Results 1 to 40 of 44
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    BG44k for controlling carbon buildup ...
    Anyone tried BG44k ? Heard good things about it so I picked some up and will run it through on my next fillup and provide some feedback ...
    Here's the blurb:
    BG 44K® Power Enhancer® safely, rapidly and thoroughly removes engine deposits in combustion chambers, intake manifolds, ports and on valves. It restores flow in fuel injectors and cleans the entire fuel system. BG 44K® Power Enhancer® improves fuel economy and reduces exhaust emissions. It restores that “like new” driveability to an engine’s performance and keeps it running better, longer and more efficiently. Add one can or bottle to fuel tank at fill up. Catalytic converter and oxygen sensor safe. NOTE: After cleanup with BG 44K® Power Enhancer,® regular use of BG Supercharge®II, Part No. 202, in gasoline engines or BG Diesel Fuel Conditioner with DPL, Part No. 2276, in diesel engines will prevent deposits from forming in the fuel system and upper engine for maximum driveability and fuel economy.
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Veteran Member Four Rings Retsujou's Avatar
    Dec 07 2008
    08 RS4 Tit/Exec/Prem/Carbon
    Mississauga
    Re: BG44k for controlling carbon buildup ...
    This does not work for FI, as it is not ever going to reach the top of your inlet valve.
    Apr 27 2004
    Quote Originally Posted by Retsujou View Post
    I'll take your word for it as I'm really not very mechanically inclined. That said perhaps it will do SOME good as it'll still run through the injectors etc. ...
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Dec 07 2008
    Mississauga
    It helps and i USE IT religiously in my car. However it does little to prevent carbon build up. There is nothing like some good hard driving on a weekend to heat your engine up to prevent the carbon build up by burning some of it off and of course avoid fuel that has Methanol in it
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    The stuff will obviously help clean the injectors. Talking to one of the techs at Agincourt, they did mention that they have seen FSI engines with dirty injectors.
    Retsujou is right, these FSI engines, including the 2.0T, needs to breath. Apparently the naturally aspirated FSI engines will seem to experience issues before the 2.0T with respect to the intake valves getting covered in crap.
    Mike
    Apr 27 2004
    1) Please define "religiously" - how often ?
    2) I rarely wait for weekends to heat up the engine and my rule of thumb is to shift at a minimum 6,000 but would say the car rarely sees below 3,000 rpm and always sees 7,000. Perhaps this is why I visit the pump so often
    3) Which station sells gas with methanol in it ? (I use Shell 90% of the time and Petro Can the balance)
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Markham, ON
    I have read that fuel cleaners and such should not be used on a regular basis as it may cause more harm down the road, but i can't remember where I read that.
    As for fuel all I know that Shell premium does not have ethanol in it.
    Mike
    Apr 27 2004
    Quote Originally Posted by Tanner View Post
    Doesn't surprise me. There's guy I know of who apparentley uses this stuff on a regular basis and throws it in every few thousand K's. The local place where I bought it suggested it be done twice per year ...
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Markham, ON
    I'll use it twice a year at most and that's it. Six months after the first time I used it, I don't really notice my back bumper covered in soot like the first time I used the motul fuel cleaner.
    Mike
    Dec 07 2008
    Mississauga
    Quote Originally Posted by Stevelev View Post
    Around every 15K or twice a year, whichever comes first.
    Well I do not drive that harsh, mostly because that would make me break the law 90% of the time or I would never get out of second gear :)
    For Ontario every fuel except Shell 91 Octane has Methanol in it.
    Apr 27 2004
    WUS ! I never said I used 3rd gear and up ...
    Thanks for the info, I appreciate it.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Senior Member Three Rings mianol's Avatar
    Jan 19 2008
    http://forums.vwvortex.com/zerothread?id=4659547
    check it out, if ur THAT worried about build up get a catch can, it helps no?
    07 A3 S-Line, DSG, APR stage II+, ATP dp, NEUSPEED intake, BBS ta rep, alpine deck, 2x alpine amp, JL 10", black badgessold
    2011 DGM STi
    Apr 27 2004
    Very interesting read, thanks.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Registered Member Two Rings
    Dec 03 2009
    California
    i read on other forums that once u use this u get horrible gas mileage and the fill ups afterwards. and some dude sells this at his dealership and said it was a scam
    Markham, ON
    I just used Motul fuel line cleaner. Two tanks of this stuff. Run the engine hot and hard on the highway. After the first tank, my back bumper was covered in soot. Second tank, not so much.
    Now I know this has nothing to do with intake valves, but I'm a bit surprised that my engine has NOT hesitated yet this winter as I know that my intake manifold and such is pretty filthy. Usually it hesitates a bit a minute after I leave work but I can't remember the last time it did this.
    Mike
    Apr 27 2004
    Quote Originally Posted by yimstab7 View Post
    My consumption has not changed over the past several fillups. My gas mileage is not great but then again I do tend to push my relatively porky hi-po machine.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Veteran Member Four Rings cassdesigns's Avatar
    Mar 16 2004
    A3 2.0T, CLK320, S550, e46 M3
    Markham, Ontario
    Mike, where can I find the Motul fuel cleaner?
    Ibis White '08 2.0T DSG S-Line
    Titanium Package /Opensky
    APR Stage 2 + Sport exhaust
    Stoptech Stage 1 braking, H2Sport camber kit
    ECS Dogbone mount, Neuspeed power pulley
    Eibach + Bilstein + H&R suspension setup
    Markham, ON
    Independent Tuning for sure.
    But if you're up in Markham, there's a place closer perhaps, Exotic Motoring. They're at 80 Travail Road, near Markham Road and 14th. They also carry Lexol cleaning products too!
    Mike
    Mar 26 2007
    Colorado
    watch, and everyone should stop bitching because the video is proof
    Apr 27 2004
    Quote Originally Posted by vdubjetta02 View Post
    Very interesting! Although I didnt do the full fuel induction deal (BG44K in the tank only), I had no apparent change to drivability etc. Some suggest that BG44k on its own only works if the valves etc are clean to begin with. As luck would have it, I ended up with CEL and EPC lights and ultimately rec'd a carbon cleaning with full "tear down".
    Before
    After
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Markham, ON
    And word from somebody that tried it, results are marginal on an engine with a lot of miles already. Good for preventative maintenance but I wonder with repeated use over a long period of time whether it's going to affect other things like the catalytic converter, rings, etc.
    Mike
    Oct 20 2008
    Try seafoam. Like BG44K, some people say it doesnt work, some say it does. However, many have reported the car to me a lot smoother after sea foaming.
    Jul 28 2007
    RS5
    gta, ontario
    ethanol not methanol
    Feb 23 2008
    Shell & Shell Canada == Top Tier Gas == 8-10% ethanol by volume, all grades
    2008 A4 B7 3.2 Quattro 6MT, S-Line, Titanium, Ocean Blue Pearl, Prem BOSE, Cold, Conv, Volterra Leather, BT, iPod
    2008 A6 Avant 3.2 Quattro 6AT, S-Line, Night Blue Pearl, Prem, Nav, Milano Leather, Cold, iPod
    2010 S5 Prem+ 6MT, Brilliant Red, Black/Platinum, B&O, Nav, Sport Rear Diff, Mods...
    Markham, ON
    Shell V-power in Canada is advertised on the pump to contain no ethanol. Regular fuel from Shell can contain up to 10% ethanol, and up to 5% for mid-grade.
    Also the detergents in the fuel has very little impact on the intake valves. Direct injection being the reason.
    Mike
    Feb 23 2008
    Then Shell fails the Top Tier Gas program that they have been promoting to the tune of ~35MM dollars
    Markham, ON
    This applies to ANY fuel that contains cleaning additives, and in fact, any retailer that participates in that program or any other similar program.
    Direct injection engines do not benefit significantly from these additives. Period.
    Mike
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    I use Sunoco Ultra 94, is this gas any good for our engine? I use it because I have APR ecu in my ride.
    Markham, ON
    If you have the program that can use it, sure.
    I have heard people switching to a program that uses a lower octane as many have complained about horrible gas mileage using Sunoco's Ultra 94 vs Shell Premium with minimal performance difference.
    But back to carbon buildup, regardless of the fuel you use, there's nothing that will keep the intake valves clean. Call it a side effect of the benefits of better fuel efficiency or a design flaw.
    Mike
    Feb 23 2008
    I'm just saying that to be in the Top Tier Gas program, they must conform to the criteria listed here: http://www.toptiergas.com/deposit_control.html (see 1.3.1.2 for the ethanol issue). I'm certainly not saying you are wrong, only that if Shell isn't meeting the criteria they say they are, then WTF!?
    Markham, ON
    Gotcha.
    Mike
    Markham, ON
    Found this thread....
    http://www.bobistheoilguy.com/forums...1098496&page=2
    Interesting part regarding the base fuel which is used for testing and may not be exactly the same thing delivered at the pump, which is probably how Shell is able to get away from selling v-power here in Canada without ethanol.
    Mike
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    How much are these usually going for?
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Oct 20 2008
    A local shop charges 518 to take apart the intake manifold and scrub it down
    i think that is prolly better
    if you do seafoam, use good oil and catch can you wouldnt have to worry until like 120k. 518 for every 120k seems pretty reasonable for me.
    Markham, ON
    $518 for a 2.0T? THat's pretty good price, I wonder how good a job they do though.
    Mike
    Oct 20 2008
    ^ yes, although you can prolly find a shop for a bit cheaper. 518 for every 120k is cheap, considering how labour intensive it is. Your average joe wont drive to 240k, so it's really 518 once.
    Mar 19 2004
    I meant how much is a can of the BB44k going for.
    Apr 27 2004
    Quote Originally Posted by ed@audiyo View Post
    I paid $33. tax tax in (in Ottawa)
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Veteran Member Four Rings BryanR's Avatar
    Sep 08 2004
    2003 Audi A4 1.8tqm Avant
    Ottawa
    Before and after
    Mar 19 2004
    Ok, thanks. I guess $25 tax in is a good deal but I have to purchase 4 cans.
