Results 1 to 15 of 15
    Jan 11 2006
    Houston, TX
    Rear Coilover Install
    Did anybody else do it in reverse like this pic for easier adjustment?
    Mar 27 2005
    The Cold North
    Re: Rear Coilover Install
    i didn't but you can. Once i got the ride height dialed i never changed it after.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Jun 13 2008
    Bay Area
    didn't even know you could do that... lol... it would make it hell of a lot easier...
    Jan 10 2007
    VA
    Some have, I wouldn't.
    Nov 04 2009
    Norcal
    Anyone else install this way, and can offer any guidance? I'm about to install some KW V3 in a week or 2 in my B7.
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    Mine are that way on my Bilstein PSS9. I thought all of them were like that.
    Feb 17 2004
    Liberty Hill, TX
    some CO setups (like KWs)are designed to be installed with the rear spring perch above the spring - others are not.
    I wouldn't install one as pictured in the OP because that perch is made to be installed against the lower frame, not the rubber bushing. There's no guarantee that it's sufficiently stable to not pop out.
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by Matt Devo View Post
    I think someone over at Stasis mentioned about suspension float causing the circumstances to allow the spring to pop out...
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by A4SoftWalker View Post
    yup, that's what I was alluding to.
    Registered User Four Rings CDesign's Avatar
    Jun 10 2009
    West Coast
    Quote Originally Posted by rensho View Post
    that's the right way for kw.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    thats how my KW Variant 3's are.
    i wouldn't worry about the spring popping out, but when you jack up your car, make sure the springs are in the correct locations.
    Established Member Two Rings nezach's Avatar
    Nov 03 2007
    02 A4 3.0 Quattro 6spd
    Chicago, IL
    I have it installed this way and so far have not had any issues.
    Veteran Member Four Rings 617 Bones's Avatar
    Wife's - MK3 GTI VR6 Vortech S/C
    Boston
    Quote Originally Posted by onlyaudis View Post
    How do you like the Bilstein PSS9's?? Happen to know the lowest/highest they go??
    I have H&R Coilovers but think they are too low... and might want to switch it up a bit.
    B7 A4 Avant 2.0T 6MT - Arctic | H&R + B5 Perches | JHM S/S + 4:1 Center Diff | Apikol Snub + Rear Diff Mount | Hawk HPS | Tyrolsport Caliper Kit | AWE Exhaust | 034 RSB + Spherical End Links | 19" VMR v710
    Dec 03 2005
    2 pedals 1FG
    connecticut
    In the end I wound up installing my STaSIS streetsports that way.
    Oonly problem is you still have to loosen the subframe to adjust them. too much spring pressure on the perch and the tool doesn't fit the perch properly. good news is you only have to loosen the subframe about three turns per bolt and then you can easily turn the spring perch to set ride height. Before that I would just pull the whole spring out since I'm adjusting my coil-overs when the car is on a lift (faster to remove spring and adjust the perch by hand than to fiddle with the tool in the control arm).
    -Doug
    Nov 02 2007
    SF Bay Area, CA
    wouldn't loosening your subframe tweak your alignment?
    nevermind, after adjusting your height you should get an alignment anyways.
