Results 1 to 20 of 20
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    Rear washer nozzle clean and adjust DIY
    I had a problem with my rear washer nozzles not spraying the correct pattern, so I went to adjust the sprayer jet with a small needle, and it broke off in the nozzle
    So I needed to remove and clean out the rear washer nozzle - here's how I did it:
    Remove the rear washer cover by pulling outward on each side - this releases tabs on the left and right, and then you can pull the cover off:
    Then you can get to the nozzle. This can be removed by using a small flat blade screwdriver - put it right where arrow is and very gently and carefully pry on the nozzle, slowly working it off of the base of the wiper:
    You will then have the washer nozzle base exposed and the nozzle and jets can then be cleaned:
    There are two washer jets on the A4 Avant. They are a simple ball jet that can be adjusted by rotating it in the nozzle housing using a small needle. I found that the ball jets had seized in the nozzle housing and wouldn't move. So, after removing the part of the needle I had broken off trying to adjust it earlier, I soaked the entire nozzle in some RP Max Film.
    This stuff kicks ass - better than any Teflon based lubricant I have ever used! It's about $8 for a small spray can, but little goes a long way.
    Then using a pair of locking pliers and another needle, I worked the ball jets until they moved freely in then housing, and then blew it out with my air gun:
    After it was clean and the ball jets were both moving freely, I put it all back together again, and then was able to adjust the nozzle spray pattern to spray the rear glass.
    Then the rest of the car got a wash:
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    Re: Rear washer nozzle clean and adjust DIY
    Nice write up...rep point for you my man!
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Jan 24 2008
    West Coast
    ^ Agreed! Nice job Mike. +1 Rep!
    Moderator
    Sep 11 2009
    boards n wax
    Huntington Beach
    x3
    rep to you my man.
    Mar 08 2007
    Air and water
    SATX
    Thanks guys!
    After doing this, the wiper and jets work well, but I am thinking of getting the Euro wiper from DTH. I upgraded the front to Aero, and it was a world of difference. It would be an easy swap and wipe better. Does anyone have the rear Aero kit installed? Pics of the blade etc.?
    -Mike
    @countdowngarage
    Senior Member Two Rings xattica's Avatar
    Dec 12 2009
    12 Lotus Evora, 19 Countryman PHEV, 07 Cooper S
    San Juan, PR
    I have problem with the right headlight washer. After use, it get stock on the bumper and do not enter back again...
    2000 Audi TT 180 * 1996 VW Cabrio AT * 2000 A4 1.8T Quattro Avant AT Stage 3 (sold)
    Mar 08 2007
    Air and water
    SATX
    Quote Originally Posted by xattica View Post
    Sorry, can't help you there - I have not torn into the front washers, just the rear.
    -Mike
    @countdowngarage
    Senior Member Two Rings IVRNGS's Avatar
    Apr 27 2007
    2002 A4 Avant 3.0 ATQ
    Houston, Texas
    Excellent DIY...
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Probably cracked underneath. You can remove the cover by pulling up on it and ther are little pin detents that let the cover come off. Once off check the sprayer to see if it is loose, it should not wiggle at all. The whole assembly is easy to remove but you have to pull the front bumper.
    Nice write up op, my one nossle shoots clear off the glass so maybe this will inspire me to go fix it. Stoopid car broke down and is just sitting in the garage anyway!
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Jun 27 2011
    Glad I found this. Bookmarked for future use as my rear sprayers simply don't work. Hopefully its just a clogged sprayer...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Orange County, CA
    I think I have the same issue on my B5. I didn't even know that the rear wiper had a washer nozzle... I thought it was just for rain. I may have to take apart the back of the hatch to remove the nozzle.
    B5 Parts For Sale
    Jun 27 2011
    Well two weeks back I dig into this. The pump was functioning properly so I popped the sprayer cover off and tried the sprayer again and fluid shot out of it. It was clogged sprayers after all. So I just cleaned the nozzles with paper clip and it is good to go.
    Posted from my iPhone. Any misspellings are Siri's fault.
    -CP
    2017 Q7 3.0t
    Mar 08 2007
    Air and water
    SATX
    Good to see this thread coming to some use
    -Mike
    @countdowngarage
    Jan 25 2016
    PA
    Nov 30 2016
    London
    Sorry to resurrect an old thread but, along these lines, I removed the rear washer jet to clean and now it doesn't seem to fit too well on the nozzle. It seems looser than when I prized it off, so water is coming out from the bottom of the jet and pooling around the nozzle, with only a weak spray from the (now clean and descaled) jet. Any ideas how the jet might be fitted back more firmly?
    Mar 08 2007
    Air and water
    SATX
    Quote Originally Posted by tdfg83 View Post
    Not a problem at all. I'd say as a guess that either a.) the nozzle assembly has a crack or break which is causing it to not seal or b.) the rubber seal has broken and/or is missing.
    Can you take a look at the nozzle assembly where it connects to the nozzle and get a visual on the condition?
    -Mike
    @countdowngarage
    Orange County, CA
    This reminded me that I still have not fixed my rear nozzle after 3+ years. But I have a B5, the OP's B6 may be different.
    Sent from my iPhone
    B5 Parts For Sale
    Nov 30 2016
    London
    Quote Originally Posted by MikeWire View Post
    Ah! That could be the problem then, I can't see a rubber seal. So that is a third part then, between the nozzle on the windscreen wiper base and the jet? Maybe it pinged off without me noticing when I prised off the jet? Any ideas where I can get a replacement seal?
    Nov 30 2016
    London
    Ah! That could be the problem then, I can't see a rubber seal. So that is a third part then, between the nozzle on the windscreen wiper base and the jet? Maybe it pinged off without me noticing when I prised off the jet nozzle? Any ideas where I can get a replacement seal?
    Update to the above, there didn't seem to be any missing part, but perhaps I'd slightly damaged the jet nozzle when removing it. I got a new one and it pushed firmly back into place with no leaks. All sorted then!
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Good info!
    Mine gets clogged all the time. I've cleaned it 3 times in the past 8 months.
