Results 1 to 12 of 12
    Senior Member Three Rings Stockton's Avatar
    Mar 04 2008
    2004 A4 Quattro 1.8t 6spd
    Palm Beach Co, FL
    DIY: B6 A4 - Window Regulator & Motor Replacement
    I used another DIY from another board but found some errors in it.
    This was done on my 2004 A4 1.8t Quattro 6spd manual just to be precise.
    I replaced the Front Driver's Side(left) Window Regulator which I purchased from http://www.genuinevwaudiparts.com/pa...?siteid=214407
    Part number: 8E0837461C
    This is a DIY on how you to replace it with a new one, if you need to replace the window motor you can use this, it's actually a lot easier and less steps.
    Lets begin with the tools you will need.
    1 Philips head screwdriver
    1 Flat head screwdriver for prying, I put tape on mine to help prevent scratching.
    1 Ratchet wrench. I used a nice long extension piece too. You don't need the ratchet the whole time. You only need it to break the seal of the screws or the last half turn when tightening. The extension works nice to keep from banging into things with the handle your hand and is nice to use without the ratchet like a screwdriver.
    1 #25 Torx bit.
    1 #30 Torx bit.
    1 #45 Torx bit.
    A pair of needle nose pliers will come in handy as well.
    Having a stool or something will save your back and knees too.
    Now lets take this door apart.
    First, roll down the window all the way down.
    If you're window reg is really jammed up try to help it down with your hand. It doesn't have to go back up till you replace it with the new one, if you're doing the motor it doesn't matter if it's up or down.
    Now we're going to take the trim off the door and the small cap behind the handle.
    There is one Philips head screw at bottom center of the door as well.
    The screw at the bottom is pretty long and can be a pain, be patient with it and don't strip out the head.
    As far as removing the upper trim, I used my fingers, I started in the middle near the door handle and worked my way to the door hinge. All of the clips pull straight out, except the on at the end of the trim closest to the open part of the door, that clip should be done last and pull the trim towards the door hinge.
    Here is the back of the trim piece.
    Here is what 5 normal clips look like.
    Here is the one clip closest to the open part of th door, as you can see it can't be pulled straight out.
    The cap under the handle just use a flat head from the underside and it will pop right off.
    Now with the trim and cap off you have 4 Philips head brass colored screws exposed and 2 of the same screws behind where the cap was. Remove them. This is where a needle nose or magnetic screwdriver will help with the 2 behind the cap.
    Now with those 6 screws and the 1 at the bottom center removed the door interior is ready to pull off. Start at the bottom and gentle pull to get the clips behind to come loose. The door interior will stay attached by the top. You will have to lift it to get it completely separated from the door but it won't just drop off until you lift it off.
    The door is going to be attached from behind by the door handle mechanism and 2 wires at the bottom near the speaker so don't just yank it off expecting it to be free from the door completely yet.
    Once lifted away from the door detach the door mechanism and wire clips, one on the speaker, one on the window motor. The one on the window motor has a purple clip that you can just press down with a flat head, it will swing down and back releasing the connection.
    Now lay the door interior somewhere safe it won't get scratched.
    The inner door is now exposed somewhat.
    Now get our your #25 Torx.
    I like to take all the #25's off now you can so you're not switching back and forth with different bits.
    Now unclip the other other connection on the speaker and the other 3 connections on the Window Motor.
    There are 3 black #25 Torx screws around the speaker and 3 silver #25 Torx on the Window Motor. There is also a clip holding a wire on top of the speaker that needs to be removed. I found it easier to undo the tape holding the wire to the clip then pulling the clip itself.
    When you remove the screws from both parts, neither part will fall off. The Window Motor will need to be pulled off and if that is all you are replacing, do so, and reverse the steps from here and you are done.
    The speaker has a small platic hanger at the top center, after the screws are out it will need to be lifted and pulled off to come free.
    Now with window motor and speaker removed, time to remove the glued on sound deadening material. Just start at a corner and slowly, gently work it along the glue lines try not to rip and destroy it. It helps if it's warm when you're doing this, you can use a hair drier to help warm it up if needed. If you do it right all the glue will come off with the deadening material and not stay on the door.
    When it's off lay it somewhere safe glue side up.
    Check to make sure this clip is still intact and in the correct position.
    Now there are still 2 more #25 Torx screws to remove now.
    One is in the speaker well where you just removed the speaker. It's a black screw at the bottom of the old Window Regulator. The other is to the left of it about same height and is now uncovered with the sound deadening removed. Remove both screws.
    Now you are done with Torx #25 screws till the re-assemble.
    Now you have to remove the power mirror wire from the clips on the inside lower part of the door so it can come out freely when you pull the door apart.
    This is the Brown wiring harness that you disconnected from the Window Motor. Pull the big rubber plug out of the door that all the wires are coming through and disconnect the plastic wire tie holding them all togther. Needle nose will help.
    Now there are 3 clips holding this wire on the INSIDE of the door you have disconnect. One is black and you can release the clip easily. The other two are white and you can reach them from inside the speaker well.
    Here is the black one you can release easily.
    Here is a pic inside the speaker well, you can see the lower white clip, the second is higher and approximated.
    It's up to you to pull out those white clips or just undo the tape. I pulled the lower and undid the tape on the higher one.
    Now with that wire loose, pull it through and let it hang out of the speaker well.
    Now we're going to pull the remaining plastic pieces near the mirror. They're just clipped in, I started at the bottom with a flat head till I could get my fingers under it and just worked my way up for the big piece, it has 3 clips holding it. I started from the side with the small piece it has one clip and wedges into to the bottom.
    Now we're ready to take some more screws out.
    Now we're gunna take the one and only #30 Torx screw out that was behind that plastic you just removed by the side mirror. It is the lower black one. Do not remove the upper silver screw.
    Ok now on to the last 4 screws and they are all #45 Torx 2 silver 2 black. 3 of them are right there on the door easy to spot, one is on the open edge of the door hidden behind a rubber cap.
    Lets take the one out behind the cap first.
    Remove the rubber cap and remove the screw. Don't worry about dropping it inside the door. There is no where for it to drop to. It will just stay there. A magnetic bit or needle nose and a long extension will really help here.
    Cap
    Screw
    This is the angle you're gunna be at unscrewing it and replacing it, extension of some length is a must.
    Now with that out, lets take out the other #45 Torx screws that are easy to get to. 1 black screw and 2 silvers left.
    Now all the scewes are out. Time to remove the weather stripping around the top part of the door ONLY!
    Be careful with this. I ripped mine a little but some glue fixed it. Pull from behind the stripping, not underneath.
    I started from hinged part.
    Do not remove it past those lines.
    Get your fingers behind the rubber from the top of the door and work your way around slowly.
    When you're done it will look like this.
    Now on the open part of the door there is one rubber cap to remove.
    You want to get the 2 clips behind it to come out of the lower half of the door but stay attached to the upper half.
    Now the last step before separating the door. Just squeeze the blue plastic stems of the Window Regulator where the Window Motor was attached and push them into the door.
    Now you're ready to live the top half off the door off. The whole window assembly will life out. The top frame, Window Regulator and Glass. Have somewhere close by, clean and safe to lay this down.
    You're going to be laying it down mirror side up.
    When lifting remember the glass and Window Regulator are slightly curved so it won't lift straight up, just get a good grip and lift slowly and don't force it, let it come out how it wants to.
    REMEMBER THE POWER MIRROR WIRE. That has to come up with the mirror so make sure it's not caught anywhere.
    When you get it separated you have this.
    Remember when I said you were done with the #25 Torx bit? Well I lied, get it back out. 4 more to go.
    Ok now you're gunna take the 2 #25 Torx out of the bottom of the Window Regulator but leaving the plastic tabs on the actual glass.
    Pull the window out to get this.
    Now lay the new Window Regulator out next the old one that's still attached to make sure you have it all ready to go on the correct way.
    Now remove the 2 #25 Torx screws at the top of the old Window Regulator.
    Alright, now just put the new one into place and put the top 2 screws in.
    Then slide the window into the frame and line up the bottom tabs. This is the most annoying part, getting the window in. It's easy with someone to give a helping hand which I didn't have but with a little patients it'll go in and line up.
    Now screw the 2 lower #25 torx screws in to attach the window to the Regulator.
    From here just reverse the steps.
    I like to get the window in attach the 2 #25 torx screws at the bottom of the Window Regulator first and get the blue stems popped through that the Window Motor will screw into.
    REMEMBER WHAT SCREWS GO ON UNDER THE SOUND DEADENING. The Window Motor goes on after the deadening material.
    Hope all worked out for you.
    Main thread link to chat about DIY: http://www.audizine.com/forum/showthread.php?t=221875
    Jan 11 2007
    Salt Lake City, Utah
    Excellent writeup, I used it a couple times and had a friend use it as well. One thing though, you don't need to take the sound deadening all the way off. The duct tape and the top edge is the only one that needs to come off. The rest of the big bolts can be accessed just by folding the sound deadening back (there's no glue at that point). And to access the only screw that is actually covered (the one circled in the pic below), just cut a tiny X over the head of the screw, and it's easy to get right out. That helped me a ton with not having to worry about messing with all of the glue in the door (which is the biggest pain of this IMO).
    [/QUOTE]
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Mar 16 2009
    2019 Honda Accord Sport
    Hanford/CA
    My Right back window wont go up or down anymore, while driving it slowly goes down.
    I am going to use this Thread to figure out what is going on with it.
    Apr 13 2009
    NS
    Quote Originally Posted by Kenjuro View Post
    Let us know when you figure it out as mine is doing the same thing. Thanks
    Veteran Member Three Rings Veereihen6's Avatar
    Mar 06 2009
    Long Island, NY
    Hey guys, about to do my front passenger side window regulator, but I cannot get the window all the way down. Is this a major issue?
    2004 B6 S4 Avant 6MT Moro Blue - mostly stock for now
    1998 VW GTi-VR6 - mmmmm....listen to that VR6 growl! -sold-
    Senior Member Two Rings SoCal Driver's Avatar
    Nov 28 2012
    2016 VW Tiguan S 4motion
    Oxnard, CA
    how much are you talking about? if it's only a few inches you'll be fine.
    Current: 2015 Audi S4 P+ | Ibis White | Sports Diff | B&O | Carbon Inlays
    Past: 2008 A4 2.0T Quattro 6-Speed | 2004 A4 1.8T Quattro 6-Speed USP in Arctic White
    Mar 06 2009
    Long Island, NY
    stuck more than half way up.
    Nov 28 2012
    Oxnard, CA
    you should be ok. i think the hardest part for me was pulling the window out. I had to do it 3x to get mine done right.
    Mar 06 2009
    Long Island, NY
    OK, just did mine. Took like 3 hours total for me. Getting the window out was no problem, but I ended up breaking 3 out of 3 of the door clips. If I have to do it again, I will buy spare clips. The old regulator was so mangled that the cable was all bunched up in the opening where the motor connects to it. Thanks for the thorough DIY, no way I could have done this without it.
    Junior Member Two Rings audiboy22's Avatar
    Jul 26 2016
    Rockford, IL
    All done, window goes all the way up but at the top the anti-pinch kicks in and lowers the window 1/2 way. How do I stop that?
    Junior Member Two Rings RAUDI-Ä4's Avatar
    Feb 12 2019
    Lancaster, Pennsylvania, USA
    Very nice thank you
    Junior Member One Ring
    Aug 30 2012
    MA
    Thank you for this! Just replaced my driver's side window regulator, the cable popped out and a plastic piece snapped so the window wouldn't go up.
    Very helpful write up. Did this over 4 hours or so, had to redo the position of the top pieces in the door a few times to get it right. Saved me a few hundred bucks.
    This is on a 2003 Audi A4 1.8t Quattro automatic.
    I did have to wind the window up by cranking the regulator manually with pliers, before the window would work again, not sure why but mentioning in case it helps others.
