Results 1 to 11 of 11
    Oct 05 2009
    Are Brakes Covered Under Warranty?
    When I had my 03 Audi A4, brake and pads were covered. Is this no longer the case with 2008 Audis ?
    Mar 17 2009
    2001.5 S4 Pearl white with white interior 6 speed.
    Earth
    Re: Are Brakes Covered Under Warranty?
    I do not believe normal wear and tear items are covered under warranty
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    No wearable parts are ever covered by warranty as far as my experience has been. Why would they ever replace something for free that is intended to wear and be replaced. Maybe under some sort of free maintenance schedule, but not warranty.
    2021 Audi S4, P34 Intake
    Veteran Member Three Rings neverfollow-rs4's Avatar
    Apr 23 2008
    2018 Q7, 1988 YUGO GV
    Atlanta
    What he said and its not covered under audi care either. The only way would be if you have something worked out with the dealer. Didn't bmw had some type of coverage that covered brakes wipers etc? I think Audi had it about 7-8 years ago but that was when they were trying to attract more customers.
    2013 S4 6MT P+
    Nav, Drive Select, Napa seats, B&O.
    May 20 2004
    More cars
    Never Land Ranch
    The older audi's up until 2004 had brakes and wipers covered under manufacturers warranty.
    Currently, no wear and tear items are covered under that warranty unless a manufacturers defect...
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Established Member Two Rings king505's Avatar
    Jan 13 2009
    2005.5 B7 A4 2.0T Q TIP
    I believe under the Audi Advantage they will replace pads 1 time. Wipers are covered to. Not under the warranty though only Audi Advantage.
    Veteran Member Three Rings TheHeggi's Avatar
    Aug 03 2008
    05.5 2.0t A4 + 02 CBR600 F4i
    Redlands, CA
    Quote Originally Posted by SEXICAN View Post
    My brake pads/rotors were replaced under warranty at 45k on my 05.5...I think that deal went out the window before 06 though
    05.5 DG 2.0TM FWD
    [Stasis SS][RS4 Rear Sway][APR 91][AEM intake][034 HFC][podi/stepper boost gauge][Satin Black B6 USPs][S-Line front bumper][RS4 Grille][Satin Black S4 blades][DIY Ti vinyl][DEPO projectors w/6000k]
    May 20 2004
    More cars
    Never Land Ranch
    it all depends TheHeggi,
    Some dealerships will replace them "under warranty" and some won't. It all depends on teh dealership
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Aug 03 2008
    Redlands, CA
    I could've sworn I read on here multiple times in the past that 05 or 06 was the last yr for this option, but whatevs, no biggie.
    05.5 DG 2.0TM FWD
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Quote Originally Posted by TheHeggi View Post
    Yeah, before my warranty and free maintenance plan ran out, I had my front pads replaced for free. My service advisor called me when my car was in for the 35k service and told me something along the lines of, "your front pads are looking pretty low, would you like us to replace them for free as Audi offers one free replacement."
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    05's are the only cars that got warranty wearable items:bulbs, wipers, clutch, brakes. 06+ are 12mo/12k, clutch is 6/6 iirc. bulbs and wipers are 6/6. but if you buy a cpo, it probably got brakes before you bought it as they have to have 7mm minimum (half of total thickness) to pass cpo standards. pads are just about one of the easiest diys around and rotors arent any harder.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
