Originally Posted by
c4racer
Will 245/35/19 tires work well on a stock ride height Avant?
that's perfect actually...although you'll get chastised for not lowering the car when you post pics
I'm 18x8.5, ET38 on 245.40.18 tires. That's identical (sizewise both height and width) to your proposed setup, save the 1mm offset difference. 1mm is the white part on your fingernail that you trim.
Won't rub, and should be nicely flushed out, but not pokey.
My setup (and your proposed setup) is 19.3 mm more flush (further out/aggressive) at each corner. That's about 13/16"...and that's a good thing on these cars. Also means your track is 1 5/8" wider than stock.
Here's a visual reference
