Results 1 to 29 of 29
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    hood latch broke, now how do I open my hood
    the cable to the latch release has been disconnected, so I can't use pliers to pop the hoood Fuuuuuuuck.
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Re: hood latch broke, now how do I open my hood
    Same thing happened to me. If you can get a wrench in there you can take the three nuts that hold the latch to the hood off and pull it open. Kind of a pain, but thats the only way. Not sure if it'll work on a B7 though.
    Once you get it open, zip tie that mother****** back on. The clip breaks out and it slips off.
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by beemercer View Post
    that's the only option i saw too :/
    Dec 19 2009
    2000 S4: F21s, E85, Jfonz tuned. 1991 Audi 200 20VTQ: H&R springs, Brembos, 17x9s wrapped in 245s
    Santa Ana
    if you go under the car and get the bellypan off, you can use a real long screwdriver or soemthing similar and manually release the latch from the bottom side. There is a little lever that you have to push over. It's doable but not fun
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by AudiVWTech View Post
    thanks man, I'll try that. car is on the lift right now w/o the belly pan already
    Yep, had to do this on my friends A4 when the hood latch was not properly replaced. It is a pain but it is doable.
    Veteran Member Four Rings d.p's Avatar
    Nov 08 2006
    F80 M3
    Annapolis MD
    I wouldn't if I were you. The dealership replaced my AC condenser and forgot to re-attach the latch, thus sealing my hood.
    I stood at the dealer for 3 hours watching them try and use that method. They successfully mangled the latch and several tools and never got the hood open. I sold the car that day and the new owner ended up having to remove the 3 10mm bolts through the front grille from the latch to get the hood open. Cost me $200 in parts to fix all the shit the dealer broke!
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    May I suggest an alternative method?
    MY2024 B9 Q5 55 TFSIe: GlacierWhite||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Active Member Three Rings tylerS's Avatar
    Aug 02 2009
    nw
    or you can take a page out of frozen-lugnut-kid's book and...
    In Limbo Two Rings
    Jul 29 2009
    Michigan
    Quote Originally Posted by tylerS View Post
    Well at least this saw matches his car.
    Registered Member Three Rings somethingcorp's Avatar
    Oct 07 2008
    New Jersey
    that happened in my gti pain in the dick to do.. EASY fix tho.. the latch is very cheap
    Jhm tune, Piggie pipes, Awe Non-res cat-back, Intake spacer, clear corner mod, custom suede trim.. more to come
    "speaking my mind isn't an act. nor is it a product of me allowing myself to be a con artist, but it is simply to express something that i suppose shouldn't be held in."
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Man you have a widebody S4, supercharger, headers etc... You don't have any F*ing problems... Buy a whole new hood and call it a day.. lol
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    ^^^^ I think he has the aluminum RS4 hood, and not the steel S4 hood. I could be wrong, but it isn't as cheap to replace it.
    Edit: Might be a CF hood painted, I can't remember.
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Does the screwdriver method even work on the V8's? I looked to try and do it but I couldn't see shit from the bottom. Honestly taking the bolts out isn't bad at all, just run out and get a long wrench and a six pack... you'll have an open hood and a decent buzz.
    It does, but it is a lot more difficult than an A4 because of the lack of room in the engine bay. With the A4 you have so much open space to see up from under the car to locate the latch. With the S4 there is little room to see and get to it, but it can be done.
    Deactivated Four Rings
    Apr 13 2008
    Bayern
    whereabouts are these cables breaking again?
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Quote Originally Posted by ALWAYS4UDI View Post
    This is actually a good PSA.
    Pop your hood. Look at where the latch on the radiator support is. There should be a little black piece of plastic clipped into the latch. Sometimes the plastic piece breaks apart and it comes up clipped. So what happens is you pull on the cable and there is no tension, it's just loose.
    It's a good thing to check on every once in a while.
    Sep 16 2008
    B6 S4 Avant Nogaro 6-speed MT
    Normal, IL
    This happened to me and I was stumped. I just took it to an Audi repair facility (not a dealership) and they fixed it. Cost me a couple hundred.
    He fixed it using this method quoted I believe. I believe he bent his screw driver (pre-insertion) in order to get the right angle though. He showed it to me and giggled.
    Dec 19 2009
    Santa Ana
    Quote Originally Posted by d.p View Post
    The guy who did it to your car didn't know what he was doing. I am a dealer tech and I have had to do this a few times. I have never damaged any cars or any of my tools doing this. And it is doable on the v8 cars. I had to get a hood open on a b6 s4 cabriolet once using this method.
    Senior Member Two Rings sl2.oturbo's Avatar
    Jul 10 2009
    A4 2.0T S-line
    East Brunswick
    Quote Originally Posted by somethingcorp View Post
    i think i broke that hood latch on the gti lol
    2008 2.0t s-line Ti
    Dubbin' Daily
    Established Member Two Rings Prtaick's Avatar
    Feb 16 2009
    Philadelphia PA
    I have done a few of these. Removing the grill and the nuts is a good start to get the hood up a bit. Than I came up from the bottom with a few long tools, a hook, pry bar, my arm, things like that. It's all about being gentle... and having long girly arms and hands. ha
    Mar 09 2005
    Santa Clara, CA
    fuck that shitty latch mechanism! now that the hood is open...SC time!
    Mar 24 2010
    Sweden
    Quote Originally Posted by ngng View Post
    My god! how? i have the same problem, please post details of the process.
    Established Member Two Rings ADynamics's Avatar
    Oct 06 2009
    Sprint Blue B7 S4
    Tri State
    On B7 S4, put wedges to raise hood as much as you can, insert bent pieces of aluminum siding taped to hood and front grille, insert 14" blade between the siding, cut away two posts holding down the hood. Be very careful not to cut anything. It can take as long as 3 to 4 hours without hurting anything. Do not use power tools as you have not control for zero clearance.
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    As a former Corrado owner, opening a hood with broke cables is a skill, not a science.
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    Jan 14 2012
    columbus, oh
    B6 S4 Hood Opened through Grill
    Quote Originally Posted by joeycuccaro View Post
    Just had to work this out on my B6 S4. I think the screwdriver method could work with a long enough screwdriver and if you really knew the mechanism well. Just hard to tell what is what from the bottom. I ended up saying a prayer and then working the grill out with some finesse and a screwdriver. I removed the chrome colored ring that surrounds the grill first and I think that helped when I started working on the grill itself. There are tabs on the grill that you should be familiar with before you start working on it and I've seen details in manuals and other threads. Once the grill is out you can remove the three 10mm nuts that holds the latch mechanism to the hood. A long handled 10mm open ended wrench is about your best bet.
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    I went through this today, what a PIA
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Can someone confirm that the 3 bolts holding the latch can be removed on the B7 (B6 is confirmed).
    2.0T
    Other engines?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Senior Member Two Rings icanfly's Avatar
    Jan 12 2012
    06 B7 S4 | 92 Corrado SLC VR6 | STI Powered HandBuilt TarmacRallyCar | Skydiving Rig
    Looking for a canyon to carve.
    ^^^This is a fact!!!
    long live the slc vr6 and it's bitch of a hood!
    slow is fast...
