Results 1 to 27 of 27
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Removing dried on painters tape
    Anyone know of a good method to remove dried on painters tape? Apparently the painters tape I put on my fenders and hood to prevent from scratching has cause more bad than good. Keep in mind they have been on my car exposed to all elements for almost 7 months
    Its very similiar to removing wallpaper. Its just peel a very little bit.
    -Sami-
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    Re: Removing dried on painters tape
    painters tape all have time limits printed on the labels...
    for future reference..
    goo gone? or stuff like that?
    Veteran Member Four Rings Vince Stark's Avatar
    Jul 30 2009
    Dallas
    Quote Originally Posted by Kwarner View Post
    well i think he know that by now...lol
    OP try soapy water or a regulal detailer
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    soak it in goo gone...good luck.
    generally goo gone works, but you need to soak it for hours.
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    i wouldnt mant goo gone sitting on my paint for hours. Buy a pressure washer.
    High speed Ferrari movement...
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    I would use some 3M adhesive remover, which should be paint safe, then use some clay bar and finish up with some wax and sealant.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Mar 27 2005
    The Cold North
    Quote Originally Posted by MikeWire View Post
    2nd that. the 3M adhesive remover works well and is safe on paints.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings Sandeman's Avatar
    Feb 15 2009
    2003 MB SL500
    where the horseman roams
    GOOO GONE FTW, or use Tar-Sap remover from NAPA
    ive used them both, and theyre the same to me...
    i would also use WD-40, and douse the tape in it first, and then peel off the tape, afterwards, apply another coating of WD-40 and use a credit card wrapped in a soft rag and go over the residue that was left behind... give your car a simple wash after that use the the GooGone or similar with a dry cloth and wipe off
    then give your car a nice bath and it should be good as new
    that was mine
    Jun 29 2007
    Raleigh, NC
    turtle wax bug n tar remover did the trick for me in the same situation. i actually lost some paint over it too....
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jul 14 2009
    Pasadena
    goo gone...the orange kind! and be sure to wipe the spot down with water after
    Veteran Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    remember anything you use to get it off, 3M adhesive remover or GOO GONE you'll need to rewax after as it will strip your wax. i recommend 3M adhesive remover.
    02 Avant 3.0 // Avant Garde Member // 3.0 Group Member
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Paint reducer SPARINGLY works wonders. Worked for me where goo gone failed
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Deactivated Four Rings
    Sep 30 2008
    n/a
    Use a heat gun. Heat it up and peel away. Then use some water based paint thinner. They sell a natural paint thinner that won't harm the paint.
    Oct 01 2009
    Parma,Oh
    Vegetable oil - saturate the tape and it will soften the adhesive. much more safer than goo gone.
    Jul 30 2009
    Dallas
    Quote Originally Posted by TTMK2_TJ View Post
    that was mine
    that is a nice tape job u had there
    Buncha motorcycles
    Memphis, TN
    ask jake, he had half of his a4 taped up for the road trip home
    APR Stage 2/AWE Intake
    Feb 19 2007
    Charleston, SC
    Thanks guys. Had I known there was a life expectancy on blue painters tape I would have never put it on
    Ill try the heatgun method first....have one sitting right outside
    -Sami-
    Veteran Member Four Rings Chris_tA_4's Avatar
    Dec 12 2006
    B6 A4
    Orlando
    try those drier sheets that you use for clothing. Soak it in soapy water first, then start scrubing the sticky residue.
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    see, a while ago some dude posted a thread about getting his new A4 driven a 1000 miles or so home and the front end was taped. there were a lot of people that asked why, and i can see in that case where its a good idea to keep rocks and debris from chipping the front. but the two cars posted above i see no reason to do that. why? i dont think it looks cool or trendy at all, i think it looks horrible. sorry only imo. its like the people who leave their oversized FMICs hanging down and without grilles with chrome tubing protruding just to show it off. that looks gaudy.
    Nov 02 2007
    SF Bay Area, CA
    honestly...for me
    old yellow masking tape with goo gone soaked for an hour worked wonders. i then proceeded to use my finger nail to aggitate the glue off.
    goo gone reintroduces moisture into the glue and turns it into a GEL that can be taken off. goo gone should be safe for paint as long as you wash your car after.
    Sep 30 2008
    n/a
    Quote Originally Posted by zz2h33 View Post
    Well genius. The TT that was all taped up was for a Halloween party at a go kart track. You were supposed to dress up your cars. The second picture posted I am sure was to leep rocks from chipping the fenders up during the long trip home. If you are going go tape your car then you might as well have fun with it.
    Sep 23 2006
    Houston TX
    If you can get some 70% or higher isopropanol (sold as "rubbing alcohol"), that might work too. Cheap and safe on your paint.
    But I'd try Goo-Gone first.
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    Quote Originally Posted by NvrFllw View Post
    sorry didnt know i offended the audizine gods i'll buy stock in 3M.
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    i've heard gasoline works really well actually.
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Feb 19 2007
    Charleston, SC
    Isn't there this special power tool bit that can pick up glue and adhesive?
    -Sami-
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    whatever you do, start with the mildest solution first and only move up when it isn't working. you may find something like dish soap and warm water takes the majority off.
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Oct 01 2009
    Parma,Oh
    use a hair dryer not a heat gun.. heat gun will melt your paint because of the high heat temp.
