Yesterday I switched my coils to Hitachi E's and changed the spark plugs to NGK's. I seem to be running ok, but this evening I threw four codes, all of which seemed to have nothing to do with the coils directly. I cleared them, then later the CEL came back on with this one code, which is repeated from earlier:
Address 01: Engine
Controller: 4B0 906 018 M
Component: 1.8L R4/5VT G 0002
Coding: 16251
Shop #: WSC 06335
1 Fault Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
Readiness: 0000 1001
Does this mean that the coolant sensor is toast? The engine temp gauge seems to work fine. Or is this a bad connection?
