Results 1 to 39 of 39
    Veteran Member Three Rings jeffp477's Avatar
    Jun 09 2009
    1982%20porsche%20924/%2005%20VW%20Touareg%20V8/2018%20VW%20Tiguan/%2717%20Triumph%20Street%20Twin/82
    temecula,ca(socal)
    exhaust diameter..
    ok guys who knows the diameter on the oem exhaust for c5 2.7t... need it. pls..
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    Re: exhaust diameter..
    i think it is 2.25" OD. but dont take my word on that.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Jun 09 2009
    temecula,ca(socal)
    Quote Originally Posted by 4Ring_Jelly View Post
    that what it looks like, but i want to make sure... still trying to do research, very hard to find info on this.. thanks. though..
    Veteran Member Four Rings 2001A6's Avatar
    Sep 17 2008
    Stuff
    St. Charles, MO.
    the 2.8 is 2" OD.
    ~Matt.
    - PES Supercharged 01 A6 2.8Q
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Veteran Member Three Rings awtst3.a6's Avatar
    Nov 08 2008
    2000 s4, 2001 a6
    Va
    ding ding +rep
    I believe the s4 has 2.5 piping vs. the a6
    auto GT a6 - is here.....
    "I compare it to a centerfold model.Just because her measurements are great doesn't mean she's a good lay"
    Jun 09 2009
    temecula,ca(socal)
    ok so far the only thing i found.. oem a6 has a 50mm diameter which is about 2inches... well it is 1.97 and a bunch of numbers following that but ill stick with that which is considerable for a 2"... lol.. so the stock a6 is losing hp cause of flow, not like their brother s4 that has the same 2.7t engine which AWTST3.a6 mentioned that it has 2.5.. well that sucks..
    Sep 18 2006
    Colorado
    that might be the diameter of the 2.8 exhaust. i will go out to my car in the next day or 2 and see what the circumfrance of the tubing actually is and then find the diameter.
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    The S4 and A6 have the same diameter downpipes, the cat back exhaust is 2" ID not 2.25", I promise you
    I don't think I care anymore
    Nov 08 2008
    2000 s4, 2001 a6
    Va
    Quote Originally Posted by jeffp477 View Post
    Ehhh, with 2.0" piping it doesn't limit what you can do and isn't always a disadvantage. Some people set cars up like this for back pressure (on a turbo'ed car). My guess is audi did research with the 2.5 before they looked at the 2.0". They prob sound out that there was a lack of back pressure with the amount of piping used in the a6 vs s4. Causing them to go with smaller piping which in this case for our car might be better. I understand higher flow = more horse power but that doesn't mean you will be boosting off the line :D.
    Nov 08 2008
    2000 s4, 2001 a6
    Va
    Quote Originally Posted by nothing77 View Post
    it is 2.25" OD and 2.00" ID... I have messed with my exhaust 3-4 times. :D The s4 is 2.5 OD and prob 2.25 ID... Leaving a .25 inch difference which is huge in exhaust talk. Yes the cars do have different piping.
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    C5 2.7 2.25"
    b5 s4 2.50"
    C5, Giac, 2Bennet , UUC, snub, 034, piggies, RS6 SE catback, rear S4 BBK, RNS-E, JHM, darintakes, K&N, forge, samco, rs6 reps, OZ Ultraleggera, phat box, 4.2 blades, clear corners, LED tails, tinted - SOLD
    Rolling on AR 402, H-sports, Milltek Turboback, O.CT tune, LWFW w/RS4, Stoptech ST-40 332mm fitted in stock 17", hyperboost BPV, Quad-xenon
    Aug 04 2007
    I deleted my mufflers, the exhaust tubing I had to buy to put in place was 2" ID, so either I got really screwed on my factory exhaust, or the A6 2.7t came with 2" exhaust, I also believe that the S has the same size exhaust, since I am running S downpipes to stock OEM straight pipe axle back
    Apr 01 2008
    Massachusetts
    B5S4 has 2.5" OD tubing including the DP's.
    so your 2" ID is the same as 2.25" OD...? and your S4 DP also is 2"...?...hmm
    Aug 04 2007
    Then read what I posted before commenting, I clearly stated ID, that is how you measure exhaust tubing, by the amount or space open inside the tube, not outside the tube
    Apr 01 2008
    Massachusetts
    so whenever we talk about exhaust diameter, it's ID...?
    but we always say we have 2.25" and S4's have 2.5"...which are OD...
    Nov 08 2008
    2000 s4, 2001 a6
    Va
    Quote Originally Posted by mike's machine View Post
    to nothing:
    You say OD..... ID is a given. What are you going to bitch about next? HP vs WHP? Stop being so technical to make your self right.
    Aug 04 2007
    My experience is that Audi calls it by ID, so that's how I call it. It always sounds better to state the OD as it is bigger, sounds faster.
    Nov 08 2008
    2000 s4, 2001 a6
    Va
    No.. it is just nice having your exhaust connect together vs all of the shit/clamps you would need to do to get a smaller OD exhaust to work (with the same ID)... If you didn't measure both OD/ID before ordering parts/piping... you aren't smart.. How else do you piece a exhaust system together.... annnnnd on the topic yahhh that is why they call them 3.0" exhaust for the s4's.... They sound bigger stronger(from a sales stand point)....What are they relating to when they say 3.0" exhaust? OD? not ID..... I don't think anybody here is claiming that 2.25 inches is big/bad/faster.... I think you just need to chill out.
    Aug 04 2007
    I am only trying to point the OP in the right direction, which I see he was alreday doing himself. I am very chill, I just dont want to see some poor guy order a bunch of tubing, only to find out it is not what he is looking for. I always stated that I was speaking in terms of ID, check my original post. I was not wrong, we apparently just have a different view of how to size exhausts.
    Nov 08 2008
    2000 s4, 2001 a6
    Va
    Let me refresh you how this happened again....
    I agree with 4ring_jelly "2.25 OD" as quoted...
    Then you go along the lines saying.....
    ??? So stop being technical. You say 2.25" is wrongin the quote in relation to the previous post by 4ring and i? Yes or no. You then try to turn the tides with ID vs OD... Honestly just stop.
    Now you have mislead the OP and he is confused and unable to get help from the forum. Congrats. Also I measured the ID/OD when I got my piping unlike you(car exhaust off). So how would u even know.
    Notice how the apr 2.5 piping fits to the stock exhaust (2.25). It is just a piece of exhaust but you can see it needed a good bit of weld to fit.
    Aug 04 2007
    I am truly sorry that you feel I mislead, I just found that OTS 2.25" OD was a sloppy fit when I was putting my exhaust together. That is why when I ordered my parts, I ordered 2" ID. There is no need for name calling, I am aware that you and I have a history on another forum, but let's not bring that over here.
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    Jeff -
    I assume you got all of the above. What are you thinking of doing?
    wofman
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Aug 04 2007
    Thanks for the reality check Wofman, back to the OP, what are you thinking about doing?
    Sep 17 2008
    Stuff
    St. Charles, MO.
    One last thing, we didnt get screwed on pipe size, remember the C5 has true duals, where ther S4 does not. pipe might be slightly smaller, but I bet the flow volume with duals and not is pretty similar.
    Sam, thats how mine looks from stock to 2.25 inner.
    x3 what is op plannign to do....
    ~Matt.
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Sep 18 2006
    Colorado
    Quote Originally Posted by 2001A6 View Post
    THIS.
    the math:
    if the A6 has 2" ID x 2 pipes: pi*(ID/2)^2 = pi*(2/2)^2 = 3.14 x 2 = 6.28 sq inches
    if the S4 has 2.25" ID x 1 pipe: pi*(2.25/2)^2 = 3.98 sq inches
    Aug 04 2007
    I was only being sarcastic about getting screwed on exhaust sizing, I did the same math that 4 Ring did, that is why I opted to stay with stock sizing on my muffler delete. I think that the flow is sufficient to sustain stage 3 power at the altitude that I am at. However, for depth of sound, I wish I had gone with 2.5" ID, the 2"ID tends to be slightly raspy at part throttle
    Jun 09 2009
    temecula,ca(socal)
    Quote Originally Posted by wofman View Post
    Jeff -
    wofman
    well thanks to all the help guys...
    and yes wofman figured out what i'm planning to do... like nothing77 says, the 2 inch is ideal, but i think i'll be running 2.25 from the cats still debating to put x2 resonator or an x-pipe for the droning noise, no mufflers, just putting tips... so it wouldnt look ugly at the rear seeing stainless steel.
    so what do you guys think about that setup?
    favor on resonators or x-pipe..
    Sep 17 2008
    Stuff
    St. Charles, MO.
    THIS.
    the math:
    lols, it was late. I think the A6 has more restrictions in the system, S4 has 2 suitcase mufflers/resonators, and the A6 has the big res, the small res, and 2 mufflers.
    Also, the S4 has duals up to the res, then its single, there fore it is alot closer than that figure.
    I now have an x pipe. Kills the drone, but not sure on the sound. Inside the car its great, but is real raspy outside.
    ~Matt.
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Jun 09 2009
    temecula,ca(socal)
    i guess ill do the combination of both 14" resonator and x-pipe with no muffler just tips..
    but how raspy does it sound? i need to hear it though...
    Sep 17 2008
    Stuff
    St. Charles, MO.
    I have video footage, just need to load it onto youtube. I will post it for you.
    ~Matt.
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Jun 09 2009
    temecula,ca(socal)
    that is so cool... i know kievisky has a nice setup, but he running with no cats, and his running a full custom set up too..
    thanks..
    i'm adding you of my fl.. are you on the facebook acct that kievisky made for the c5's?
    Sep 17 2008
    Stuff
    St. Charles, MO.
    yep, I am. and no problem, videos are up loading now.
    Previous set up.. Remus mufflers, resonator delete, all cats, no x pipe. Droned like a bitch! but sounded amazing outside...
    sound starts at 30secs, skip to that.
    http://www.youtube.com/watch?v=8h42DObnBmM
    ~Matt.
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Jun 09 2009
    temecula,ca(socal)
    Thumbs up Re: exhaust diameter..
    cool.... thanks for the vid clip...
    Sep 17 2008
    Stuff
    St. Charles, MO.
    ~Matt.
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Veteran Member Three Rings ccomengee86's Avatar
    Feb 17 2009
    '03 allroad 2.7T
    Dayton, OH
    2" ID. At least on my allroad.
    Apr 01 2008
    2010 Jetta TDI
    I opted for engineered catback system (Milltek -- used, fortunately for the purse) behind AWE DPs, so I didn't have any risk or uncertainty re sound/drone or with performance (clean and mean). Milltek uses resonators and mufflers -- no drone, no rasp. Not as aggressive as most folks here might want. More of a low, gentle growl.
    Jun 09 2009
    temecula,ca(socal)
    that sounds like a nice set up as well. im still quoting about putting cut offs on mine for the cats..
    Veteran Member Four Rings khalimadeath's Avatar
    Nov 18 2009
    70 VW Bus, 64 VW Bus, 13 Q7, 18 S5 SB
    Reno NV
    I got the same problem ive been searching and came across this thread seemed logical to just add to this thread. what is the OD and ID on an 01 C5 4.2 cause i cant find that shiz anywhere
    -Zach-
    The C5 Union////////////
    The United States Constitution
    (c) 1791. All Rights Reserved
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    I had a cat go bad on those piggies, and ended up just getting them cut out for now. So, piggies with gutted pre-cats, straight pipes instead of the larger cats, and 2.5" pipes back to Magnaflow's. A little more aggressive than I want, but until I save up to get a good set of downpipes...
