Results 1 to 6 of 6
    Jul 17 2009
    Philadelphia PA & Pikeville KY
    1-MPH Speed warning lamp... HOW TO TURN IT OFF
    Hey Guys,
    I did a little search on my recent issue and I cant seem to find an exact match so I'm sorry if this has come up before.
    Today while driving my 04-A4 1.8 T/Q the little speed light came on and I was unable to turn it off.
    It looked something like this {1(MPH)}. When ever I went over 10 mph the thing came on... when I pulled to stop lights it went off.
    I know I must have inadvertently set the speed sensor.. but I cannot imagine how. While driving I tried the "CHECK" Button on the dash but the light stayed on. It was only when I slowed to below 10 mph that the light went off.
    At a stop I hit the check button again and it ran through the diagnostic with all signs clear... But this is really annoying so advice is most appreciated and welcomed.
    Cheers
    Martin.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: 1-MPH Speed warning lamp... HOW TO TURN IT OFF
    while you are driving hold the "CHECK" button, until a line runs through the little mph sign...signifying that you just turned that feature off
    -Sami-
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    wgile you are driving hold the "CHECK" button, until a line runs through the little mph sign...signifying that you just turned that feature off
    x2
    High speed Ferrari movement...
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    I believe that the answer to this question is also in your owners manual.
    RS4 Rear Sway :: KW V1 Coilovers :: B5S4 Calipers :: W&L Catalytic Converter :: 30% black tint :: S4 Door Blades
    Veteran Member Four Rings Lusticles's Avatar
    Nov 04 2009
    a lemon
    Quote Originally Posted by numer24 View Post
    yes ^^
    Jul 17 2009
    Yes... I agree too.. I am sure the answer is IN the owners manual... however since I have bought my car used.... I Dont have an owners manual, and I am currently out of town and my shop manual is at home....
    Thanks for the informative replies folks... I will let you know if I was able to get it to turn off.
    Thanks
    Martin.
