Results 1 to 10 of 10
    Established Member Two Rings mountainsnbirds's Avatar
    Nov 25 2008
    05' S4 Avant 77' Puch Maxi
    WVU, Morgantown, WV
    drone/humming between 55-60mph
    I've searched and found several threads. one it was simply a wrong tire size, the other threads mentioned something about a problem with the rear differential.
    Between 55 and 60mph there is a drone in the car. Very loud, enough to cause things in the car to vibrate!! i just noticed this the past week. My tires are the correct size(235/40z 18). I'm not sure what may be causing this.
    Anyone know what this may be?
    THanks in advance!
    Sorry....the car is manual
    Yeah, it is just a drone. At 54mph no drone at 55 the drone is very loud and again stops completely over 60mph. It doesn't seem to be coming from one particular area, i'll try to pinpoint it today. The tires are Cooper zeon zpt, they are cheap tires but they are somewhat new(<2,000mi). Also this is something that started within the past week.
    Thanks again for the quick replies.
    I wanted to update the thread. I found the problem. It was in fact the left rear wheel bearing. Its getting fixed now and should be done tomorrow. I cant wait to have a quit ride again!
    Thanks again for the helpful advice!
    Last edited by mountainsnbirds; 01-11-2010 at 10:11 PM. Reason: found source of problem
    Veteran Member Three Rings ahhhudi's Avatar
    Dec 15 2008
    north Chicago area
    Re: drone/humming between 55-60mph
    Is your car a manual or tip?
    Current: 2015 B8.5 S4 - Sepang Blue w/Black Optic package. Sport Diff.
    Previous: 2005 B6 S4 - Dolphin Grey and 2001 B5 S4 - Black.
    How Many Speeding Tickets? Vote.
    Quote Originally Posted by mountainsnbirds View Post
    THanks in advance!
    Just a drone at those speeds? Where exactly do you hear the noise coming from?
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    What tire you running and how old are they?
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
    Active Member Three Rings tylerS's Avatar
    Aug 02 2009
    nw
    check for excessive wear on your tires... if something got knocked out of alignment, it can cause an odd humming noise
    Veteran Member Four Rings mad70sx's Avatar
    Mar 12 2009
    Silver '04 S4
    North Central CT
    I recently had to have the rear diff on my S4 replaced under CPO at approx 55,000 mi on the odo. I was getting a fairly loud hum at 50 to 60 mph. Dealership said it was "something" in the rear diff but could not specify exactly what the problem was so it was replaced completely. I did not experience any vibration at the time,but I would have assume,judging by the noise,that if I did not have it addressed that it eventually could lead to some vibrations.
    Noise issues can sometimes be tricky to identify and correct,hopefully it is something relatively simple such as worn tires,etc. Good luck!
    JHM Tune ~ JHM Intake Manifold ~ JHM Version 2 Headers ~ FI/JHM 2.5" Exhaust ~ JHM 40/60 Rear Diff ~ JHM LSD Rear Diff ~ KW V3 Coilovers ~ Porsche 18Z calipers ~ BBS CH
    Veteran Member Three Rings rzundel's Avatar
    Sep 20 2008
    Ferrari Challenge Stradale, Maserati GranTurismo S, Range Rover HSE, Porsche Panamera
    Westlake Village, CA
    Droning is caused from a "harmonic" event. Just because you notice the drone between 55-60 doesn't mean that the vibration isn't occurring from the onset of rotation. What you hear between 55-60 is simply the Harmony of the event. Focus on all areas of the car that have rotation. Tires, drivetrain, brakes, exhaust, bearings. Best guess without hearing it would be drivetrain. Does it make a difference if the car is under power or not at those speeds? In other words, when you hit 58mph and let off the gas does it still drone? If so you can most likely eliminate anything engine related. Just my 2 cents.
    2005 Audi B6 Tip
    HRE M40 20x8.5 et34, HANKOOK Ventus V12 235/30/20, BREMBO 6pot Front BBK, BREMBO 4pot Rear BBK, KW VARIANT 3 Coilovers, LABREE Res Cat Back w/4" tips, GIAC ECU Flash, AE Corner Balance + Alignment, HOTCHKIS RS4 H-Sport F&R Anti Roll Bars, STERN Adjustable Control Arms, AE PERFORMANCE Black Optic Hood and Bumper Grilles, Clear Corner mod + Silver bulbs, Rear Valence Painted Satin Black, 30% Window Tint, Front Clear Bra, RS4 Pedals.
    Nov 25 2008
    WVU, Morgantown, WV
    Quote Originally Posted by rzundel View Post
    The noise does continue after leaving letting off the throttle. Thanks for your advice i will check all those areas well!
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    A bad wheel bearing will sound like youre in an airplane. Although it will increase with speed.
    Established Member Two Rings audimotion's Avatar
    Apr 03 2009
    04 S4 Cabriolet 6MT, 07 Q7 3.6
    minnesota
    Just today I picked up my wifes ML 500 from the dealer after having a new differential installed. She was complaining about a droning noise and some vibrations throughout the vehicle at speeds 40-60mph. Dealer drained the diff. fluid and found metal shavings...replaced diff. under warranty. Drove approx. 120 miles today after picking it up and now vehicle is smooth as butter and perfectly quiet. In your case, if its not the diff, it may very well be a wheel bearing as they have a similar sound when going bad.
    Good luck!
