Originally Posted by
B6JoeA4
you are correct.
with leatherique, the conditioner forces dirt and grime out and pushes it to the surface, the cleaner is then used to clean the dirt off of the surface
On the basis that 95%+ automotive leather has a polyurathane covering... I'm also "Confused about how [and why] to use Leatherique"
Leatherique
[Leatherique arose from a need to find a product that would restore the leather in his 1939 Bentley. Nothing he tried was adequate for this special car, so he approached Peck about creating something new. After a lot of work, they produced Leatherique”] [Leatherique]
This type of top-grain premium leather is mostly used in prestige European automobiles; Aston Martin, Bentley, Ferrari, Jaguar, Lotus, Lexus and Rolls Royce, US Cadillac and high-end German automobiles such as Mercedes-Benz, Daimler AG and BMW. This is the market sector both Leatherique and Connolly were originally formulated
[Leatherique Pristine Clean is part of a two-step leather maintenance system. Step one - Leatherique Rejuvenator Oil is a protein collagen complex that is absorbed into the hide to nourish it, and while it will expel dirt to the surface, it does not harm the dye in any way. This oil nourishes the leather and forces contaminants out of the pores.
Step two - Pristine Clean then removes these contaminants from the surface of the leather and leaves it with a clean, matte sheen. This is the only leather care system that calls for the conditioner to be used first, and it makes perfect sense! The leather absorbs as much of the oil as it can and expels the rest to the surface, along with all the contamination.] [Leatherique]
Comment
[That is the design of the formula for Pristine Clean. It removes just the dirt and not the Rejuvinator Oil. Never use a cleaner first since that will emulsify the dirt and drive it into the leather]. According to Leatherique you apply the (conditioning) oil first and then the cleaner. They state that their cleaner will only remove contaminants (dirt and oils) but not the Leatherique oils. I would question how it discriminates between the oils that it removes: i.e. the most common soil found in leather upholstery is body oil followed by suntan oils and then oily residue brought in via the air conditioning system
In my opinion the chemistry behind the Leatherique system simply does not add up, whereas leather cleaning and protecting is a relatively quick and simple process (i.e. cleaning and hydration) it seems that this system takes a huge amount of effort.
An extract from “Automotive Detailing, Inside & Out”, a knowledge base for the perfectionist © TOGWT ™ Ltd Copyright 2002-2009, all rights reserved.
