Results 1 to 8 of 8
Thread: BPY vs. TFSI
    Senior Member Two Rings BIG EYE's Avatar
    Sep 22 2005
    A4 USP 3.0Q/A3 SLine
    San Diego
    BPY vs. TFSI
    Sorry if this is a dumb question, but i am new to the 2.0T motor and i am not finding the info via search.
    What is the difference between the two and how do you tell what you have?
    Thanks,
    Oct 30 2006
    2011 GT3 RS, 2011 C63AMG, 2012 E63 Wagon, 2010 ML550, 2006 A3 commuter
    ca
    Re: BPY vs. TFSI
    one is chain one is belt.
    Sep 22 2005
    San Diego
    Re: BPY vs. TFSI
    Quote Originally Posted by tpliquid View Post
    which is which? How do you tell what one you have?
    Established Member Two Rings Krieger's Avatar
    Aug 02 2009
    2006 Audi A3
    Winter Park, Fl
    Re: BPY vs. TFSI
    FSI has a belt, TSI has a chain. that is not the only difference.
    the HPFP on them is different as well as the TSI has it riding the rear cam and it holds more boost for longer, thus allowing much more power and its roller follower so its much more relibable than our flat tappet follower on the FSI.
    both are dirty.
    both break down semi-frequently...
    both have numerous issues. You have to keep up on your maintence and check ur oils and change it out alot more than a normal engine.
    you gotta pay to play. :-) If you can keep the beast happy, she will pull strong and pull hard.
    Jul 30 2008
    08822, Jersey
    Re: BPY vs. TFSI
    if it says tsi. its chain. if its says fsi its belt. this is all on your engine cover
    Apr 13 2009
    Kitchener, On
    Re: BPY vs. TFSI
    wait....I don't get these abbreviations
    From what I understand right now:
    FSI - 06+ 2.0T in north america
    (In asia, golfs are sold with 1.4FSI, 1.6FSI that has no turbos, & its just a plain direct injection engine)
    TFSI - 08.5+ 2.0T (You guys call it TSI? isn't this the name for that 1.4 twincharger engine in europe?)
    Can anyone clear this up for me :S
    Sep 22 2005
    San Diego
    Re: BPY vs. TFSI
    Thanks for all the info! I also posted this on Vortex, and got some good info that helped clear things up.
    http://forums.vwvortex.com/zerothread?id=4695667
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: BPY vs. TFSI
    Quote Originally Posted by tdota3mike @ vortex
    TFSI ( what vw calls the BPY) = FSI (what audi calls the BPY) = BPY(engine code)
    TSI ( what vw calls the CCTA) = TFSI (what audi calls the CCTA) = CCTA (engine code)
    bpy is an engine code just like aeb, or awm, or ccta,
    bpy is a turbocharged 4 cyl with fsi (fuel stratification injection)/direct petrol injection
    other engines have fsi including the 4.2, 3.6, and 3.2, but these engines are only fsi, not tfsi (turbo). the "tsi" ccta is just the second gen version of the original 2.0tfsi. it has a slight bump in hp, a canister oil filter that is inverted and mounted at the top, and most notably, AVS which is audi valvelift system. it activates a high lift cam lobe at higher rpm, in addition to adjusting the cam lobe positions to alter the opening and closing of the valves. similar to vtec on hondas, but it is actuated by solenoids rather than oil pressure.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
