Originally Posted by
Dynamite
thanks, yea I realise the tq is way better in the s4, and it is tempting largely for that reason. I guess what I want as far as handling goes is just going around corners on crappy roads quickly (poor tarsal and gravel), I dont need to be able to accelerate out of them quickly (although a plenty of go for passing is good). at the track it is just fun, not serious racing for me, im not a grate driver and dont claim to be. You did bring up gas mileage which I had completely forgotten about, that is a very good point. As far as working on the cars I do everything myself, so how much worse is the s4 to work on? I have never been in an s4 or a bt or elim a4 or had a good look around in them.
Yes, the S4 is a bit more difficult to work on and more expensive to maintain. If you know how to work on a 1.8t, then you know how to work on the 2.7tt. Besides the fact that the 2.7tt has 2 turbo's the setup itself is basically the same as a 1.8t, you just have double the components in several areas. Many common parts under the hood of a 1.8t and a 2.7tt. The 1.8t can still be a bitch to work on anyway, I've practically done everything on the 1.8t.
If it were me, I'd go S4 and never look back, and that's coming from someone who has owned, driven, tuned, and worked on both. Don't get me wrong, I absolutely loved the 1.8t. The fact is, even if you just did a K04 setup, its still going to cost you a decent amount of money just to get on the same level as a stock S4.
But before you even consider a B5 S4, its extremely important to ask yourself this question and even more important to answer it honestly.
Can I afford to buy an S4 and have the turbo's blow the next day? That's a question that took me a couple years to be able to answer yes... A troublesome S4 can put a good dent in your bank account. In all honesty though, so can the 1.8t
If you do decide to buy an S4, do yourself a favor and do the fallowing
- set aside 6months to find a good one. (NO, NOT KIDDING HERE)
- test drive the shit out of them
- do a lot of research so you know how to identify an S4 shitbox (I encountered several during my search)
- get a 2001.5 or a 2002 (these late models had larger oil supply&return lines serving the turbo's)
- find one with a documented maintenance history
