Page 1 of 8 123 ... LastLast
Results 1 to 40 of 286
    Oct 16 2008
    South Florida - Ft Lauderdale
    B7 A4 Timing Belt Change
    Part 1
    I was not too stuffed after the Thanksgiving meal so I decided to start the project.
    For the Bumper removal, the DIY is here:
    http://www.audizine.com/forum/showth...ghlight=bumper
    Remove the following components:
    Headlights
    Intercooler scoops
    Disconnect hood latch cable
    Air filter intake conduit
    Spark plugs (you need to do that for later)
    Then, you should end up like this
    Then remove the 2 front impact sensors located on each side of the radiator
    Remove the front support
    And under supervision of my weekly rides (my primary job )
    Driver intercooler, disconnect the bottom hose
    Passenger intercooler, disconnect the upper hose
    Now, time to dump the coolant. Located on the bottom left corner, the valve: turn counter clockwise
    When the circuit is empty, disconnect the bottom hose by lifting the clip and pulling AFT. Be gentle, everything is plastic
    Insert 2 bolts on each side of the frame to be able to slide and support the front
    Now, remove the screws circled in red, on both side of the car
    Unplug the fans controller harness
    Because I really want to have access to the front and the bench was close by, I decided to vacuum the AC. Doing so (good thing, my Freon was low); I will be able to slide the entire front end on the side.
    And voila, plenty of room to access the timing belt
    How easy the DV access is now
    Part 2
    Started this morning by removing the Alternator to access the Thermostat Assembly. Pretty straightforward: remove the 4 Allen screws and secure it on the side. No need to remove the connectors on the back.
    Now, here is the beast. Pretty easy here as well: Not shown on the picture due to access, you need to remove the 2 top Allen screws of the Oil Cooler to give some slack to a metallic line connected to the valve
    Valve removed
    New one & old one side by side
    Warning: This DIY is for information only. If you decide to use it, it’s at your own risk.
    Now the timing belt:
    Loosen the 6 screws of the puller Dampner (don’t remove the pulley yet)
    Remove the 5 screws of the upper plastic cover
    Using the Crankshaft bolt, turn clockwise until the mark on the Camshaft and Crankshaft are aligned. Because both marks could be difficult to see (especially the one on the Dampner pulley) I use a white marker to materialize them a bit better (got old eyes too).
    Camshaft
    Crankshaft
    Now remove the 6 screws of the pulley Dampner. Remove the bottom protector. As you will see, your bottom mark is now gone so as a safety, I made another mark on the block and the bottom pulley
    New reference
    Now removed the nut of the Tensioner and slide out the Tensioner.
    Now remove and replace the water pump as well as both idler (in red)
    Slide the new belt in place.
    When installing the new Tensioner, make sure that the rear tab fits completely inside the block.
    Now, set the tension:
    Tight barely the Tensioner nut. Using an Allen wrench, turn clockwise the center of the Tensioner until the notch is aligned with the highlighted dot. Then torque the nut with final value
    All should look like this
    Torque Values:
    Using the crankshaft bolt, turn the shaft a complete revolution: This will center the belt on all the pulleys and use this step to control that at the end, all your marks are still aligned.
    Time now to put everything back together because you are done and you save yourself a big chunk of cash.
    Phil
    CUSTOMER ADDITIONAL COMMENTS WHO HAVE FOLLOWED THIS DIY
    a. IMPORTANT! before you do anything - read up on it and picture it in your mind doing it. do this a few times. so, your mindset is fresh and have a courage in doing it. of course, the right tools, double check everything, take lots of picture, bring a lot of patience, and take your time.
    b. TB access - use Phil's DIY reference - you don't have to disconnect A/C lines - slide out and down to ground put support on radiator - you'll have plenty of room to access TB.
    c. T-stat removal - disconnect top hose, remove torx screw on middle metal hose on T-stat body. pry it out with flat screw driver gently and pull middle metal hose out slightly once popped out the T-stat house and STOP. remove the two hex bolt on T-stat and slide out towards you. then pull out bottom hose (pop the clip). you'll have plenty of space and leverage to pull bottom hose. put things back in reverse order.
    d: filling coolant - 2 gallons of G12 50/50 mix - squeeze/pump top and bottom coolant hose to let air out and suck in new coolant in engine. do this a few times until you hear coolant flowing on top coolant hose. if you have air, you'll see your coolant in reservoir bubble up. before starting car, leave reservoir open, put heat on HI on low fan setting, start the car and start squeezing/pumping top and bottom coolant lines. you'll feel and hear coolant flowing. run car for a few minutes to get coolant going. do this process a couple of times. put reservoir cap back on and test drive. when done test driving. let car cool down and check coolant level again. add if neccesary. Note: In adding coolant. Don't fill over MAX level. If you do, I'll make a mess.
    Senior Member Three Rings Blarg's Avatar
    Sep 08 2008
    Kansas City
    Re: A4 B7 Timing Belt - The DIY
    Great job so far, glad to see someone putting this together!
    Sold - 2006 A4 S-line Quattro 6M Nav
    Jan 09 2009
    07 A6 4.2, 04 Volvo V70r, 03 BMW 540i Sport
    Connecticut
    WOW!
    Veteran Member Three Rings spitfire11's Avatar
    May 02 2007
    Airplanes, Cars, Trucks, Motorcycles, Bicycles
    Southern NM
    You're the man
    VAG Cars:
    '84 Diamond Silver Metallic Rabbit GTI VR6 swap/resto-mod in progress
    Previous:
    '01 Nogaro Blue B5 S4 Sedan, 6MT, K04 Stg III
    '08 Ibis White A4 2.0T, Quattro, 6MT, S-Line Titanium APR Stg II
    '90 Black GTI Turbo 12v VR6
    '96 Emerald Mica A4 2.8 12v Quattro 5MT
    Senior Member Four Rings Jake39454's Avatar
    Mar 04 2009
    Horsepower injected Audis
    Richmond RI
    Why did you remove the spark plugs?
    Oct 16 2008
    Quote Originally Posted by DW Garage View Post
    Once the new timing belt will be in place with the new tensioner, you need to turn the Cranckshaft by the 12 points bolt, at list 2 revolution to:
    1/ Make sure you did not make a mistake and all the references are lining up
    2/ This will set the timing belt tension
    If the plugs stay in place, bo way you will turn the cranck
    Phil
    Mar 04 2009
    Richmond RI
    Phil
    19mm 12 point, I'm very familiar. It can be turned without removing the plugs, no problem. Doesn't hurt to do it, but not needed. Just wanted to make that clear.
    It's nice to see people putting forth effort to do DIY's like this for B7's
    Oct 16 2008
    I have to replace the belt anyway so it's a pleasure to share with the Community
    That could save some $$ to some Fellow Ziner's in the future
    Phil
    Veteran Member Four Rings nramsey's Avatar
    Dec 09 2004
    Nice! And so jealous of your day job. Is that a TBM?
    Looks like a pretty awesome "garage" to do car work in!
    - Nathan
    http://www.flickr.com/photos/nramsey
    2008 A4 2.0T Quattro Avant - Dolphin Gray
    Eibach Pro-Kit - Koni FSD - Rotiform MIAs
    May 02 2007
    Southern NM
    Looks like a socata TBM 700
    VAG Cars:
    Previous:
    Oct 16 2008
    Quote Originally Posted by spitfire11 View Post
    TBM 850 to be exact but great and correct guess
    Phil
    Oct 16 2008
    Replacement done. Posted Part 2
    Phil
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    Re: A4 B7 Timing Belt - Complete DIY
    Nice!!!!
    Feb 19 2007
    Louisiana
    Fly I guess you going to take that plane to my house and change my timing belt for me!!! lolz
    Oct 16 2008
    Anytime
    Phil
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Excellent DIY...But hey, its Phil right...What else could it be...
    Way to go man...Thumbs up
    May 26 2009
    VA
    Outstanding write up. Thanks!
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    One again you have proven how much of an asset you are to the AZ community. Well done, Phil.
    +rep from me
    EDIT: Sorry Phil, it appears I cannot give you multiple reps
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Veteran Member Three Rings illegitimus's Avatar
    Mar 17 2009
    2006 B7 A4 Quattro Tip S-line
    Boston, MA
    Phil, did you make use of the tools rental the site provided? Did you replace the accessory belt as well? How much coolant does it take to fill the system? Thanks.
    Oct 16 2008
    Yes I rented the tools in case the Crankshaft and Camshaft seal were leaking. Because they were fine, I did not use the tool so no, you don't need the tools.
    Yes, accessory belt was part of the kit I purchased so I replaced it. I also replaced the pulley (not part of the kit but only $40).
    The kit I purchased comes with 2 jug of G12, 1.5l each. You need to dilute with water at 50% ratio and I used almost all of it
    Phil
    Mar 17 2009
    Boston, MA
    Phil
    Good to know that the tools are only required if you need to take the pulleys off. Thanks for the DIY!
    Jan 09 2009
    FL
    Good stuff Phil
    Active Member Four Rings Goped220's Avatar
    Feb 16 2006
    2025 Audi S4, 2023 Audi A4 & 2024 Subaru Crosstrek
    NY/FL
    Do you need to place the Thermostat when you doing the timing belt?
    Previous Cars: 2006 Audi A4, 2011 Audi S4, 2016 Audi S4, 2017 Audi A4, 2019 Audi S4, 2023 Audi S4, 2024 Audi S4, 2019 Benz E450, 2015 STI, 2013 370Z, 2013 Benz GLK, 2014 F-150, 2020 Lexus GS350, 2016 Subaru Crosstrek, 2024 Porsche Cayenne S
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Quote Originally Posted by Goped220 View Post
    You're in there, may as well while you have the clip off versus doing it twice.
    I'm excited to put 18k more miles on my car and do this. I love wrenching, especially when it makes my dad's head want to explode. Taking the entire clip off will do it!
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    Great work!
    '08 Brilliant Black B7 A4 w/ DTM Conversion Stage 2+ - Sold
    '14 Midnight Blue Allroad Premium Plus w/ Nav & LED Package - Sold
    '13 Ford F150 XLT - Current
    '14 Glacier White Q5 Premium Plus - Current
    '08 Ibis White B7 A4 Titanium Edition Stage 1 - Current
    -Steven
    Oct 16 2008
    As already said, better be safe than sorry and because everything was open, I've done it.
    Nevetheless, Water pump is Mandatory.
    Phil
    Established Member Two Rings Chb04's Avatar
    Jan 12 2009
    11" B8 Sedan , 07" B7 Avant, 11" Jeep Wrnglr Unlmtd
    USofA
    Phil awesome write up and I'm ready to tackle it myself! How long did it take roughly?
    Oct 16 2008
    Count a full day at easy pace.
    Phil
    Oct 16 2008
    Quote Originally Posted by v_audi View Post
    ^^ Thank you
    Phil
    Oct 16 2008
    Quote Originally Posted by Hyphy View Post
    Good stuff Phil
    I was waiting for you
    Phil
    Dec 07 2008
    Harrisburg, PA
    Quote Originally Posted by airborneriflema View Post
    +rep from me
    Funny.
    Veteran Member Four Rings Dangler's Avatar
    PA
    nice
    F.T.W.L.T.B.D.W.I.C.T.W
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    Awesome stuff Phil!! Saw this and thought about doing it myself but i think ill leave it to the professionals. lol
    Quick question?? What mileage is this required at? I looked through my maintenance book and all it said at 75K was to replace belt for 1.8T, nothing about 2.0T. I know someone got a letter from Audi saying it will be good to 110K i think? But does that include '05.5?
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Dec 11 2007
    San Diego, CA
    Anyone know if this needs to be done at 75K?
    FRRG Southern Ring
    Registered User Three Rings Dan@EuropaParts's Avatar
    Sep 06 2009
    Piscataway, New Jersey
    Hey folks. We just loaded the B7 2.0T Timing Belt Kit on the site. Check it out:
    Feb 09 2008
    2006 A4, 2006 4Runner
    Colorado Springs
    Quote Originally Posted by Sal_B7 View Post
    The initial guidance was 75k, but it was revised (at least on MY06 2.0Ts) to 110k. http://microsites.audiusa.com/my09/l...enance2006.pdf. I'd print this out, bring it to the dealer and ask the service guys about what years the guidance applies to.
    Dec 11 2007
    San Diego, CA
    ^^Thanks a lot for that. Yeah i have a 05.5 so wondering if that applies to me as well. The paper says replace timing belt at 110K for 2.0T FSI only, so hopefully im in that category. Definitely going to check it out, not looking forward to forking out the $$$ for this right now. Ill give them a call tomorrow.
    FRRG Southern Ring
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    Fantastic write up, + rep.
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Oct 16 2008
    Guys,
    Whatever the paper says, I would not gamble with this. Yes, once removed, the belt look almost like new but I would be more concern about the Tensionner and other small bearings. If they seize, you are done and it will end up costing you more . My tensionner once removed, had a pretty consequent side play
    My 2 cent but hey, what do I know
    Phil
    Mar 17 2009
    Boston, MA
    Phil, did you have to evacuate the AC system? I mean, is it needed so the radiator and the ac condenser are removed completely to gain access to the belt? Can the radiator assembly be swung away like on a B6 being hinged on one side?
