Results 1 to 15 of 15
    Established Member Two Rings chriswstprt's Avatar
    Jan 24 2009
    00 a6 2.7t 6sp.stg 3+,03 20th A.E.gti w/gt2871r, sold 87 mustang gt.EURO all the way!
    trumbull ct
    is my stock 2.7 good for 7000 rpm's like the s4
    i know the red line is about 7000 rpm's on the s4 2.7 and i have a 00 a6 2.7 6sp. with the same motor and trans but the cluster red lines at 6500. i would think it is the same, 7000 as the s4? any input on this? can i rev my stg. 3 to 7000 rpms without a problem?
    Veteran Member Three Rings chrisbostonusmc's Avatar
    Jan 12 2008
    Sarasota,Fl
    Re: is my stock 2.7 good for 7000 rpm's like the s4
    Quote Originally Posted by chriswstprt View Post
    I take mine to 7300 no problem and i dont have any head work done
    Stage 3 SSP Tuned RS4 K04'd
    12.4 @ 115 on pump gas only
    425AWHP/467AWTQ
    ALL MY MODS DONT FIT IN SIG! DAMMNITTT!
    95 Toyota Supra T51R 800hp
    Mar 17 2009
    2001.5 S4 Pearl white with white interior 6 speed.
    Earth
    Better question: What is the stock rev limiter ?
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    I regularly rev to 7k, I believe my limiter is set at 7350
    I don't think I care anymore
    Veteran Member Four Rings 2001A6's Avatar
    Sep 17 2008
    Stuff
    St. Charles, MO.
    I think the stock rev limiter is 6800. It is on the 2.8 as well.
    Programing raises it to 7100 on my 2.8. If my engine can spin that fast, the 2.7 will too.
    ~Matt.
    - PES Supercharged 01 A6 2.8Q
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Veteran Member Three Rings Coors's Avatar
    Aug 21 2008
    04 A4 USP 6MT
    Philly
    Quote Originally Posted by 2001A6 View Post
    ...Rev limiters according to GIAC's literature
    6,800 Rpm (stock)
    7,200 Rpm (GIAC chip)
    The greatest trick the Devil ever pulled was convincing the world he didn't exist, then poof he is gone.
    __________________________________________________ ________________________________
    GIAC BI File/TT 225 Injectors/034 HFC/Forge007/ER FMIC/JHM Short Throw/B5 S4 Motor Mounts/podi/AFE Dry/...
    [Sold] '01.5 6MT C5 A6/RS4'd/GIAC Stage 3 Minus w/ alot of mods
    Nov 30 2008
    SE PA
    It would be interesting to see a dyno chart to see if the HP and torque are still climbing that high or are starting to roll off.
    ________________
    04 allroad (sold)
    Aug 04 2007
    With KKK turbos, HP/TQ is most definitely dropping off. It is the turbos that run out of breath, not the motor
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by swmic View Post
    You're not making more power past 5k or so with K03's so it's purely for the increased FW momentum. Torque actually starts to fall off after 5K, and HP just kinda stays flat and begins to fall flat after 6.5. The only time I take the car to red line is first gear, past that there's no point.
    Nov 30 2008
    SE PA
    As I thought. Any revs higher than the peak HP/Torque curve don't do anything for you but slow you down and increase the chance of breaking things.
    ________________
    04 allroad (sold)
    Sep 17 2008
    Stuff
    St. Charles, MO.
    Like what was said, the turbos are soo small theres no need to rev that high. Power starts to fall off after about 5500, and even with K04s you wont really make power after 6500.
    And when I was emailing GIAC about their programing for the 2.8, they said the engine itself runs out of breath after about 7500, so theres no point in spinning it faster, unless of course you start playing with heads.
    And dont say that swmic, because depending on a cars powerband/gearing it pays to rev out more in one gear to put your self in teh sweet spot of the power curve for the next. Also can work the opposite, might be more efficient to short shift... Depends on the car.
    I think an ideal shift point with these engines, turbo or N/A, is about 6-6500, no higher than that unless you have big mods.
    ~Matt.
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Jan 12 2008
    Sarasota,Fl
    When I talked to Greg at SSP about doing drag runs after he did my K04 install I asked him where he shifts at since he has an 11 sec s4. He told me 7300 so i got my tuning programed for 7350. I'll have a dyno setup soon enough. Late March probably. This is also in race gas. When I did my 12.4 run on 93 I shifted to 7-7300 each time
    425AWHP/467AWTQ
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by chrisbostonusmc View Post
    in every gear? ouch..
    Veteran Member Three Rings GarbatyA4's Avatar
    Aug 10 2007
    Ontario Canada
    Yes you can!
    2012 Audi Q5 - Daily (slow AF)
    2013 Mini Cooper S - sold
    2005 BMW 325Ci - sold
    2007 BMW 335i - sold
    2004 VW Golf TDI - sold
    2004 Audi S4 V8 Cabriolet - sold
    2003 Audi A4 1.8T - GT2871R - sold
    2000 GMC Sonoma - sold
    1992 Dodge Stealth RT - sold
    1991 Chevrolet Beretta GTZ - sold
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    I'm just curious at what the AR 2.7 drivetrain can handle on let's say an rs6 k04 or some gt's before the need to upgrade. Is going past 7500 dangerous?
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
