Results 1 to 15 of 15
    Established Member Two Rings B6 S4 is BRZRKR's Avatar
    Nov 08 2004
    1972 Datsun 240Z w/ SR20DET swap, 2005 Audi A6 4.2 Sport Sedan, 2003 Passat Wagon V6 4Motion
    Knoxville, TN
    Front diff gone bad? Really?
    I just bought, as in this week, a 2004 (build date 09/03) 6speed Avant.
    When I turn the wheels 95% going slowly (of course) in the dry, it groans. In the wet, when the tires have no traction, it hops the front wheels. Makes me think that the front diff is locked up. Thoughts? if this is the case, where do I go?
    HELP!
    Thanks much.
    Jared
    2004 S4 Avant 6 speed
    2003 Passat V6 4Motion GLX Wagon
    1972 Datsun 240Z - Rules the roost.
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Re: Front diff gone bad? Really?
    Normal. Search. Nuff' said.
    Oct 11 2009
    MD
    It's the 4wd. It's normal don't worry about it. We all have it.
    Nov 08 2004
    Knoxville, TN
    I bought an S4 new in 2004. Didn't do it at all. Also, I've searched "front groan" and "front diff" and find nothing. I'll keep searching terms that I can think of. Thanks for the help, guys.
    Senior Member Two Rings hayasa's Avatar
    Aug 25 2008
    S4 has an open front and rear diffs, but electronically controlled through stability control. The slight groaning is the center diff since it is mechanical. Normal sound.
    Established Member Two Rings nycats4's Avatar
    Nov 13 2008
    04 s4, 01 se-r
    nyc
    Search "quattro binding" and you'll have your answer.
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    I saw a bulletin lately that required you to overfill the power steering reservoir by 10mm to quell groaning noises. I have noticed an intermittent groan only while the clutch is down and turning the wheel, like a 3 point turn. Why theyd be related I have no idea.
    Nov 08 2004
    Knoxville, TN
    Thanks guys. I'll check it out. However, in response to the "we all deal with it" stuff, I'm not a noob with this. I think this is more than normal. My 04 S4 Sedan didn't do it. My Q7 4.2, A6 4.2, 4Motion Passat V6... none have this issue like this. It pops LOUDLY in a parking lot so that people turn to look. I'll read the posts though. Thanks for all the help.
    Nov 08 2004
    Knoxville, TN
    Flushed it (front/center diffs/trans) with Motul yesterday. Still has the problem. I also have a leak of engine or trans oil where the bellhousing meets the block. I don't know if it's the rear main seal or the equivalent in the front of the trans, but I guess I'll be doing both at once, and at the same time, I might as well upgrade the clutch, flywheel, and center diff to 4:1. Any other ideas?
    Active Member Two Rings Abwasserleitung's Avatar
    Jan 30 2010
    Central WA
    I understand the theory behind what is happening with the mechanical diff, I've driven numerous audi's w/ quattro and none of them have groaned. I too find it hard to believe that this is normal and just go on my merry way. I am sure most of us felt this way in regards to oil consumption and Audi's response. I've talked to a few people where this was solved by replacing either the transfer case, UCA bearings, steering rack, and/or wheel bearings. I am just looking for a better answer than its normal.
    Where's the facts?
    i.e. problem => solution
    Mar 11 2008
    B7RS4 & e46Ms
    There's three things being talked about here...
    1. groaning while turning due to power steering - Different issue that what the OP described, as he can feel wheels hopping.
    2. groaning (from the rear wheels) - due to the center diff sending more torque to the rear wheels at low speed...coincidentally, those are also the wheels moving the least when turning at full lock at low speed. - This is what's considered normal. 07 cars and newer (perhaps some 06s as well) have a different diff with a higher rear bias and this is more evident.
    3. If you're turning and you hear loud "pops", then you may be looking at bad CV joints... If it was the diff, you'd most likely hear it while going straight or under light turning as well...
    FRRG AZ Ring
    Nov 19 2005
    somewhere
    I have this behavior/scenario on a somewhat regular basis. Dealer said the "noise" is coming from the the exhaust ?!?
    Is there any "official" word - or "proof" - that this noise is really from the center diff?
    Do we have an official response from AoA on this? Would be nice to have - to ease our concerns.
    When "quattro binding" is mentioned to the dealer they look at you like a startled deer in front of headlights... ??
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by audi-s View Post
    Well, if you talk to any A4 or early S4 owner who did the 4:1 mod on their center diff, they can attest to this change in behavior. I noticed it right away, then confirmed is again with the stock RS diff.
    FRRG AZ Ring
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Yea I noticed a pretty big difference going to the later model center diff. Definitely the way it should of come from the getgo!
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Nov 19 2005
    somewhere
    Thanks for the clarification!
