Results 1 to 11 of 11
    Senior Member Three Rings nyca4tqm's Avatar
    May 26 2009
    American, German, Japanese, English...
    Orange ****y, NY
    signs of a bad HID ballast?
    I just installed my DDM 55w 5k kit, the right light will come on 1 every three times I turn the switch on, I have checked the wiring 3 times. Does anyone know of signs of a bad ballast?
    I had a cheap HID 35w 43k kit in that never gave me any issues......I wanted brighter, whiter light with a ballast I could hide in the headlight housing. This is what I get for not leaving well enough alone....
    Thanks in advance.
    A little of this and a little of that.......I like go, not show.
    2014 RS5
    Everything is relative.
    Veteran Member Four Rings salz2135's Avatar
    Sep 15 2005
    Austin, TX
    Re: signs of a bad HID ballast?
    If you are sure that the wiring is not the issue, switch the ballasts from left to right then right to left narrow the problem area. You can also do this with bulbs to see if the problem "moves" as you make your changes.
    May 26 2009
    Orange ****y, NY
    GRRRRR I was hoping to not do that since I sealed the ballasts into the headlight housing and the silicone takes about 12 hrs to properly cure........Thanks for the idea.....I'll let you know what happens.
    I did take it for a drive tonight and the light is noticeably brighter and whiter..........now to work out the gremlins....
    2014 RS5
    Jun 24 2009
    Dallas, Tx
    I just installed the DDM tuning 55w kit into my car, one of my headlights does the exact same thing. I had a spare bulb laying around and found out the bulb is acting up, so i would say just switch the bulbs and see what happens. i wonder if DDM replaces malfunctioning bulbs like that because its a pain having to figure out if the bulb is on or not.
    Established Member Two Rings Vrdady's Avatar
    Mar 21 2007
    VA
    I'm going to guess you need that kit to wire directly to the battery for additional start up power.
    If your Audi isn't quattro, Why did you buy it?
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Quote Originally Posted by Vrdady View Post
    no you should be able to use the stock wiring and everything, the kit is designed for this, check all your connections and make sure the car is running with around 14v, low voltage will often make it hard for the ballests to output the needed power
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Dec 05 2007
    I have a 55w kit (not DDM Tuning) and have no issues with mine. Not running a power feed from the battery and using the stock connector. As already mentioned, check for wiring, swap bulbs, then lastly the ballast. It has to be one of those reasons (well, should be anyways).
    May 26 2009
    Orange ****y, NY
    I used the factory wiring and only changedthe connectors from the original harness that goes to the hid bulb harness. Basically I put cut the square double female plug off and put individual female plugs on the wires so they fit into the DDM plug. I will try the swapping of ballasts and bulbs only becauseI have no issues with the left side, only the right. If it were a voltage it would be both sides right?
    I really dont want to have to open up that housing again to swap ballasts.....grrrrrrr.
    Thanks for all the ideas and suggestions..will update once I do the swap...
    2014 RS5
    Dec 05 2007
    You should not have needed to cut off any wiring at all. Maybe you are losing voltage somehwere. The HID kits are really plug and play. The only modification that should be needed is a hole to get the HID bulbs into the headlight housing. After that, it is literally plug and play.
    May 26 2009
    Orange ****y, NY
    I tried to get the square plug on the right to fit into the power plug on the DDM kit but it would not hence the removal and addition of female plugs. (this pic is just to show the plug, that is the old 2 piece headlight housing)
    I opted not to drill the housing and just make a plug for an existing hole.
    Gonna tinker some more.....stay tuned...
    2014 RS5
    May 28 2008
    2015 Tacoma Off Road
    Quote Originally Posted by sekx View Post
    DDM does replace bad bulbs. I had one burn out after about 4 months of use and they sent a replacement set of bulbs under their warranty.
    2015 Tacoma Off Road - current
    2001.5 S4 avant - sold
    2001 A4 sedan - hit and totalled
