Results 1 to 12 of 12
    Senior Member Two Rings 2002.SLC.A4's Avatar
    Nov 09 2008
    Salt Lake City, Utah
    Brown Steering Fluid
    My car has been making slight grinding noises. After topping off the steering fluid (was low) it went away. Today after an oil change its doing slight grinding noises again and my steering fluid is light brown and fizzy.
    Whats the deal?
    .:ERICKA:.
    "i promise you by age 10 chicks will be sucking dick so they can snort lines of pixie sticks" -marty was here
    May 21 2007
    Florida
    Re: Brown Steering Fluid
    a couple things:
    1) its fizzy because its got air in the system, probably from being low. to fix that you just make sure its topped off, leave the cap off, start the car, and turn the wheel from lock for lock a few times.
    BUT
    2) its brown because it need to be flushed.
    2018 Navarro Blue Q5
    Nov 09 2008
    After the fizz was gone I realized it was way low again (hence the noise). Looks like its leaking somewhere but its not dripping in the garage or driveway anywhere, which it should at the speed that it emptied itself (filled up from below min 3? weeks ago or so).
    Where could it be going? Into the steering rack due to faulty seals or anything?
    .:ERICKA:.
    Dec 06 2007
    ^^leaky steering racks are extremely common on our cars.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by 2002.SLC.A4 View Post
    into the inner tie rod boot most likely. i'd feel around and squeeze those to see if you can tell there's fluid in one of them
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    Mine does (or did) the same thing until I tried this:
    I was doubtful until I notice the steering really lighten up and get more responsive after a couple of days driving. I still need to check to make sure it's not leaking, but I have hopes that this solved the leaky seal problem.
    FYI, I was topping my PS res. every couple of months or so. I used about 1/2 the bottle.
    "Compatible with all power steering fluids"
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Jun 30 2008
    Erie, Pennsylvania
    It could be leaking out of the end(s) of the rack and filling up the rack boot(s).
    EDIT: ^ Beat me to it.
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    every time my car leaks it all goes down and pools on the splash guard under the engine. take it off and check for fluid first. then worry about taking the boots off.
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    looks like another victim of a dreaded leaky power steering rack. mine has been leaking for like a year and half, im too damn poor to fix it and i just cant find the point of the leak. im going to try that lucas oil stuff next. i usually just top of my power steering reservoir every month or so.
    Veteran Member Three Rings rpetral0's Avatar
    Jul 25 2009
    http://www.audizine.com/forum/showthread.php?t=332003 my post (#8) with pics on the bottom...that and a do a flush :P
    ...I'm listening
    Jun 22 2008
    SL,UT
    Quote Originally Posted by rpetral0 View Post
    except she drives a 1.8t, not a 3.0. completely different pump and hose system.
    Jun 14 2005
    Anaheim, CA
    I used the stop leak on my car and it worked wonders. I was pretty skeptical at the time since none of these kragen solutions have ever worked for me, but it solved the problem! I think it works by forcing the seals to expand, somebody can correct me if i'm wrong though.
    Brandon @ VMR Wheels
