Results 1 to 40 of 40
    Oct 05 2009
    iPhone 3Gs Integration to 2008 Audi A4
    I just bought a used 2008 Audi A4 which has the Audi Symphony System.
    It also has has BlueTooth, and iPod type adapter in the glove, and a Phone Adapter in the center console. I got the BlueTooth all hooked up and I like it a lot. Trying to figure out how to get music playing off the iPhone.
    I "think" my car got this installed http://www.iamaudi.com/audi-ipod-adapter/
    But I am not too sure since it did not come with the cable. argg
    Is that the best way to connect my iPhone 3Gs ? I want something that will charge, control and play through the Audi Symphony system
    Thanks
    Ken
    Senior Member Two Rings DrewBo's Avatar
    Sep 18 2006
    OBP 2.0T
    Michigan
    Re: iPhone 3Gs Integration to 2008 Audi A4
    while I have no first hand knowledge, take a look at this thread..
    http://www.audizine.com/forum/showth...highlight=dice
    05.5 A4 Ocean Blue Pearl
    Nov 08 2009
    Ottawa, Ontario
    You cant play music off the phone, as far as I know...
    Veteran Member Three Rings Nikoman's Avatar
    Feb 04 2008
    2015 Jeep Grand Cherokee
    Chicago, IL
    I'd like to know too. I have an iPhone 3GS and want to play music on the RNS-E. I currently have the Pro Clip with bluetooth connectivity for calls only. Kind of sucks being limited to just 2x2GB SD cards.
    May 20 2009
    Hartford
    i have the same setup as you. i have an 08 also....maybe its the package and Iphone 3GS. I use the bluetooth for calling through my RNS-E. I have plugged in my iphone into the factory glove box adapter (i used an ipod/iphone 30pin extention cable from jablejive to make it fit). You can play the music off the iphone's playlist and control it.... it also charges (even though the iphone screen has a an incompatibility error on the screen) you wont see the song titles though (thats just our a4's ingeneral...not the iphone's fault).
    Oct 05 2009
    Quote Originally Posted by bostonvr6 View Post
    I dont have the RNS-E, only the Audi Sym System. I need to look into the cable.Do you know if this will work on Audi Sympony systems
    So is your phone kept in the glove all the time?
    Do you have any pics of your setup?
    May 20 2009
    Hartford
    it wont make a different if you have rns-E or not....as long as you have the factory ipod jack in the glovebox. I dont have any pics...but like i said...its all factory. I actually use an ipod classic so that stays in the glove box at all times. I used the iphone for music for about a week when i got my car (as per the setup i described in my prior post). The cable is just a simple ipod dock extension cable...it will work with any ipod iphone product that has the standard apple jack. There is a 6ft cable so if u want you can route the wire from the glovebox and up to the center armrest or something if u want.... having the extension cable just adds flexibility of where u put ur phone i guess.
    Feb 04 2008
    Chicago, IL
    Sounds like a limitation of the B7 audio systems.
    A solution would be to pick up an aftermarket head unit or get a B8...
    May 20 2009
    Hartford
    Quote Originally Posted by Nikoman View Post
    whats the limitation?
    bluetooth for calling works
    charging the phone works
    controlling your playlist from our headunits works (cant read titles though)
    seems to do the job decently.
    Ill be picking up a pioneer touchscreen navi/dvd player next year....i hate the rns-e lol
    Nov 08 2009
    Ottawa, Ontario
    Limitation being no audio through bluetooth.
    Sell me the RNS-E then :)
    May 20 2009
    Hartford
    Quote Originally Posted by FuriouS View Post
    True...but i wasnt sure the iphone could transmit music via bluetooth (didnt this it had a2d bluetooth or wahtever its called for stereo bluetooth streaming)
    Yea the RNS-E wont be for sale until spring.....unless u can find me a sweet deal on a Pioneer AVIC-Z110BT now
    Oct 05 2009
    Thanks for all the info. Well my cable came in today, everything works as expected. The only thing is that it doesn't charge the iPhone. Is this a cabRl problem ? it complains that this accessory is not intended for this device bla bla would would like to turn on airportmode
    any possible solutions ?
    Jan 14 2006
    IN
    The iPhone uses a different interface protocol than what iPods use. Apple decided to switch out the 12v FireWire for a 5v USB connection and for some reason, this doesn't allow charging. This Scosche adapter reportedly solves this issue, but I've never tried it.
    Feb 04 2008
    Chicago, IL
    not showing titles of songs is a deal breaker for me.
    Veteran Member Four Rings chaze's Avatar
    Sep 16 2007
    2001 A4 Avant, 2009 328i
    Canyon Hills, CA
    Quote Originally Posted by gizmo99 View Post
    Same situation on my e90, which even has a special ipod package. Plays, controls, gets titles, but doesn't charge. I've forgotten and been listening for an hour or two then when I get where I'm going my phone is dead, ugh. But like was mentioned above, there is a small adapter that goes between the dock cable and the phone that allows charging.
    -Chris
    2001 A4 Avant - Apr '11 to Present
    2008 A4 Sedan - In the graveyard
    Oct 05 2009
    Thanks for the reply and solution! Will definitely get an adapter.
    With an adapter, now I need to figure out to get proper mounting / holder that supports this setup
    Oct 05 2009
    Just curious, are there any ways to update the old iPod interfaces in the Glove to allow charging ? That adapter is as big as a zippo :)
    Sep 16 2007
    Canyon Hills, CA
    Don't know about yours but my iphone won't physically fit in the glove box interface. My solution was to use an old 30 gb classic that I had laying around for JUST music and keep my phone free. As in free to charge off of a 12v cig plug cable. Good luck.
    -Chris
    May 20 2009
    Hartford
    Quote Originally Posted by chaze View Post
    Yea i only used my iphone for music for about a week. I had an ipod classic so now that says in my glovebox all the time so my phone is free to come and go with me.
    The iphone DOES NOT fit in the audi glovebox ipod dock. You have to get an extension cable. I got mine from cablejive...pricey but i dont know anyone else that makes them. I think i paid $30 for 6ft.
    Nov 04 2009
    Norcal
    Stereo BT = A2DP.
    Bummer that the BT interface from Audi doesn't handle it.
    Maybe new deck is needed for me.
    Veteran Member Three Rings EuroSpec27's Avatar
    Sep 07 2009
    North Jersey
    My iPhone won't connect to my bluetooth, however when I had my Blackberry it worked fine. Any advice on what it could be?
    _Thanks
    '08 335xi Coupe
    Titanium/Coral
    6MT/Nav/Premium/Sport/Cold Weather
    May 20 2009
    Hartford
    Quote Originally Posted by HondaVtec21 View Post
    _Thanks
    Turn off the blutooth on your iphone. Get in your car, shut the door, turn your car on. Now turn your bluetooth on your iphone on and see if it recognizes the audi system. You have to setup the initial pairing within 5 minutes of the car turning on before you drive off. After that it will be automatic whenever u get in. This is what the dealer told me when i bought the car and thats how i set it up. Works great.
    May 15 2009
    07 Audi A4, Honda Pilot
    Auburn, AL
    Look up enfig. The dension gateway 100 or 3oo will play music from your iphone and charge it. Its 10 times better than the audi ipod adapter. Easy to install as well. There are lots of posts about the dension gateway adapter on the forum.
    Oct 05 2009
    I finally got my iPhone hooked up with charger enabled (via adapter).
    Question: how do I STOP the iPhone from actually automatically playing. In other words, is there a "STOP" Button? I ask because sometimes I hook up my GPS to it and there are no options for me to turn music off (or stop playing music from playlist)
    In fact, on the Audi Systems, I dont even see a STOP button for CDs
    Veteran Member Four Rings Kubus's Avatar
    Aug 10 2009
    2017 Audi S3
    Montreal, QC
    My Kufatec Bluetooth with Symphony II allows me to do music from my 3Gs over Bluetooth. It sounds ok but not super.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    You can only "stop" on the iphone itself. note that if the ipod app is playing you can double tap the home button and it will bring up the ipod mini-player to quickly stop your song.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Oct 05 2009
    The problem is, once I stop it. It automatically starts playing agian
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Really? Under what circumstances? What kit are you using?
    Edit: Just saw you are using the OEM Audi kit. I haven't heard anything good about them, nor do I know enough about them to solve your problem. Maybe an aftermarket kit in my thread that was posted here earler?
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Jan 18 2005
    North NJ
    Senior Member Three Rings AnewMadrid's Avatar
    Jan 14 2011
    2019 S5 ,2019 Q5
    Silicon Valley
    my car doesn't have the MMI and I really need to get my iphone working in there. It has the bluetooth setup and the phone prep in the armrest but the only "cradle or adaptor" I found to work with armrest is in the UK and its like 250 USD. Can anyone guide me to a more cost friendly cradle?
    Thanks,
    ANEW
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    i have rns-e and i can:
    - play music with my ipod 3gs
    - connect bluetooth
    - can't charge :-( the old iphone charged, and worked better, and was faster....god i miss that fone
    - it fits in the glove box with a little elbow grease (or if you have a lazy saturday and a dremel you can grind down the sides and have a roomier fit)
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Jan 14 2011
    2019 S5 ,2019 Q5
    Silicon Valley
    I have an ipod already in the glove and that works fine, I just want my phone to work in the car as I am on it frequently, without having to use my old blueAnt speaker. I don't know if i'm missing something here, I searched the forums and the only one I came up with is that one in the UK. Actually I haven't went to the dealer, so I will do that tomorrow.
    ANEW Madrid
    Jul 08 2010
    tucson
    danbury
    umm not sure if i read your posts correctly but you have bluetooth feature in your car? it should play off the speakers and theres a mic on the ceiling console you dont need that cradle
    [CENTER]Scott
    2011 S4
    Jan 14 2011
    2019 S5 ,2019 Q5
    Silicon Valley
    I figured out what was wrong, it was paired to my blueant and couldn't pair with the car. All is golden now.
    Established Member Three Rings b7kevin's Avatar
    Jan 04 2011
    East Haddam, CT
    My solution was to use a cassette adapter, cost $5 and plays all the songs I want :)
    2006 A4 Brilliant Black 6MT
    - Revo Stage 2+ - AWE HPFP - ST Coils - K&N - 034 TIP - Newsouth Vent Gauge - Neuspeed Snub - OEM DV Upgrade - E-Code test pipe - AWE Quad tip - s4 rear valance - de-badged - vag'd -
    -Wake up an address the biggest issue of our freedom. National DEBT.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Quote Originally Posted by b7kevin View Post
    Does the Symphony seriously still come with a cassette player? Anyway, with a tape adapter the sound is not as good, you aren't charging unless you plug it in to ANOTHER adapter (wires FTL), and you can't control your iphone/ipod with your steering wheel.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Jan 14 2011
    2019 S5 ,2019 Q5
    Silicon Valley
    my car doesn't have a tape player and I can scroll through my phonebook and pick who I want to dial, so it's working perfect for me now, was user error on my part.
    ANEW Madrid
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by JMG View Post
    Symphony I, I believe came equipped with the cassette player.
    Jan 04 2011
    East Haddam, CT
    I believe my headunit is the symphony 2, double din in dash cd changer. BTW the sound is AMAZING with the cassette, as it is digitally upconverted. I can still navigate my phone book and increase and decrease volume with my steering wheel. Iphone 4 battery is 10x better than the old, so I rarely charge it in the car. I also cant stand navigating through artist through the headunit. It is retarded. Seriously.... It locks the phone its 100x easier to chose artist and song on the unit itself. Unless you have a menu system as efficient as the iphone itself integrated into the car, I'll stick with my $5 adapter and use the single wire as with your glovebox unit.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    It may be digitally upconverted but it's going digital to analog first and will lose quality. I agree that it is much easier to navigate with the iphone itself, but to quickly go to the next song it's nice to use the steering wheel.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
