Hey guys,
I just picked up an '01 2.7t 6mt AR and had it dyno'd last week to get a baseline prior to modding. After the dyno on the drive home while in manual mode, the ride height would not adjust to the selected height (didn't matter which direction i tried). I got home fine and figured I would let it sit overnight and see what the story was the next day... Well when I came out to the car the next morning, the rear (both sides) was on the ground, but the front still seemed to be in level 2 from the day before, and there is now a CEL light on the dash for the suspension. I scanned it and got the following codes:
01400 - Suspension Level Control
08-10 - Control Limit Surpassed - Intermittent
11-10 – Control Limit Not Reached - Intermittent
01780 - Sensor for Vehicle Leveling
04-10 – Mechanical Malfunction - Intermittent
00774 - Level Control System Sensor: Left Rear (G76)
27-10 - Implausible Signal - Intermittent
00775 - Level Control System Sensor: Right Rear (G77)
27-10 - Implausible Signal – Intermittent
Car had no codes and suspension was working perfectly prior to the dyno, so I'm thinking a sensor or two got knocked loose or damaged in the rear causing the droop and codes, but I am looking for input! Thanks in advance for any assistance!!
