Results 1 to 8 of 8
    Established Member Two Rings Dcting's Avatar
    Mar 25 2008
    Forest Hills, NY
    Shaving tires necessary?
    Hi guys,
    Looking for some help. Went to go put my stock titaniums on today in preparation for the winter and noticed I had a flat on one of them. Found out that the hole was in the sidewall and needed a completely new tire because it would be too dangerous to patch. So I was wondering if I would need to have the tread on the new tire shaved to match my other 3? I have read it can do quite a bit of damage if I dont, but my stock titaniums only have 5k miles on them (swapped to VMR 710s right after I purchased car). So my question is, will it really make much of a difference since my stocks are practically brand new? Or should I just get it shaved slightly. Thanks to anyone that can help.
    -DT
    Account Terminated Four Rings
    Aug 31 2009
    Short Hills, NJ
    Re: Shaving tires necessary?
    nope should not make a difference, you should have searched before posting b/c i have seen atleast 3 thread about this. I forget the exact number, but i tihnk there cannot be more then a 5% tread dif between any of the given tires. you should be fine.
    Veteran Member Three Rings caitovS4's Avatar
    Nov 19 2006
    If they're almost new than I think you're fine.
    I was told by Tire Rack that Audi recommends no more than a 4/32 difference between tires.
    -Vince
    2011 S4
    2005.5 S4 - Sold
    Veteran Member Three Rings rpmfoundation's Avatar
    Aug 25 2008
    2012 Toyota Highlander Hybrid Limited (wtf)
    Hollywood Hills, CA
    first and foremost - file a paper with NTHSA - there has been an ongoing problem with pirelli P6 developing sidewall damage.. and go to the dealer 5k miles on tires is nothing. I got my sidewall busted in 2500 miles and thats on nice roads. Do some research and get printout showing other people having same problem. P6's are just plain crap. its a fact. When they were on Volvo's there was a class action and people got their money back or tires replaced.
    my car is still on AZ... someone else is just driving it (BMO).
    Senior Member Two Rings Longbeach24's Avatar
    Aug 08 2007
    B7 Ibis White 6MT
    RI
    4/32 (as noted above per Audi recommendation) is a pretty big difference so you should be more than ok with only 5K miles.
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    The recommendation is actually no more than 3/32 if I remember correctly. Depending on the wear rating of the tire, you'd prob be ok, but it wouldn't hurt to get a tread gauge and just measure it out to make sure you're well within that range. I'm dealing with the same problem as I had a blowout over the weekend.
    If need be, tire rack can shave tires too.
    Justin
    DTM S4 Sprint Blue
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by caitovS4 View Post
    +1, with only 5k on your tires there shouldn't be too much wear. You should be ok
    Brandon @ VMR Wheels
    Mar 25 2008
    Forest Hills, NY
    Thanks for everyones help. Just placed an order in tirerack. I have more than enough tread and opted not to shave the tires.
    Used this as a reference if anyone ever has to measure tire depth with coins:
    http://www.tirerack.com/winter/tech/....jsp?techid=51
    Very helpful.
    -DT
