Results 1 to 17 of 17
    Active Member Three Rings
    Dec 10 2004
    Seattle WA
    Ideal tire size for running 19x8.5 front and 19x9.5 rear
    What are you guys running without an insane amount of rubbing? Need to get some tires going for my new wheels.
    Veteran Member Three Rings DaveS4's Avatar
    Apr 12 2009
    Nova Scotia, Canada
    Re: Ideal tire size for running 19x8.5 front and 19x9.5 rear
    Are your fenders rolled? If not, you may have some problems there...
    2001.5 VAST Stage3 **** Silver * 6 Speed
    2001.5 Completely Stock * Imola * Automagical
    Dec 10 2004
    Seattle WA
    Not yet... car is in a 1000 pieces, but I'll be rolling them as soon as I get it all back together.
    Veteran Member Four Rings bez101's Avatar
    Oct 06 2009
    sheffield
    im running on my 20's 245/30/20 slight rub with a full car
    i ran 19's 245/35/19 no rubbing
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by DaveS4 View Post
    he'll need spacers too, I have just about 1-2mm clearance from the knuckle with my 235/40's on 8" wide rims
    Dec 10 2004
    Seattle WA
    Quote Originally Posted by blmlozz View Post
    I'm going to figure out spacers once I've done a test fit... just trying to figure out what tires I should order for now...
    Nov 29 2009
    Wake Forest NC
    IM running 235 -35-19's no rubbing and its not to hard on your ass lol
    Dec 10 2004
    Seattle WA
    Quote Originally Posted by XXTHENECKXX View Post
    Fronts, rears, or all around?
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    it's really going to depend on the offset of your wheels.
    i'm running 235/35 19 in the front on my 19x8.5 and 245/35 19 on the rear on the 19x9.5. I needed the stretch in the rear to make it fit, and actually had to put 10mm spacers on the rear because the tires would rub on the suspension upright without them.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Dec 10 2004
    Seattle WA
    wheels are 43 offset
    Jul 12 2008
    SF Bay Area
    +43 is the stock avus offset, a 245/45/17 will need a 10mm spacer to clear on an 8" rim
    keep in mind every inch wider a rim is will add 25.4mm or 12.7mm each direction of less clearance
    I am looking at doing VMR 710 with a +33 rear offset (on 19x9.5) and 245/35/19 (all the way around with front 19x8.5 with a +45 offset)
    I have a 6mm spacer on the back now with 18x8.5 +35 fliks with 225/40/18 and have 20mm clearance (diagonally- closest point of contact from tire to upright)
    So switching to a 245/35/19 will add .7in (18mm) to the overall diameter of the tire so that should effectively bring me 9mm closer plus an additional 2mm due to offset and its possible that the inch wider rim could eat another 12.7mm of space
    Shit, now that I'm doing the math I'm thinking I might need an 8 or 10 in the back......
    Does anyone have a staggered setup on a B5 that could shed some light?
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    post pictures of the wheels on your car as well as how they line up with the fender and how close they are to the inner knuckle. Tire choice is affected by ride height as well as the fenders. If we see how you line up withthe fenders we can give you an idea on what kind of stretch you will need (if any) in the rear.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Dec 10 2004
    Seattle WA
    Quote Originally Posted by wdbdy2000s4 View Post
    Will be test fitting the wheels later this week. Will post pics. I found another set so might sell these anyhow haha.
    Apr 12 2009
    Nova Scotia, Canada
    How did this end up going? I'm trying to figure out if I'll be able to fit 19x9.5's with 235/35/19's all around with some rolling, I'd love to know how this went...
    Veteran Member Three Rings dgrs4sd's Avatar
    May 25 2008
    So Cal
    You wanna run 235/35r19 front & 265/30r19 rear if you are going to do it.
    These sizes have almost exact rolling diameter. This also won't mess w your quattro.
    Ideally you would just run the same size
    w/t all around as the car was setup for this and the quattro system prefers it...
    Feb 02 2009
    Cars other people killed
    capital city wastes
    theres going to be so much friction on your poor car. first its got to divide like 300hp to 4 heavy ass 19x9 rims plus the rubber you put on there will further slow it down. I mean sure itll look cool but good lord the gas mileage is going to suck.
    also since the quattro is primarily biased to the front you may encounter some understeer issues because the rear wheels are going to be firmly planted in the ground, going straight, and the fronts may have trouble convincing them otherwise.
    Apr 12 2009
    Nova Scotia, Canada
    I'll have the 4:1 diff, making it 80/20 r/f
    But yeah, I might just go with 19x8.5's and 235 tires. It's easier get going, I know it will work. If I take the car to the track I'll be getting 17's with some r compound, the 19's are street wheels.
    Also, stage 3's On meth are around 425hp, not 300;) the 19s I'm getting will be lighter than the stock rims anyways...
