decrease in noise, so hopefully we will be in good standing soon.
    as for the rotors...contact Patrick Bendicto 408-710-3037 @ bigfoot performance, tell em i sent you. great pricing and customer service. all rotors made to order and can come in different colors. i will post pics soon.
    if you guys have any other tips or tricks, it would be much appreciated. I hope the noise goes away completely soon.
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    Quote Originally Posted by dannyj777 View Post
    I dont think itll ever go away COMPLETELY from what ive heard ceramics are a bit noisier which is why i went with the HPS's. Im also interested in the rotors you went with although its more then likely the pads causing all the ruckus.
    2019 QUANTUM GRAY S4
    Stock
    Prev
    2015 SUZUKA GRAYRS5
    2013 SUZUKA GRAY RS5
    2015 MYTHOS BLACK S4
    2008 AVUS RS4
    2004IMOLA YELLOWS4
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    Id say put some serious heat into the pads, then let them cool, not by sitting but by braking easily and lightly. This has helped before, especially with new brakes.
    Nov 21 2009
    Arcadia/CA
    try bedding them again. also u can also try to file down the leading edge of the pad
    b5 s4 semi-noob...b5 a4 super-noob
    '01 a4 avant http://www.pbase.com/sy0296/b5_a4
    '01 s4 avant http://www.pbase.com/sy0296/s4
    '88 m3 on going project http://www.pbase.com/sy0296/e30_m3
    '02 m3 681rwhp 110oct + meth http://www.pbase.com/sy0296/m3&page=all
    Veteran Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    Drilled/Slotted rotors Squeak like a mofo...that is one of the many down sides.
    Your not going to get it to go away that is normal. Over time it actuall gets worse. Search and you will see this is the number 1 complaint about cross drilled rotors. SLotted has less noise but still some.
    +1 rep for being honest about not stopping better. Ive never seen any benifit other then looks wise on that for normal driving
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Oct 05 2010
    I have a similiar problem but mine dont sqweek when they stop they make noise when traveling down the road. I installied new hawk pads and rotors. But it only make the noise like in ons spot its not a consit noise amy ideas i have tried the heating them up and everything. But it still dose it cant make it go away. Doing this from my phone sorry for the spelling and grammer
    Jan 29 2010
    north ga
    I really hope English is not your first language.
    If it's not, then don't mind me........
    Nov 07 2010
    Troy, MI
    Quote Originally Posted by hercfe View Post
    ^ this
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Add more anti-squeal compound on the caliper clips.
    Oct 05 2010
    I have done the stoping and hard braking its like a consit sqeeking only gose away when u apply the brakes. I heard it might be the clip any ideas.
    Apr 24 2009
    Frisco, TX
    Anti-rattle clips should be replaced any time you service the brakes.
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    Quote Originally Posted by Audi0s View Post
    The German Tune-Up trick......
    Actually I have cured squeaking brakes by doing this on more than one occasion but it will come back at some point.
    Cheers,
    Jim
