Results 1 to 8 of 8
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Question symphonyII can-bus code 01336
    I had my radio out a while ago to remove the a/c controls and ash tray so I could install my shifter. Since the reinstallation my radio has never worked the same since.
    I did have to enter the security code to get the radio out of safe mode.
    My symptoms now are:
    ~ radio buttons do not light up when headlights are on
    ~ radio display is not in the DIS on the instrument cluster
    ~ only front speakers work, rear door speakers and subwoofer do not work
    I am getting the following DTC:
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8E0 035 195 A
    Component and/or Version: symphony II NP2 0007
    Software Coding: 00001
    Work Shop Code: WSC 00256
    1 Fault Found:
    01336 - Data Bus for Comfort System
    49-00 - No Communications
    Any idea what could be the problem? I haven't touched any of the wiring and have also made sure the radio connections are solid. All my fuses are okay as well. Haven't seen any blown fuses.
    Do I have to recode the radio via VAG-Com?
    -Doug
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    Re: symphonyII can-bus code 01336
    You shouldn't have had to re-enter the safety code, so this is really strange. I'm guessing you've already removed the head unit and double checked that all the connectors were all plugged-in.
    Is your A/C working okay?
    Anything else that isn't working as expect in term of comfort "options"?
    MY2024 B9 Q5 55 TFSIe: GlacierWhite||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Dec 03 2005
    2 pedals 1FG
    connecticut
    A/C works fine.
    All other 'comfort' features work fine.
    I checked the connections multiple times but I'll check them again.
    I need to have a second person verify that the subwoofer is working too. I am not sure if is working. I do know the speakers in the rear doors are not working for when I turn the fader to +10R there is no sound out of the rear doors.
    Which wires are for the Can-Bus? I'll have to pull up the Bentley manual and start tracing wires. It would be nice to try someone else's Symphony II to rule out the head unit or my wiring.
    -Doug
    San Francisco, CA
    Here's the pins-out diagram:
    Jan 25 2006
    A4 2.0T
    MD
    1 Fault Found:
    Security code after prolonged power loss sounds normal to me.
    Also, no communication from radio to DIS and no face plate lighting also "suggest" a can-bus issue. An issue with the physical layer... Focus on pins 7 and 12 on the A connector.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Thanks guys. When I have some time I'll dig into this. Been out of comission this week due to sinus surgery.
    -Doug
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I reviewed the wiring diagrams and the rear speakers and subwoofer are run off the amplifier.
    I had the radio on (sound out of the front door speakers and dash center speaker) on Saturday. No sound out of the sub. I then unplugged the amp and no change (still sound out the front).
    What I don't understand, from the wiring diagrams, is how the amp is tied to the CAN-bus?
    I have a lead on an amplifier to see if this fixes the problem.
    -Doug
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I figured out the problem and thought I'd provide closure to this thread.
    1) I overlooked the most common of items.... Check the Wiring Connections.
    I have a Pioneer Avic D3 I am getting ready to install so I've been going through the wiring to make sure I have that all figured out. In doing so I have been studying the Symphony II non-bose wiring outputs. When viewing my car's Symphony II I only had two connectors plugged in.. The one for power and the one for the front speakers (non-bose has front speakers run off the head unit and the rear speakers are run off the subwoofer).
    There is supposed to be a third connector (labeled 'A' in Steph's post above). Upon digging [elbow] deep into my dashboard in search for any loose connectors I found it! The third connector that provides signals and power to the amplifier and rear speakers. When I connected that to the Symphony II I know have the rear speakers working and the sub working and the DIS lights up and the radio lights up when the headlights are on.
    SO, I just somehow did not connect that third plug when I had the stereo out for the very first time a little over two years ago. CAN-bus code is now gone.
    I missed this because I have been so focused on the engine modifications and getting the car running well with proper software. Now that I have achieved that I have been slowly going through the other issues and found my mistakes.
    My mistake, your fortune.
    -Doug
