Results 1 to 9 of 9
    Senior Member Three Rings jpcallmotor's Avatar
    Jan 11 2009
    B5 A4 1.8T
    Chicago
    Mobil 1 Synthetic ATF OK for power steering?
    Can I use Synthetic Mobil 1 Automatic Transmission Fluid in my powersteering system. I have heard a few guys use it with no problems. Obviously I will flush the existing fluid out first. I searched and really didn't find much info. My steering system is fine with no noises, just fixed a minor leak at the cooler. I think it would be a good time to flush out the system because the fluid looks pretty old and dark. If not I guess its off to the dealer for some G004 of whatever they call it, the green fluid.
    Aug 13 2008
    Indiana
    Re: Mobil 1 Synthetic ATF OK for power steering?
    I doubt it would hurt it but I would just buy the correct stuff....
    -Nic
    Veteran Member Three Rings Oceanside's Avatar
    Dec 12 2008
    2001 A4
    St Pete FL
    Mine had a small leak at the cooler too and it drained, all of it, then pump fried. Just fix the small leak and fill with correct stuff and not have to worry about it
    Veteran Member Four Rings salz2135's Avatar
    Sep 15 2005
    Austin, TX
    Audi recommends MINERAL based power steering fluid. Regular power steering fluid will not work nor will automatic transmission fluid. If you have filled your reservoir with anything else, I would recommend a flush with OEM or OEM equivalent mineral fluid ASAP to minimize the damage. The components and associated labor costs we're talking about here are not cheap.
    If you don't use the mineral based stuff, the internals can be damaged and your system can develop leaks and require replacement.
    Veteran Member Three Rings iwearpro's Avatar
    Jul 28 2007
    Forsyth Illinois
    This is the stuff they put in from the factory. I bought a bottle at Napa.
    http://www.globalautoparts.biz/pento...ic_fluids.html
    Jan 11 2009
    B5 A4 1.8T
    Chicago
    Brian, thanks for that link I will check out NAPA for that 11S.
    I haven't touched the system yet. I have seen a few guys run Mobil1 ATF with no problems, and was skeptical if that would work, seeing that it is more readily available fluid at the parts store. I'd hate to add something different and see my rack leak. I will for sure order the green German Pentosin or OE fluid when it comes time to flush my system.
    Jan 29 2007
    08 S4 00 S4
    MD
    I run straight Mobil1 ATF after replacing my power steering pump a few years ago. No issues. Complete flush and refill, don't just dump it in.
    08 S4- Stock SOLD
    Veteran Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    ive got a power steering leak that is driving me crazy! it seams like everytime i find it and fix it it starts leaking from somewhere else haha im almost ready to buy all new hoses and pump (i already have a new tank) and just redo it all together! end rant haha
    If I hit the switch, I can make that ass drop.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    mobile one synthetic atf does work. And its so much cheaper and more available than pentosin stuff.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
