Results 1 to 18 of 18
    Veteran Member Three Rings USAFS4's Avatar
    May 05 2008
    2008 Audi RS4; 2017 BMW M240xi Dinan stg 1
    PCC Potomac/Chesapeake
    Driving on BAD MAF/Boost Leak, what are the repercussions?
    Update: I decided to ship the car to Cali. I'll let JHM fix her real good when they build me a STG III
    I've pulled the falling the codes, P1136 & P1138. My research has found that this is likely due to either a bad MAF or Vacuum leak. My gas mileage sucks! And obviously my power does also.
    My dilemma: I need to drive across country soon. Do I
    A) Drive the car 2500 miles, and fix it laters
    B) Let the dealer replace the MAF ($250 MAF, $150 Labor, possible more if Vacuum leak $???) The replacement MAF is a Bosch, and I want to go STG III and will prolly need to convert to Hitachi then; meaning all of the cost is a loss.
    C) Any quick fix I haven't learned of yet?
    Basically, I need to know the damage I'm doing driving on a bad MAF/Boost leak? (I also recently had the O2's replaced, don't want to kill them early)
    2008 B7 RS4, Jackal Tune, w/JHM spacers and Flap Delete
    2012 B8 S4 Stg II APR. SOLD.
    2000 B5 S4 (Audry) Stg III: 390Hp & 435Tq. SOLD. Wish I kept it!
    Veteran Member Four Rings Trigger Happy's Avatar
    Jun 17 2008
    2K S4
    Rockville, MD
    Re: Driving on BAD MAF/Boost Leak, what are the repercussions?
    Pressure test and see if the boost leak is easy to fix. If it is fix it if it isn't your outta luck on that one. Have you tried cleaning your MAF yet?
    "Clearly, a liger is not as practical as a Katana. S4s can't carry ligers. fucking 500lb cat in my backseat using my alcantara as a scratch post for its HUGE FUCKING CLAWS? I dont' think so bro"
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Veteran Member Three Rings wesS4's Avatar
    Nov 29 2007
    1966 Mustang
    San Jose, CA
    Try Cleaning your MAF. report back
    Stage 2 B5 A4 Avant | AWE | GIAC | H&R | OEM+ | BBS | Raven MS | 034 | DDM
    The Auto Shop
    TEAM|AXION is dead. RIP LOL
    May 05 2008
    Quote Originally Posted by wesS4 View Post
    Cleaned the MAF sensor about 3/4 months ago. I'll check, but I'm betting it's still shiny clean.
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    vacuum leak is bad . when car is in idle and not boost, youll be running lean.. then when in boost and is no longer a vacuum leak but boost leak youll be running rich...
    RS6 hybrids and corn
    Nov 29 2007
    1966 Mustang
    San Jose, CA
    Quote Originally Posted by USAFS4 View Post
    I see... Get your car pressure tested ASAP and see if you can't find a boost leak somewhere.
    The Auto Shop
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    boost leaks are what blows turbo's so get that done asap!
    Senior Member Two Rings Jman25's Avatar
    May 18 2009
    98 A4
    PDX
    simple, check ALL!!!! the hose lines. I was having similar problems in my A4 ended up being the small hose line from the intake man. to the fuel regulator, my buddies S4 had the same hole in the same line, lots of heat and such, you can take some brake parts cleaner and and spray each of the connectors where the hoses meet with the engine running and if there is a leak the engine will bog down big time. Dont waist the money on the MAF since you have already cleaned it chances are it is a simple very small hose that needs to get replaced, just make sure you physically inspect and palpate each part because it took me a long while to find that the hose was ruined on my car until I grabbed it and it cracked in my fingers.
    May 05 2008
    Quote Originally Posted by Jman25 View Post
    You wouldn't happen to have a Vacuum hose diagram? Can't find one.
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    After you pressure test, if your still having problems, then change the maf. A bosch maf is 140 bucks new. You can definitely put it in your self. If not I even have a spare bosch laying in my room I could sell you.
    Mar 01 2007
    Ducati 1098s, A4, S4
    Fayetteville, NC; Indianapolis
    Pressure test NOW! lol as far as the mass air flow I've never had problems driving with it unhooked. The audis and VWs Ive played with run fine with or without the mass airflow.
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    not to thread jack I but what code are you getting for your MAF?, i scanned my car and mine came up as signal to low. I never cleaned mine since I owned the car, should that help or just replace it?. Also I am going full stage 3 in about a month or so I dont want to buy a new bosch MAF, and then pay again to switch to the hitachi. If I clean it a still get a code and decide to get the hitachi with the wiring will it run fine even though my cars a 2000. Or will the ecu have to be tweaked for the hitachi.
    10 b8 s4 6MT sprint blue / black & silver
    Sep 28 2009
    ky
    Quote Originally Posted by koolkoreanked View Post
    WHAT??
    Established Member Two Rings chriswstprt's Avatar
    Jan 24 2009
    00 a6 2.7t 6sp.stg 3+,03 20th A.E.gti w/gt2871r, sold 87 mustang gt.EURO all the way!
    trumbull ct
    don't know about you but any maf f.i. car i have owned or worked on needs the maf to work right.
    Veteran Member Three Rings GarbatyA4's Avatar
    Aug 10 2007
    Ontario Canada
    if you have a boost leak, you don't want to run your turbo charger out of its efficiency range.
    will help result in premature failure.
    leak test it and fix it.
    2012 Audi Q5 - Daily (slow AF)
    2013 Mini Cooper S - sold
    2005 BMW 325Ci - sold
    2007 BMW 335i - sold
    2004 VW Golf TDI - sold
    2004 Audi S4 V8 Cabriolet - sold
    2003 Audi A4 1.8T - GT2871R - sold
    2000 GMC Sonoma - sold
    1992 Dodge Stealth RT - sold
    1991 Chevrolet Beretta GTZ - sold
    Mar 01 2007
    Quote Originally Posted by chriswstprt View Post
    These cars run just fine without the maf hooked because there is a map sensor as well... Go unplug your maf and drive... Sure the car can't fine tune itself and sure it won't stop over boost but down the 1320 I've seen the same times hooked or unhooked. I got tired of my a4 eating up maf sensors so I just unplugged the last one that went out and drove... Now if the car only had a mass airflow meter then it wouldn't even start with it unplugged.
    May 05 2008
    My car has always had a rich fuel smell since I've owned her. Think I've had an engine light on ever since as well(or after the chip which was first mod). That's 70k to 130k. If I had a boost leak I don't think I could have made it this far. Well no time left. She's getting shipped. I so wanted to drive her cross country and document it.
    Oct 01 2009
    brooklyn
    im having sort of a similar problem with my a4. i replaced the air flow meter but saw no improvement. i cant seem to find where my air leak is coming from.
    my cat keeps glowing red, along with my turbocharger and my BRAND NEW coils went as well.
    any ideas on what to do?
