Results 1 to 11 of 11
    Active Member Two Rings ViperJ's Avatar
    Aug 16 2009
    2001 A6 2.7T TIP
    Issaquah WA
    Battery Swap, Will it Require Radio Code?
    I have tested my battery on my Audi and it is okay but struggles on cold mornings so I will be replacing it. My question is, when I unhook the battery will that reset my radio and make it so a dealer has to enter the code? If so is there a way to pull the code before I swap batteries?
    BTW I did search, couldn't find anything with people before they needed the code. plenty of people after they switched batteries
    2001 A6 2.7T, TIP
    Previous Cars
    -2007 STi (Stage 2)
    -1999 Corvette (650hp NA, 200 Shot Nitrous)
    -1994 Camaro (Lightly Built)
    -1994 TransAm (Lightly Built)
    etc...
    Senior Member Three Rings JohnUSMC's Avatar
    Jan 13 2009
    07 B7 A4 2.0T Quattro
    Dallas, TX
    Re: Battery Swap, Will it Require Radio Code?
    my code was located on a sticker in the spare tire well... look there!
    Veteran Member Four Rings khalimadeath's Avatar
    Nov 18 2009
    70 VW Bus, 64 VW Bus, 13 Q7, 18 S5 SB
    Reno NV
    Yes if ur battery dies or u replace it u need the radio code. u have to hold down 2 buttons then put it in. i dint know where the radio code is or how to get it mine was written in car manual by previous owner
    -Zach-
    The C5 Union////////////
    The United States Constitution
    (c) 1791. All Rights Reserved
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    my radio code is on a sticker in the Bose pamphlet that came with the car.
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    Senior Member Three Rings JohnTC's Avatar
    Mar 30 2009
    '02 A6 Avant, '06 525xi
    North Jersey
    I replaced my battery and did not need the code. I think you only need it if the radio is removed. My car has also had the battery disconnected for several days when the TC was changed. No radio code needed.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    It depends on the situation. If you are just replacing the battery, you should be fine. The cars electrical system should have plenty of juice sitting in it to maintain the code. As JohnTC mentioned, I have had my car with the battery unhooked for days and not had a problem. Same thing with actually removing the radio for some time and then putting it back in. It would just start right up. That being said, I have also seen cars that needed the code entered when any of the mentioned actions took place.
    If the code isn't written down somewhere, you are at the mercy of the stealership .
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Established Member Two Rings Tik-Tok's Avatar
    Apr 19 2009
    '03 Allroad, '91 MR2, '72 GTO
    Calgary, AB
    Couple of weeks late here, but you shouldn't need the code. I had my battery unhooked for almost 4 weeks, and it was fine.
    APR stage 1, APR R-1 diverters, H-Sports, Custom boost gauge (in mirror), 40/20 tint, Westfalia Euro-hitch.
    Aug 04 2008
    I just replaced my battery this weekend -- you do not need a radio code. Just pull the battery out and put the new one in. Good luck!
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    If you guys do need codes I have a guy that will get them for a 20 spot.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Veteran Member Three Rings patrick23's Avatar
    Dec 09 2009
    2004 Audi A6 S-line, 2001 Nissan Pathfinder SE, 1999 Subaru Legacy Outack Limited
    val-des-monts quebec
    well if you need a code in the end dont worry....
    i replaced my battery on my old A4 years back and needed a code- went to the Audi dealership, gave them my VIN and they gave me my code in seconds.... free too, I'm thinking it may even be done over phone.
    Veteran Member Three Rings ChescoS6's Avatar
    Jan 13 2007
    2012 Golf TDI 2003 Ducati ST4s ABS 2007 Ducati Monster S2R
    PA
    A little late but for future reference......
    "The Symphony II radio has "Smart coding", which makes it unnecessary to enter a code to unlock the radio as long as the radio is installed in the car that it belongs to, even after disconnecting and reconnecting battery power. If you are installing a Symphony II radio in a different car than the one it came in, you must enter the code to unlock the radio. "
    HERE
