Results 1 to 8 of 8
    Nov 24 2009
    uk
    Glove Box hinge repair
    The left hand glove box hinge on my Audi A4 - B7 snapped recently looking on the forums this seems to be a common problem.
    I removed the entire glove box - 3 8mm bolts at top and 2 at bottom
    Set airbag switch to off before disconnecting single electrical plug at back/ base of glove box.
    Most posts seem to suggest the glove box door can be removed by pulling the pins out (didn’t work for me) I used a watch makers screw driver as a punch (had to bash a hole through plastic one side).
    Removed and repair the piston/ damper on left hand side its this that gets so stiff the hinge breaks. - advice from http://www.audizine.com/forum/showth...ight=glove+fix - I added a bit of grease to rubber washer and it runs quite freely now.
    Quite a few posts seem to recommend glue the hinge - I cant see how that would last.
    I used a M5 screw - about 4cm long
    Drilled a pilot hole in both sides of broken hinge and screwed screw into the door side.
    chopped head of screw leaving about 1.5 ish cm of screw exposed
    Screwed broken part of hinge onto screw and adjusted
    Slightly undo screw and put araldite rapid on middle of hinge and built up reound crack and screw.
    Allow to set overnight before reassembling glove box.
    photos attached - will let you know if it holds seems quite solid
    Hope this helps a few people - better than £120 from Audi
    Audi A4 B7 1.9 TDi
    Senior Member Two Rings babybepeezy's Avatar
    Aug 12 2009
    California
    Re: Glove Box hinge repair
    This was fixed under my warranty.
    Veteran Member Three Rings CoDRoX's Avatar
    Nov 03 2009
    NoVA
    Quote Originally Posted by babybepeezy View Post
    I still have my original warranty but the dealer just quoted me 525$ to fix it. wtf. Gonna try another dealer to see if he can fix it for free under warranty.
    2014 Q5 3.0T | Lava Gray Pearl/Black | Prestige | S-Line Plus | Adaptive Damping Suspension | Driver Assist | Sport Interior Package | EPL Stg I |
    Sold, but not forgotten:
    2013 allroad | Glacier White Metallic/Chestnut Brown | Prestige | Sports Package | 19" Wheels | Audi Drive Select | Adaptive Cruise Control |
    2006 A4 2.0T quattro | Black/Black | S-Line | 6MT | Bi-Xenon AFS | Navigation | Bose | BlueTooth | Tint | APR Stg I |
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Veteran Member Three Rings Adub-Drew's Avatar
    Feb 07 2010
    Wilton, CT
    Anyone got an idea as to how i get the right side glove box hinge "pin" out? On the left side i just hammered it out lightly with a skinny star screw driver, but on the right its covered with plastic trim...
    B7 A4 tip (daily) Mk6 Gti Drivers Edition (toy) Soon to come Mk4 R32
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    What i did was: Open the side dashboard panel, removed the piston hinge. But now the light didn,t work anymore, so i removed the piston by turning it 1/4 turn and pulling it. Then i snap open the top part to dimantle the piston and remove the rubber ring (after i saw that drilling holes at the back to let the air pass wasn't working). I put back the piston together with the hinge and now i still have the light and the piston slow down a tiny bit the glovebox door.
    My hinge was broken, but not broke off yet. I will have to glue it and attach a "L" shape bracket to secure it.
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Senior Member Two Rings unh112's Avatar
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    I believe there's a TSB for this. Mine was fixed for free.
    06 B7 Quattro Silver MT
    RS4 Sway Bar | RS4 pedals | S4 Door blades | Votex front spoiler | Votex rear spoiler | revo stage 1 | Forge DV | clear side markers | VAG-COM mod | Eibach pro kit | Koni FSD | 40% Llumar axcess tint | LED license plate light | 6000K HID | 18's B8 wheels 245/40/18 tires with 8/12mm H&R spacers front and back
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    Me too, about 6 months ago.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
